Old 03-12-2006, 07:46 PM   #1
normansti
Member#: 89691
Default how to load a realtime map?
Can anyone help me out here? I got ap and I tried to load a realtime valet mode but its not working. am i doing somthing wrong?
normansti is offline   Reply With Quote
Old 03-12-2006, 08:01 PM   #2
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
All you should have to do is plug it into your car then select "1. Switch Map".
boundy3 is offline   Reply With Quote
Old 03-12-2006, 08:06 PM   #3
normansti
Member#: 89691
I tried it and it didnt work.
Old 03-12-2006, 08:10 PM   #4
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Can you list what you are doing in order? That'll make it easier to diagnose....and the obligatory, did you read the directions?
darkstarmoto is offline   Reply With Quote
Old 03-12-2006, 08:13 PM   #5
normansti
Member#: 89691
plug in ap, click switch map, scroll down to valet mode, turn ignition switch to on position, select valet mode, then it says sending....., sending complete click ok, turn ignition off, unplug ap, and still a no go,
Old 03-12-2006, 08:22 PM   #6
-Kevlar-
Member#: 82378
its not hitting the rev limit?
-Kevlar- is offline   Reply With Quote
Old 03-12-2006, 08:24 PM   #7
normansti
Member#: 89691
nope, i took it to 4500
Old 03-12-2006, 08:28 PM   #8
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
Its been awhile since I loaded a realtime map. Do you have to do anything with the connectors under the dash?
ihavebettersound is offline   Reply With Quote
Old 03-12-2006, 08:29 PM   #9
normansti
Member#: 89691
you tell me?
Old 03-12-2006, 08:30 PM   #10
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
lol Don't like reading directions huh?
Cobb's website has step by step instructions on how to do that.
Old 03-12-2006, 08:31 PM   #11
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
You need to have the conectors mated to change realtime maps.....my question is why are you trying to flash Valet as your realtime. You do realize that anytime you do a ECU reset it will revert to Valet mode, yes?
Old 03-12-2006, 08:32 PM   #12
normansti
Member#: 89691
yes i know but i dont want to load a basemap. I tried with the green connectors plugged in also and its a no go.
Old 03-12-2006, 08:33 PM   #13
-Kevlar-
Member#: 82378
no you dont!!! your thinking base map.... think before giving the wrong info.
IBunclescottyW WjustW W
Old 03-12-2006, 08:36 PM   #14
-Kevlar-
Member#: 82378
try starting w/ the key in the on position....are you sure its in the on position or the acc?
Old 03-12-2006, 08:42 PM   #15
boundy3
Member#: 54598
2004 WRX Sedan
^^^ What wrxblubayou said, no need to connect the green connectors or plug in the itialization connector when switching realtime maps.
try a different realtime map, like one of the anti-theft maps and see if they work.
make sure the igntion is in the on position.
can you switch basemaps?
what kind of subaru do you have and what year?
Old 03-12-2006, 08:43 PM   #16
Rev1
Member#: 51240
08 Lexus IS350
Rev1 is offline   Reply With Quote
Old 03-12-2006, 08:46 PM   #17
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
Doh..my bad...for some reason I was in "basemap" mode...
and wrxblubayou I don't know what your problem is but you seriously better stop ripping me pal...ever since you "thought" you knew all about Unabombers set-up you've been on my case...grow up....
Old 03-12-2006, 08:47 PM   #18
normansti
Member#: 89691
I have an 05 sti. I deleted the valet mode from the accessport and downloaded a new one. rev suggested maybe the file was corrupted so ill try it.
Old 03-12-2006, 08:54 PM   #19
-Kevlar-
Member#: 82378
i really dont know what the hell your talking about , but dont do it in the forums on someone else's thread. pm me if you have a problem....
Old 03-12-2006, 08:55 PM   #20
-Kevlar-
Member#: 82378
its possible...good luck
Old 03-12-2006, 09:11 PM   #21
normansti
Member#: 89691
thanks. ill prob try in the morning. i dont feel like goin outside right now
Old 03-13-2006, 02:26 AM   #22
PattyB69
Member#: 92559
I load Anti Theft A realtime map everynight cause I live in a sketchy Neighborhood. Here is the process in order..
1.Turn Ignition to "On" position but dont start it.
2.Plug the AP into that slot underneath the steering wheel.
3. Select "Switch Map"
4. Choose whatever map you want.
5. Wait until it loads and then hit "OK" or that enter button.
6. Turn off ignition.
7. Disconnect AP
And then when your ready to clear it. Just turn the ignition into the ON position again without starting it. Connect the AP into the car again. Choose "Reset ECU" and then after hit "OK". Turn the car off again and then disconnect AP
Thats all I do to load realtime maps. Do it just about everynight. Hope that helps you out. let me know if it still doenst work.
PattyB69 is offline   Reply With Quote
Old 03-13-2006, 09:18 AM   #23
normansti
Member#: 89691
thank you.
Old 03-13-2006, 12:43 PM   #24
nate49509
Member#: 22452
2016 WRX
7. Disconnect AP
Wow. You go through that every night? Must really be a bad neighborhood.
nate49509 is offline   Reply With Quote
Old 03-13-2006, 02:31 PM   #25
PattyB69
Member#: 92559
Ehh its not really that bad. Its just sketchy. And ive thrown so many thousand of dollars into my car that I really would sleep better at night knowing that the Anti Theft map was in.
Its really not a big deal. It honestly takes about 30 seconds then im done. 30 seconds of my time, that gives me peace of mind. So its all good
How to load maps from computer to ap BigSteiner5 AccessPort 1 10-02-2009 05:01 PM
Is it possible to load a APV1 map to opensource? spoolinsti05 AccessPort 13 03-09-2008 05:39 PM
How to load UTec Stage 1? STUDAndring Engine Management & Tuning 2 11-22-2004 04:46 PM
How to load your motorcycle. Real or fake? JMP73 Off-Topic 8 10-20-2004 09:18 AM
active perl, how to load mods? m750 Off-Topic 11 03-01-2004 04:20 PM
