Old 11-10-2000, 03:40 PM   #1
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Post KYB AGX w/stock springs report....
First off, waaaah! I miss the stiffer Eibachs (no, I don't miss the ride height issues).
There are signs of an overdamped condition, i.e. the springs not being enough for the struts at 2/4. I'll let them break in for a bit, then try tightening up the KYBs to see what happens.
I'm back at stock ride height which, after measuring, confirms the 1.6F and 1.75R drop that I got from the Eibachs. It's not to be leaving metal shavings on the lip of my garage, too. But now that I know what I had, I miss it very much. No question.
I took a familiar curve at the same velocity as with the Eibach/AGX combo, and it wasn't as securely planted, because of the softer springs, so I got a little bit of lean-based tire scrubbing. Ah, well. I'm sure something will come up.
Meanwhile, Duxler Tire, Evanston....$180 for spring install, alignment, and brake bleeding! I'm pleased with that number!
Kevin
gtguy is offline   Reply With Quote
Old 11-10-2000, 06:54 PM   #2
GTMAN
Member#: 480
1998 Legacy GT Wagon
Post
How is the ride comfort and 2f/4r? Is it better than the Eibachs + boosters?
If you're running overdamped, then you need to turn the struts down i.e1/1. But I'm sure curious about the reduction of body lean when you turn it up.
GTMAN
GTMAN is offline   Reply With Quote
Old 11-10-2000, 07:04 PM   #3
gtguy
Member#: 2184
Post
Yes, the ride comfort is better with the stock springs. The problem with the boosters was that they reduced the effective length of the spring. We tried placing them at the base of the spring, since it would have taken far more strength than any of us had to slide that big mother in between the progressive coils!
The boostered Eibachs were stiffer, but at the same time kind of squishy as I explained previously, cuz of that big 'ol hunk of rubber sitting beneath the spring. We thought of the plastic wrap business, but that will probably degrade over time and need a reapplication, even though it seems to make more sense than the boosters.
I talked to Mike Shields, who said that I was the first dissatisfied customer with the Eibach Legacy springs, but that he'd take them back. That guy is aces, and I'll be sure to give him business whenever I can. He knew of no alternatives that would guarantee a 1" drop for my wagon.
The things we quickly get used to...
Kevin
Old 11-10-2000, 07:06 PM   #4
gtguy
Member#: 2184
Post
Hey GTMAN, how the heck come you're a "specialist," when I have one more post than you do?
Kevin
Old 11-10-2000, 10:05 PM   #5
GTMAN
Member#: 480
Talking
From the bright side to the dark side and then back again Well I had a long discussion with Mike S. also when I got my 0.75in.=1.8in drop on the wagon. Humm I was dissatisfied too....but learned to live with it. Went thru all the stress of "what should I do's". Take em out, AGX's going bad, scraping etc........but performance, looks and spending $250 again for install and realignment convinced me to make it all work.
And its been a great learning experience.....worth 10 credit hours!
With the booster, I thought you had used soap and slid it along the coil down? That would have made it easier.....but harder to come out when the soap dries though...but I found a technique though. A real wrist breaker I admit....talk about the cussing, I think I ran out of cuss words just doing the rear only.....had to switch 3 languages too over the 2 hr period
As for the 95 vs 93/94 postings "specialist" title.....I must have been grandfathered in by the old ways, or "they" know I'm on the 1.8in. drop darkside and was not afraid of it.....just kidding .
GTMAN
Old 11-11-2000, 05:48 AM   #6
gumball
Member#: 1209
Post
Hey did anyone talking to Mike Shields ask if more of the Prodrive/Eibach springs for the Legacy would be made? He evidently has one set he's keeping for posterity. It is the true 3/4" drop that he advertises- a couple folks on the board (Akita?) have them. It'll be interesting to see what the Whitelines can do too.
