Welcome to the North American Subaru Impreza Owners Club Friday August 1, 2014
Old 09-27-2001, 04:32 AM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Default Ton's of engine swap questions for you Gurus
ok, so I tore apart my engine (as best as I could with it in the car) and found that my #4 piston has a small piece missing (about the size of a lady bug and about 1/32" deep into the piston) and that is why I heard all the piston slap and noise. I am going to be pulling the engine in the next few days (gonna miss racing in the Rally-x atthe Prescott Forrest rally ) and I have a few question.
Let's get this out of the way, I did a search and nothing
1) I got the Passenger head of of the car but I'm guessing that there is no way to get the driver head off until I pull the engine right?
2) can I pull the engine without taking the tranny out or anything? In other words, can I unbolt the bellhousing from the engine and leave the tranny/bellhousing in place by just unding the engine mounts and moving the engine forward? Also, does the radiator need to come out?
3) Obviously a hoist is recomended but can two people lift the engine and pull it? I lifted my new EJ22T short block and it doesn't feel to heavy
4) do I need to lift the car for any reason?
Thanks!
Eric
Eric SS is offline   Reply With Quote
Old 09-27-2001, 07:39 AM   #2
Longshot
Member#: 2359
2001 Impreza 2.0 WRS
Default Re: Ton's of engine swap questions for you Gurus
Okay first off.. I'm not a guru, I've never done this before.. but I have been witness to it and I did pay careful attention, so I'll answer a few questions.. at least what I know...
When I saw it done on an OBS, it appears the tranny was still attached, well most of it.. just the clutch area and everything from that on to the engine was taken apart. The radiator was also still in the car at the time. Again.. I'm no guru so take it with a grain of salt, but I'm at least trying to be helpful..
This one I got.. when it was pulled out it was done using a hoist, but afterwards the guys doing it noted that it was really light, so its possible you could do it with 2 or 3 ppl, I'd still recommend a hoist.. to do some CYA, but its not heavy
I don't believe so.. the ppl I watched didn't.
...poke around the NESIC forum.. there are pictures of what I was talking about.. two guys pulled out the engine out of an OBS to change headgaskets and other minor things, but I do know for a fact there are pictures lying around...
Korey
Longshot is offline   Reply With Quote
Old 09-27-2001, 07:15 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Thanks for the info anyone else have anything to add
Eric
Old 09-27-2001, 08:11 PM   #4
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Sure, I'll give it a shot.
1. If you pulled the passenger side heads, that's the #1 (front) and #3 (rear) side. Try it - if you can't get the other header out, then at least you still have the option of pulling the engine.
2. Pull the tranny bolts, undo the engine mounts, jack up the engine off the crossmember, and get a prybar to separate the tranny from the engine. The radiator has to come out or you will surely damage it while separating the two. Use a sheet of plywood to protect the A/C condenser, which you can leave in the car.
3. I'm a scrawny weakling, so there was no way I could have lifted that engine out of the car, even if there was four of me. Rent an engine hoist for a day if you have to. The last thing you need is for someone to lose a grip and drop the engine on your fender or front bumper.
4. You may need to jack up the car to get at the exhaust header bolts and lower tranny bolts.
-WaC
Wayne
wac is offline   Reply With Quote
Old 09-27-2001, 09:46 PM   #5
Longshot
Member#: 2359
Hehe... it was Wayne's car I was looking at... so of course he showed up to further prove I'm no guru
Thanx Wayne... I think
Korey
...would like to think he knows how to work on his car...
Car Starting Problem/Question For You Gurus szeny Electrical & Lighting 42 10-03-2007 09:21 PM
Engine Internals question for the Gurus. BlackoutWRX Factory 2.0L Turbo Powertrain 4 11-06-2006 10:59 PM
Just got my Digi Rebel -- Questions for you gurus perret318 Off-Topic 6 04-30-2004 11:52 AM
Computer software question for you gurus JDM5LugHatch Mid Atlantic Impreza Club -- MAIC 27 03-03-2004 02:36 PM
easy question for you gurus out there a0f6459 Texas Impreza Club Forum -- TXIC 7 01-23-2002 12:27 PM
