Old 03-13-2006, 01:58 AM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default You have EMAP? Here is how to use ECUExplorer for data logging!
Mod, I understand that there is a post on subaru free logger:
http://forums.nasioc.com/forums/showthread.php?t=774757
I just wanted to summarize in a few step by step procedure so that inexperienced users like myself can easily understand what needs to be done.
For those who have not tried ECU Explorer, it's a simple tool to monitor how your car (e-map) is operating. It's a great tool for those who do not have time to get a Protuning and must rely on emaps from tuners like PDX Tuning or TDC.
Here is a link to the latest ECU explorer verison 3.0.25 (link fixed thanks to JR)
http://www.tari.co.za/cgi-bin/yabb2/...LatestReleases
1. Install ECU explorer software in your computer. You will need to use a cable that came with an AP to connect your laptop to your car. However, you will need to buy a serial to USB adapter for around $30 from Best Buy. You can probably get it for around $20 online.
2. With your computer connected to your car, use a defog switch to start data logging. Drive around town doing a few 3rd gear pull. Turn off defog switch when you are done.
3. Go to C: directory in your hard drive to review .csv file. Use an EXCEL to open the file. When defog is turned on, data logging starts automatically.
4. If you are not experienced in understanding recorded parameters, email your .csv file to your tuner for their opinion. Your tuner will make necessary correction or revision.
Old 03-13-2006, 08:25 AM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
What's EMAP/e-map?
Jon [in CT] is offline   Reply With Quote
Old 03-13-2006, 09:03 AM   #3
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
You can get an emap from tuners like PDX or TDC tuning. They email you a real/basetime map, which you can use to reflash ECU. It's like Cobb AP maps, but they are more customized to your specific modifications.
Old 03-13-2006, 10:21 AM   #4
JRSCCivic98
Member#: 67080
Oh, so we're gona start calling these AP maps EMaps now huh? I don't mean to be rude here (yeah, I do), but how is this any different then wanting to datalog your ECU... period? Just because you have a custom (emailed) AP map does not change the procedure for datalogging with ecuExplorer... which I think everyone is aware of how to do.
Oh and next time, make sure you have the correct information. The DL1 link you posted is no good. That program isn't even used or supported anymore.
Here's the correct ecuExplorer (latest version) link.
http://www.tari.co.za/cgi-bin/yabb2/...num=1138965460
JRSCCivic98 is offline   Reply With Quote
Old 03-13-2006, 11:46 AM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
JRSCCivic98, thanks for fixing the link! Can't believe I posted incorrect link!
Reason why I posted this is because not everyone is experienced with data logging. I wasn't aware of ECU explorer and did not know how to perform this procedure. Thought it maybe useful for people to be aware that they should perform data logging whenever they received custom e-maps from tuners since all cars operate differently.
Old 03-13-2006, 10:31 PM   #6
JRSCCivic98
Member#: 67080
Actually you're right... I didn't have my morning cigarette yet when I posted the above so I tend to be a little short. Anyhoo, thought I'd post the reason for being so short even if you didn't call me on it. Sorry. I just felt (at that time) that what you had posted was covered in the past... that and I know PDX suggests using the Tari logging software to datalog their maps that they send to users... so I would have thought that everyone with PDX custom OTS maps would already be previed to such info.
Old 03-13-2006, 10:49 PM   #7
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
No problem. What I learned is that a lot of people order these custom maps and take a big risk by not running any data log. People tend to rely on butt dyno alone and assume everything is safe. When you order custom maps, tuners don't tell you how to perform data log.
Old 03-13-2006, 11:06 PM   #8
JRSCCivic98
Member#: 67080
Heh, if you think it's important to datalog after you just update the EM, here's a good example of when not to trust your butt dyno. (My experience)
http://forums.nasioc.com/forums/showthread.php?t=954043
Old 03-13-2006, 11:29 PM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Yes, that's a very good example.
Pics and Directions for the headlight mod! Heres how to do it for all you n00bs. STR8OUT Interior & Exterior Modification 31 05-04-2009 02:17 AM
How to use accessport v1 cable for data logging shawns02wrx AccessPort 4 04-14-2009 12:30 AM
how to use logging software? Thugthizzle Engine Management & Tuning 8 03-23-2007 02:16 AM
How do I post a data log? Redline927 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-29-2006 05:58 PM
Want to use AximX50 (Pocket PC) for data logging btour99 Engine Management & Tuning 10 01-25-2006 12:30 AM
