Old 03-13-2006, 04:14 PM   #1
subaru932001
Member#: 108442
1993 Impreza 2.5 8-)
Medium Red
Default 93 imp 5spd ecu upgrade
I built a 2.5 with 2.2 heads for my 93 1.8 imp, the motor has lots of torque but runs real lean between 2,000 and 4,000 rpm's. anyone know a good way to program this or a good mod to use/ chip. I have some extra ecu's laying around for everything from 1.8 imp's to 2.5 outbacks and foresters. Anyone moded a 93 ECU???
subaru932001 is offline   Reply With Quote
Old 03-13-2006, 05:01 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
What are you running for fuel? How do you know it is lean? Have you got a wideband on there, or just the stock o2 sensor and a cheapie gauge?
Old 03-13-2006, 06:20 PM   #3
subaru932001
Member#: 108442
Medium Red
I'm currently not running any O2 sensor. The reason that I knowits running lean is the motor feels sluggish like its starving until 4000rpms with the O2 sensor plugged in, but if I unplug it and the system goes closed loop then it runs pretty good but noticibly jumps at 4000rpms which tells me that the ecu is running lean between 2000 and 4000 rpms. I will probably pick up a wideband to see what its doing exactly but that is just diagnostic. I'm thinking of plugging up a 2.2 impreza ecu to see if that helps. For fuel iam running 93 octane due to the high compression from the 2.2 heads. This motor pulls hard but noticibly more at 4000 which tells me it can do more down low.
Old 03-13-2006, 09:34 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ee gad thats not a good way to find out your lean ..
could be but not likely running rich too
an emanage (better as the 1.8 ecu is know for some very high advance numebrs) or a safc would work if you had a wideband (wideband tunning is absoulty nessicary)
it amazes me that people think that running a stock ecu w/ major changes is a viable option
Old 03-14-2006, 09:32 AM   #5
kheff46
Member#: 66739
2002 WRX wagon
jaxx- is this true for all 1.8 ecu's? or just earlier ones? i've heard theres some differences between them. like up to 95 were the better ones. is this true? thanks!
kheff46 is offline   Reply With Quote
Old 03-14-2006, 11:38 AM   #6
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Hey matt would the ecu sold me help this guy out? also what he said about his 02 sensor didnt make a whole lot of sense to me.
Wouldnt the ecu go into "safe mode" not the closed loop with the 02 sensor removed? Doesnt it basically dump fuel in this mode?
If you go aftermarket, I would say the emanage. THat is running my friends turboed 2.5 with stock 1.8 ecu quite abit better than my perfect power/1.8ecu ran 2.2t
bmxpunk is offline   Reply With Quote
Old 03-14-2006, 12:31 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you gotta remember that the 1.8 ecu especially the older ecus are not nearly as smart i believe the only "limp" mode for the older ecus is caused by a failed maf
theorizing .. w/o a o2 sensor it would never trim the fuel to stoic. thus staying 12.5 to 1?? ... which would proved good power and terrible gas mileage, on a 1.8- on a 2.5 it will probably be stupid lean
the o2 sensor is probably adding fuel at idle and cruise to find stoic. once you hit the throttle is has no affect ...
Old 03-14-2006, 01:05 PM   #8
subaru932001
Member#: 108442
Medium Red
thats what I was wanting to know. I have been looking at e-manage and it doesn't seem to expensive but anyone know a good place to get 1 or a model # that will work with my ecu???
Old 03-14-2006, 03:04 PM   #9
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
93 ecu and emanage are not friends. i would pass on it
swapstar is offline   Reply With Quote
Old 03-14-2006, 03:54 PM   #10
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Really swapstar? maybe that is why my car hates teh perfect power. But I have the 95 ecu.
Also the emanage seems fine with my friends 93 ecu? Its the ultimate, does that make a difference?
Old 03-14-2006, 05:24 PM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes the silver emanage has about 3x the features of the blue one
Tuning / ECU Piggy back for a 93 Imp A1337STI Engine Management & Tuning 2 11-21-2008 08:28 PM
93 Imp L FWD - Converion to AWD 04.STI Subaru Conversions 1 10-01-2006 01:44 PM
FS: CNY area 93+ imp. highflow cat and Stromung catback Bluemanchu Tri-State Area Private Classifieds 8 04-26-2006 08:56 PM
will 93 legacy 5spd ecu work on 95 impreza after swapping 5spd into impreza? 2slofouru Subaru Conversions 7 01-28-2006 07:34 PM
93 imp L hood FS. hunter green supermoose Private 'For Sale' Classifieds 7 08-27-2003 02:41 PM
