Old 03-12-2006, 01:11 PM   #1
quickscooby
Member#: 39415
STI [email protected]
479/492 @ 30psi GT30R .82
Default Tuning higher load cells
I've heard the phrase: Need to tune in the higher load cells a couple times. What does this mean and how is it done?
If the "higher load cells" aren't optimum would it cause a car to pull timing at the drag strip but not on the street or dyno?
quickscooby is offline   Reply With Quote
Old 03-12-2006, 02:58 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
It generally means tune fuel and boost for higher boost levels even though it isn't recommended the car be run there. I can also mean tune your high boost load sites farther up in the RPM range even though under normal tuning boost drops at high rpm.
This will ensure a proper and safe tune in the event of boost spikes or creep.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Access tuner race.. rescale load cells? tolnep AccessPort 33 02-24-2010 04:14 PM
Front wheel bearing with higher load rating Patrick Olsen Brakes, Steering & Suspension 46 10-27-2009 07:55 AM
utec tuning problems , load WRXout Engine Management & Tuning 32 03-26-2005 01:50 PM
UTEC Tuning question....load site's jstbstn Engine Management & Tuning 20 03-16-2005 09:12 AM
Anybody rewound their alternator before for a higher load? well_armed North West Impreza Club Forum -- NWIC 35 12-08-2003 01:10 PM