My AGX are broken in some, but I defintely think there's some bounciness at 2F/4R indicative of overdamping w/ the stockers. I'm not complaining though. In DC the roads suck the big one, there's fiber work going on everywhere and stock height is all I can handle.
gumball is offline   Reply With Quote
Old 11-11-2000, 09:03 AM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
So the 3/4" Eibachs are no longer being made?
Damn.
I guess we'll have to wait for the Whiteline results...
DLC is offline   Reply With Quote
Old 11-11-2000, 10:43 AM   #8
gtguy
Member#: 2184
Post
I took her out today for a damned good thrashing, and here's the in-depth report:
Turn in is still exceptionally sharp, although obviously, the lowered car seemed more eager to turn in as a result of its lower gravity center. The stock springs place a premium on smoothness as opposed to the Eibachs, which could be thrashed, contrary to my style but it's a nice option to have. For instance, if rather than carving a nice arc you have to fling the car into a corner for some reason.
Compliance is greatly improved, obviously because I'm not within the ride height that the AGX likes. It feels more plush, and I don't get the extra little jiggles that the too low car gave me over rough pavement, or those low, sharp little bumps. It's less jarring which makes sense, given the softer spring rate.
Front to back stiffness is unchanged, since this is mostly a function of the strut. Laterally now, when you rocked the body with the Eibachs, you got a single, short rebound rock. Now you get a rock and a half. It's still light years better that stock, making me think that the stock dampers are the biggest issue in that regard.
Where I notice the lateral stiffness deterioration (though not a substantial one) is in a corner where you customarily pitch the car in, just to have a bit of fun. You have to wait a hair for the spring to come to terms with the strut's damping and set. This is what I meant earlier by the setup placing a premium on smoothness, which is fine.
But there isn't any crashing or bounding over bumps, and the few potholes that I went looking for were fine. You notice the increased stiffness of the suspension thanks to the AGXs, but I don't have to avoid them now.
There is also still the same well-planted sense of security that was present with the Eibach setup. The missing last tenth of ultimate confidence that comes from the Eibachs pitchability, for lack of a better descriptive, isn't necessarily a bad thing, since it keeps you from being silly with impunity.
There aren't really any signs of over or under damping most importantly. Bumps get you the single, well-controlled rebound instead of the short jounce of overdamped, or big bounce of underdamped.
All in all, it's something I'm able to live quite happily with, until something better comes along. But boy, now that I'm at stock ride height, you can really see how an inch of drop would make the car look sweeet, yet still be within the optimal range of the AGX.
Is there anything I missed? I did this because in musing about the stock springs with the AGX, it occurred to me that nobody had ever done an in-depth ride analysis of the combination. Hope this helps someone.
Once the AGXs break in, I'll see about stiffer settings, though I suspec that is when you would begin to see the symptoms of overdamping...
The Whiteline thing is interesting. Apparently, they also make a wagon-specific spring. The guy at the three-initial place (whose name escapes me, but was cited in a previous post) is checking on it, and will let either Dale at Teague's or I know. He thought that Whiteline made a wagon spring, but wasn't sure about the drop. Anything more than 30mm is bad.
Kevin
Old 11-11-2000, 10:45 AM   #9
gtguy
Member#: 2184
Post
Oops, I meant "withIN the ride height that the AGX likes..."
Kevin
Old 11-11-2000, 02:37 PM   #10
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Smile
Kevin, Thanks for the in-depth report! Soon to be in need of new struts, and having exchanged a few Messages with Jamie about the coil-overs (most prohibitively $$$$$)it looks like we are all waiting to hear more about the White Line product. The possibility of Wagon specific application is especially enticing, as mine often finds itself loaded to the gills for a week of skiing or long trip and the sedan doesn't need to address such loading issues.
Having lowered my 91 Integra 1.75 inches I'm in agreement about the trade-offs involved. I guess Love-Hate would capture it. Speed bumps (urrgh!) and steep driveways versus short sweepers and quick transitions leave one wondering why we can't have it all! Something like the Infinity Q45A comes to mind. With all the advances made in computer power since the demise of that sophisticated-over complicated beast one wonders what FHI could come up with backed by the Mighty General's $$$$$$$
Ah well, just idle musing at this point. Thanks again for the insightful review. When were we to hear from Teague's??
