Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-13-2006, 02:43 PM   #1
DLBWRXR
Member#: 98036
Default most boost that can be run on deadbolt TD04.
How much boost can i run on a P&P tdo4 turbo with 5 deg. wheel clip?
i have a bar and plate TMIC With low (.5-.8 PSI drop)
My Access port allows a stock turbo with stock IC (2-2.5 psi drop) to run 16.3. can i bump the boost to ~17.2 with out any concerns. i have 255lph pump with stock injectors? mathmatically there is no additions strain on the turbo. it is still running the same psi at the compressor outlet right?
DLBWRXR is offline   Reply With Quote
Old 03-13-2006, 02:51 PM   #2
pezman04wrx
Member#: 66558
I've seen around 18-19psi run consistantly on the stockers ... Of course it only runs that boost from about 4k-5k until it falls flat on it's face, but it's there ...
pezman04wrx is offline   Reply With Quote
Old 03-13-2006, 03:25 PM   #3
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
MT_WRX is offline   Reply With Quote
Old 03-13-2006, 10:16 PM   #4
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
My stage 2 was running at 20 psi of boost before i got it ProTuned.
the question is what ur AFRs looks like running that much boost.
With it protuned i ran 18-19 psi - 235 whp. on a stock turbo, no P&P.
And the AFR is money now.
btw, what is the theory behind a Walbro with stock injectors??
markuswelby is offline   Reply With Quote
Old 03-14-2006, 10:39 AM   #5
DLBWRXR
Member#: 98036
Was told to get it by a performance shop to up FP. didn't think i needed it but i took there advice on it any way. but there telling me i shouldnt run more than 16.3 pounds of boost and when i did the math i thought i could run more.
Old 03-16-2006, 12:47 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...LOTS of us have run the td04 up to 20psi, peak.
....bump yer FP a bit and all's good
I ran my Monster td04(likely identical to yours, with the clip) to 18.5psi....it was a LOT of fun
Old 03-16-2006, 07:58 AM   #7
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
My Protuned td04 pushed about 19 psi at boost as well.
235 whp.
Old 03-16-2006, 03:29 PM   #8
DLBWRXR
Member#: 98036
235 whp.
did you bump the timing? i have street tuner software by the way.
Old 03-16-2006, 04:03 PM   #9
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
It was Protuned, sorry.
Yo no se.
Old 03-16-2006, 11:35 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
....mine was UTEC'd....and the timing was WAY bumped.
That thing was on 93 and a couple gallons of toluene in the tank and the whole thing cranked up
Old 03-17-2006, 12:09 AM   #11
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
What kind of power did u make??
Old 03-18-2006, 08:45 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
...lots and lots
Old 09-03-2011, 09:43 AM   #13
trini_suby
Member#: 174931
2005 Impreza WRX
CGM
16 psi
stock td04, stock intercooler
260whp, heatsoaked, with boost flux
2005 WRX
trini_suby is offline   Reply With Quote
Most boost anyone has ever run on a Subaru? WRblueX_Guy Newbies & FAQs 39 06-10-2006 03:14 AM
06 WRX, how much boost can be run on pump gas? riggs Engine Management & Tuning 9 11-23-2005 08:31 AM
Most harm that can be done by knowing IP address? Stickee Off-Topic 33 10-12-2005 04:59 PM
widest tire that can be run on a STi without rolling fendors? ndw1138 Tire & Wheel 26 04-09-2005 04:28 PM
what is the most whp that can be made on 91 octane? wrxben Engine Management & Tuning 8 06-25-2004 02:44 AM
