Old 03-13-2006, 02:10 PM   #1
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
Default AWD Fuel Tank Conversion Question???
I just purchased and installed an AWD gas tank from a Legacy. The main sending unit has 5 wires. My car has 4 wires. The extra wire is for a fuel temp. sensor, I think. I wired all the matching wires together and tapeing off the other. I used a fuel pump that I know works in the AWD sending unit. I did not touch the wiring in the secondary sending unit. When I turn the key to the on position I can here the fuel pump run, But the car will not start. If anyone can help please tell me what I've overlooked.
Thanks,
Wayne
Wayne_Coots is offline   Reply With Quote
Old 03-13-2006, 02:43 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm if you get the fuel pump prime the car should start ...
if the return line was fubar it might cause this ...did you get the return hooked up to the right port- thinking you connected it to the vent port which might have a check valve ..
Old 03-13-2006, 05:39 PM   #3
Lachlan
Member#: 19470
1981 Brat GL
Doesn't sound like a fuel pump problem then. Is it cranking at all?
Lachlan is offline   Reply With Quote
Old 03-13-2006, 07:33 PM   #4
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
Yes the car cranks. All I did was change the tank. I took out the working pump that I had and put in the new tank. I am going to double check the lines in a minute.
Old 03-13-2006, 08:36 PM   #5
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
If I cycle the key to the on position and back to the off position several times in a row then try to start the carit will tray to start for a couple of rotations. When you mention priming how exsactly do you go about doing that?
Old 03-13-2006, 09:39 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
priming as in
when you turn the key to on the ecu turns on the pump for ~1 sec then shuts it off until it sees measurable RPM
Old 03-13-2006, 10:33 PM   #7
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
Yes, it pimes itself. But if I take off te fuel line it doesn't send any fuel out. Do I need enough gas in the tank to have some on both sides of the tank?
Old 03-14-2006, 12:30 AM   #8
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
this might be a stupid question but are you sure you hooked up the hoses in the correct position? My FWD gas tank only had 2 lines going into it and the awd one had 3. one coming from the other side I believe or something of that sort.
scobaru is offline   Reply With Quote
Old 03-14-2006, 12:50 AM   #9
spongejosh
Member#: 62783
Midnight Black Pearl
why didn't you just reuse the impreza sending unit?
josh
spongejosh is offline   Reply With Quote
Old 03-14-2006, 06:06 AM   #10
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
Because the AWD tank requires the third conection in the sending unit to get the gas form the other side of the tank.
Old 03-14-2006, 09:40 AM   #11
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
could you take a picture of what you did or what your doing... i'm intrested to see a picture of the harness vs the old harness... when I did my AWD swap I used a legacy wireharness but I had to repin 2 of the wires...
Old 03-14-2006, 10:26 AM   #12
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
I spliced the Legacy plug onto the end of the Impreza harness. I wasn't sure about how to repin the plug. All of the wires matched up though. I already have the tank in the car. What are you wanting pictures of?
Old 03-14-2006, 10:30 AM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
mmm i believe the the third connection is for the charcoal vent not a connection to the drivers side of the tank
Old 03-14-2006, 11:42 AM   #14
Lachlan
Member#: 19470
1981 Brat GL
One of them pulls gas from the left side of the saddle over to the right side to be pumped.
Old 03-14-2006, 01:06 PM   #15
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
corect. The tank had all of the original hoses on it, they were cut but were still lined up apropriatly.
Old 03-14-2006, 01:11 PM   #16
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
I only replaced the hoses with new ones.
Old 03-14-2006, 01:12 PM   #17
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
I did not check the lines on the sending unit. Could these possibly be cloged?
Old 03-14-2006, 07:11 PM   #18
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
I am getting pressure at the sending unit but now were else. I have disconected both the send and return lines and no pressure on eather. I quadruple checked the lines and they are correct. Could the hard lines on the tank be clogged?
Old 03-14-2006, 09:23 PM   #19
Lachlan
Member#: 19470
1981 Brat GL
So you confirm that the pump is definitely pumping at the correct pressure?
Old 03-14-2006, 09:56 PM   #20
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
No. I don't have a fuel pressure guage. But the 93 Impreza that I took the pump out of was my daily driver. It had only been parked for a week while I was taking it apart to get rid of it when I took the pump out. The 95 that I put it in is now my only car. And I can't get it running. I am having to bum rides to work and back! I need some help bad!
Old 03-15-2006, 07:16 AM   #21
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
Bump.
Old 03-15-2006, 09:42 AM   #22
Lachlan
Member#: 19470
1981 Brat GL
nothing at the fuel filter?
Old 03-15-2006, 11:51 AM   #23
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah i suppose that is the next thing to try new fuel filter .. might even try flushing the hard lines
Old 03-15-2006, 05:07 PM   #24
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
No nothing at the fuel filter. But there is pressure at the sending unit.
Old 03-15-2006, 05:34 PM   #25
Lachlan
Member#: 19470
1981 Brat GL
Wierd. well, obviously there's either a leak or a block somewhere along the line from the sending unit to the filter. Some remote possibilities:
You wired the pump with opposite polarity and now it's pumping into the tank rather than out of it
You mixed up the hoses and you're pumping into the left side of the tank instead of to the filter (I would check the pressure on the left side of the tank just to make sure that's not it)
One of the rubber hoses is getting crushed by something, thus creating a block.
Which awd fuel tanks will fit into a 95L? 2slofouru Subaru Conversions 10 01-24-2007 01:28 PM
Impreza Fuel Tank Conversion comp1 Subaru Conversions 3 01-03-2007 07:02 PM
Fuel Tank For AWD GC? Wayne_Coots Private 'Wanted' Classifieds 2 02-02-2005 05:50 AM
light kit and fuel tank conversion souljaboi Subaru Conversions 3 06-01-2004 10:31 PM
Fuel tank capacity question STi-Nismo Dood Southern California Impreza Club Forum -- SCIC 9 07-05-2003 05:20 AM