Glenn
nuburu2 is offline   Reply With Quote
Old 11-11-2000, 04:01 PM   #11
gtguy
Member#: 2184
Post
Hey, I received an email from Eibach Friday, with a request to call their Tech line on Monday, so that they could get to the bottom of the big plummet from the Legacy springs.
I was surprised to hear from them so quickly, but fully intend to get to the bottom of the spring problem. Who knows, a wagon-specific set might result, or a Legacy spring that is better able to bear the weight of our cars. Seems to me that almost everyone who installed this kit got way too much drop.
I'll keep everyone posted...
Kevin
Old 11-13-2000, 01:32 PM   #12
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
I noticed you mentioned that you don't have to avoid bumps now like you did when using the Eibach springs. Just for the record, even with my 1.5" drop from the H&R's, I don't have to avoid anything. And this is even with 17*7 wheels with +48mm offset. And now with the FHI dampers the car is better than stock, even over large bumps/dips.
Glad to see Eibach is interested in helping everyone out tho!
Kev www.lagging.com
Force[FED] is offline   Reply With Quote
Old 11-13-2000, 04:04 PM   #13
gtguy
Member#: 2184
Post
This just in from Dale at Teague's...
<<So far the Whiteline springs are working out very well. They drop the car between 3/4 and 1" very mild drop. But the handling is a lot better. The ride is stiffer but not harsh. From what you say you are looking for I would say the Whiteline springs would be exactly what you need. I will be adding them to the web page soon. What year is your Legacy and I will email you back with a price on the set.>>
I believe the term is, "Woo hoo!!"
Kevin
Old 11-13-2000, 04:06 PM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Does anybody know what the curb weights are for the sedan and wagon? I didn't think the wagon was all that much heavier - not enough to justify the suspension dropping 1" more than Eibach said it would.
Pat Olsen
'99 GT sedan (RIP)
Old 11-13-2000, 04:06 PM   #15
gtguy
Member#: 2184
Post
Oh, crap. For some reason it hosed off the email cut and paste. At any rate, Dale says the Whiteline springs are working great, with a mild, 3/4 to 1" drop on his Legacy GT test mule. He says they're stiff but still compliant, and not at all objectionable as regards ride quality.
He's emailing me with a quote tomorrow. I'm optimistic...
Kevin
Old 11-13-2000, 04:18 PM   #16
gtguy
Member#: 2184
Post
Patrick, a quick web search turned up curb weights of 3090 for the sedan, and 3146 for the wagon. You wouldn't think that almost 100 lbs would make that much of a difference... Hmmmm.
Hey, ForceFed. I think the bump avoidance was caused by the KYBs being outside their operating range with the Eibach plummet. I wasn't sure if I should hit 'em hard, so I didn't.
Kevin
Old 11-13-2000, 05:08 PM   #17
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
My 93 Wagon is supposed to be 3300, i'm not so sure the newer ones are lighter, but...
That Whiteline deal sounds encouraging.
Please let me in on the prices...
Old 11-13-2000, 07:10 PM   #18
gtguy
Member#: 2184
Post
Hmmmm. Different numbers, but the word from AutoVantage for curb weights is GT sedan: 2885; GT wagon, 2975. I still say that the extra weight shouldn't make that much difference. Cars don't drop that much when we have passengers, who weigh far more than the under 100-lb difference, so what the dilly-o?
Kevin
Old 11-13-2000, 10:57 PM   #19
Velocity
Member#: 2205
1998 Legacy L Wagon
Deep Sapphire Blue
Post
gtguy: Wow, that's the first time I've ever heard somebody state the weight of the Legacy GT models as sub 3k lbs.... Maybe dry weight, but I am rather skeptical about that figure with fluids and a passenger...
