Old 03-12-2006, 10:37 AM   #1
raydadick
Guest
Member#:
Question good mods to do while engine is out?
what are the obvious mods to do while the swap is getting done? i have a goal of trying to get close to 300whp out of the 2.0 turbo
Old 03-12-2006, 02:09 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
uppipe port
matched headers
flywheel
timing belt
rear main seal (depending on age)
Old 03-12-2006, 02:54 PM   #3
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
I'd also add...
Radiator,
Oil catch can,
Oil cooler kit.
Others might pop up in ym head later and i'll edit my list.
DoctorNick is offline   Reply With Quote
Old 03-13-2006, 11:21 PM   #4
raydadick
Guest
Member#:
if matched headers means equal length i think i would rather have unequal length headers for the sound.
my ideas were up pipe, down pipe, headers, bov, wastegate upgrade, etc. i am not aiming for high hp number off the bat, just building up to it as i can afford to, but i want to get some of the stuff that is a b*t*h while it will be easier. i also am not sure about a flywheel upgrade since it will be a daly driver
Old 03-13-2006, 11:33 PM   #5
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
-Clutch
-Plugs
-Timing belt
-Tap for EGT
-Injectors
Essentially any maintanence or performance you can afford...it's so much easier out of the car. Good luck.
Louis
Soon2Bgreat is offline   Reply With Quote
Old 03-14-2006, 11:31 AM   #6
Randoramma
Member#: 60649
00RS EJ205 swap
^^^ What he said, I'd also add h20 pump, oil pump, I did F & R main seals also, cheap and very easy to do while its out...also timing belt tensioner. Are you doing EJ207 at least? I think you will hit those big numbers with tuning, and turbo selection.. and hopefully your EJ207..
Oh, also might as well put in that walbro255lph pump, and not the stock WRX replacement. If you wanted to, and had the cash, you could also do some higher lift cams too. Keep the durations close to stock, you should do higher rate valve springs too if you do that.
Randoramma is offline   Reply With Quote
Old 03-14-2006, 12:44 PM   #7
raydadick
Guest
Member#:
as far as what engine it will be i dont know. im getting the swap done and whatever the newer wrx has will be it. i am trying to decide to do the dash swap also or use that money to make it faster.
Old 03-14-2006, 01:48 PM   #8
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
flywheel isnt a concern for drivability, unless you are going ridiculous. i cant drive with a stock flywheel, it makes me depressed and throttle response slower on an already slow responding car (bc its turbo). haha
get a light fly. like 14lb or somthign liek that. make yourself happy.
swapstar is offline   Reply With Quote
Head gaskets being replaced, what else to do while engine is out nardvark Service & Maintenance 9 04-15-2009 03:10 PM
Mods to do while replacing clutch? SPECTRE2099 Transmission (AT/MT) & Driveline 9 03-22-2009 01:47 AM
What mods to do while heads are off?? Cams, Port and polish, Blah blah blah???? supersuby2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-23-2008 08:40 PM
things to do while intake manifold is out? awd-box-turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-08-2007 06:47 AM
Quick questions while the engine is out and i'm replacing the clutch/flywheel Anhdalai Transmission (AT/MT) & Driveline 1 10-01-2007 12:11 PM
