Old 03-12-2006, 10:03 PM   #1
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
Default RWD vs AWD: How much power is too much for 2 wheels?
So, given the recent debates on how RWD > AWD for general track useage, does that ever change with increase power? I would think that eventually, the benefits of RWD would be overcome by traction issues and putting the power to the pavement. Afterall, the tires can only get so wide. I know a lot of supercars (Enzo) are RWD with lots of power, but there are also those with AWD and lots of power (Porshe CGT). So which is more effective at running around the track on a dry day, as in could you boost the power enough to where RWD would be pointless because the power would never get to the ground? Anyone with more knowledge like to comment?
Prod is offline   Reply With Quote
Old 03-12-2006, 10:05 PM   #2
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Two words...
Audi Racing
GLwagon is offline   Reply With Quote
Old 03-12-2006, 10:05 PM   #3
wyn525i
Member#: 27986
The Carrera GT is RWD, Ginger.
wyn525i is offline   Reply With Quote
Old 03-12-2006, 10:06 PM   #4
Briman2021
Member#: 70363
1989 Conquest
This guy uses RWD, so its good enough for me.
Briman2021 is offline   Reply With Quote
Old 03-12-2006, 10:06 PM   #5
grannyshifter
Member#: 90312
FWD can handle more power than RWD and AWD, just look at the SRT4!
grannyshifter is offline   Reply With Quote
Old 03-12-2006, 10:08 PM   #6
ivwarrior
Member#: 100610
MBP
Yeah, but he only goes fast STRAIGHT.
ivwarrior is offline   Reply With Quote
Old 03-12-2006, 10:11 PM   #7
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
Whoops, I was thinking 911 turbo.
Old 03-12-2006, 10:12 PM   #8
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
werd. I'm talking road course.
Old 03-12-2006, 10:14 PM   #9
quentinberg007
Member#: 7887
And the GT2 and GT3 (more balls out race cars than the 911 turbo) are both RWD.
~~Quentin
quentinberg007 is offline   Reply With Quote
Old 03-12-2006, 10:19 PM   #10
StuBeck
Member#: 19546
2009 Honda Fit
I think about 600+ hp is too much for very high end cars, but its probably much much lower fo others. Hell, you see people spinning out with under 200.
StuBeck is offline   Reply With Quote
Old 03-12-2006, 10:19 PM   #11
WRXVT
Member#: 17979
335i Blue
but then you have the lambos that are awd as well.
Its all about preference. Top gear did an episode on it. Basically either is good, with its own advantages. awd shoots out of corners easier, apply throttle earlier. rwd is more light feeling and won't understeer into a turn
WRXVT is offline   Reply With Quote
Old 03-12-2006, 10:27 PM   #12
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
But what if you had 1500hp/1500ft-lbs, could you still effectively put that down with RWD?
Old 03-12-2006, 10:27 PM   #13
StopSweatinMe
Member#: 78421
2013 Toyota Avalon
Nautical Blue
So it's impossible for a high-hp RWD car to handle well? Dont be stupid, stupid.
StopSweatinMe is offline   Reply With Quote
Old 03-12-2006, 10:31 PM   #14
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
When you are able to spin the tires all the way from one corner to the next on the longest straightaway on a given track, THEN you have enough power.
nhluhr is offline   Reply With Quote
Old 03-12-2006, 10:35 PM   #15
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
AWD is more stable obviously, easier to drive. But with RWD , you can use the throttle to steer the car. If you look at Touring Car, the AWD cars only have a good advantadge when it's raining, other than that....
They borh have their pros and cons, but in "ideal" conditions, RWD wins out due to efficiency, weight and simplicity. There was a formula 1 car (or two) that were built with AWD, but that was ditched.
bobturismo is offline   Reply With Quote
Old 03-12-2006, 10:38 PM   #16
StuBeck
Member#: 19546
2009 Honda Fit
Lambo's are AWD because it is a feature they have, much like 911's are rear engined because they've always been so.
You can't really compare a drag car making 15,000 hp versus an F1 car making 950. The F1 car has TC and massive downforce too making it just a tad easier to drive at teh same speed as a road car.
Old 03-12-2006, 10:43 PM   #17
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
If the driver knows how to drive, the car properly set up, and is used to the car, no amount of power is "too much"
gjhsu is offline   Reply With Quote
Old 03-12-2006, 10:50 PM   #18
Gcbinc
Member#: 28459
But I'm over
here now.
I learned that Hyenas are FWD, dogs are RWD.
That's what I learned about drive wheels from Top Gear.
GeoB
Gcbinc is offline   Reply With Quote
Old 03-12-2006, 11:02 PM   #19
mamiyarz67
Member#: 55940
05 LGT 5SPD WGN
Royal Blue Pearl
when is to much to much, i got 2 words
Dodge Viper
mamiyarz67 is offline   Reply With Quote
Old 03-12-2006, 11:33 PM   #20
Fuzz541
Member#: 4739
Fuzz541 is offline   Reply With Quote
Old 03-12-2006, 11:35 PM   #21
Guru Imakuni
Member#: 58773
when is to much to much, i got 3 words
C6 Z06 Corvette
Guru Imakuni is offline   Reply With Quote
Old 03-12-2006, 11:37 PM   #22
left footed whooten
Member#: 44652
06 WRX
17 Colorado Duramax comin
The ultimate answer:
42
left footed whooten is offline   Reply With Quote
Old 03-12-2006, 11:47 PM   #23
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
The last race I saw on Speed was at Laguna Seca. I don't remember what class it was, but there was a mixture of AWD, FWD, and a couple of RWD coupes and sedans on the race track. The cars were supposed to be matched for power, but the AWD cars were just whooping everyone else around the track. There was 2 or 3 audis that were grouped together way ahead of the pack.
I think it really depends on the track, but in this case AWD had the advantage big time.
Old 03-13-2006, 12:06 AM   #24
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I have 390 BHP / 333 lb-ft RWD and really it is too much at low speeds. Above 40-50 MPH or so it is ok to open up. My car will sometimes break traction in 2nd as it hits the power peak, in the dry. There are blinky lights and warning beeps when that happens - depending on the shifting mode it will do different things; ie allows some wheelspin/sideways crabbing in sport mode, crazy tire smoking wheelspin in "everything off" mode.
And then there's wet weather...
The experience is quite different than driving a Subaru where you really never think much about traction under acceleration, just about balance of the car and when to brake.
ANZAC_1915 is offline   Reply With Quote
Old 03-13-2006, 12:08 AM   #25
Guru Imakuni
Member#: 58773
Your Maserati doesn't have traction control?
How much HP is too much for the WRX? snvin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 12-02-2004 09:55 PM
how much rain is too much rain for CART autox? bowenx New England Impreza Club Forum -- NESIC 3 09-28-2001 08:32 AM
How much PSI is too much PSI? virus67 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-15-2001 06:48 PM
how much bar is too much? Darryl Brakes, Steering & Suspension 17 06-08-2001 12:23 AM
How much Nitrous is too much? KillerTHC Normally Aspirated Powertrain 3 05-23-2001 07:14 AM