Anyhow, I completely agree with you--there really isn't any way 100 lbs would make a spring drop another inch, unless that spring is a defect (wrong rate), or maybe some kind of progressive spring. I dunno... Seems really weird to me.
But what do I care, I'll be picking up the H&R/FHI combo soon.
Velocity is offline   Reply With Quote
Old 11-14-2000, 12:21 AM   #20
gtguy
Member#: 2184
Post
The chat with Eibach was rather fruitless. They confirmed what I already knew, which was that the heavier weight of the wagon contributed to the excessive drop. They have no plans as far as Tech was aware, to do anything wagon-specific, so there.
That was pretty much it. So now I ship some springs back, and await word about a solution to my mild drop. Perhaps I'll put on an anti-lift kit while I'm being patient.
Kevin
Old 11-14-2000, 05:58 AM   #21
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
gtguy,
Did Dale have anything to say about the wagon vs sedan issue? Which is he trying out the White Line springs on, I assume the sedan?
Old 11-14-2000, 06:16 AM   #22
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
He's got a 95ish FWD Sedan that he uses for auto-x'ing.
I can't wait to hear some definitive results about these.
Old 11-14-2000, 08:12 AM   #23
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
I agree!! If the price is right this sounds ideal. Funny, just looking thru owner's manual last night and found that the GT has .5 in more clearance than the non GT Wagon. Tires and rims ? With 6.5 in of clearance B4 mods one wouldn't think that a 1.5 in drop would be that extreme. Must admit though that near stock ride height with flatter cornering attitude is mighty attractive!
Glenn
Another question arises after my perusal of the manual though. Has anyone with a GT found themselves needing to install chains in snow country? The manual says no can do, and I was wondering if anyone found themselves stuck or turning around and going home. I've had 2 AWD Subies and never needed the chains but always carried a pair of HD V-Bars just in case. I'd feel strange heading for Tahoe without the insurance policy. Any comments or experience?
Old 11-14-2000, 09:36 AM   #24
bobski
Member#: 413
2006 VF-39 WRX Wagon
Post
Glenn,
I've never had any problems in the Sierras with either my wife's Outback or my GT. Although I do carry chains in the Outback, I've never had to use chains on any of the Subarus. This is through 4 ski seasons since I've started owning Subarus. As long as you have AWD and M+S tires, Caltrans will let you through. Caltrans will usually close the road if it gets bad enough to require chains on all vehicles.
Bob
bobski is offline   Reply With Quote
Old 11-14-2000, 09:31 PM   #25
GTMAN
Member#: 480
Wink
I guess there is one way to find out. gtguy, you mission is to try out the whitelines and compare them with the eibach's! We have to know the truth...its out there and you need to bring it here.
Note: Even the largest dips that I have taken have not bottomed out the AGX's (knock on wood). Infact its like a roller coaster ride. It follows the contour of the dip like on rails. The downward G-force sensation is sweet especially your blasting thru...like it has vacuum suction fans under the car like the McLaren F1. Not at all like normal cars that 747 over the dip and gradually lower you down on a pillow. Its like goin F16 on the road!
Keep us posted.
GTMAN
PS: Eibach's response on the weight was a good joke. I know a few people on the board that got the same drop with GT sedans.
Stock struts, Top hats, KYB AGX struts,& springs smokeone954 Suspension/Brakes/Handling 47 04-11-2010 04:57 PM
FS: KYB AGX+kg/mm springs+stock top hats for 98-01 impreza Solar VIC Private Classifieds 12 03-11-2008 12:36 AM
Will it be fine to do KYB AGXs with stock RS springs? rites Brakes, Steering & Suspension 1 09-10-2005 06:56 PM
KYB AGXs w/Prodrive Springs Compared to Stock MissMyStook Brakes, Steering & Suspension 4 02-18-2005 06:25 PM
Does anyone have KYB/AGX with stock springs? nukeyfish Brakes, Steering & Suspension 9 08-22-2002 06:34 PM
