Old 03-13-2006, 07:44 PM   #1
Johnnypoofies
Member#: 107755
Default Vf 22 Question and utec
I am Looking for a utec map for my vf 22 i only see v34 setups
Johnnypoofies is offline   Reply With Quote
Old 03-14-2006, 03:54 AM   #2
Bolster
Member#: 22290
2002 WRB WRX Wagon
I used the VF34 map for mine and then altered it and had it tuned. I don't have a copy of the map, but it wasn't too hard to start on the VF34 map and make the appropriate changes.
Bolster is offline   Reply With Quote
Old 03-14-2006, 05:23 AM   #3
wrx13oy
Member#: 60529
2002 PSM Bugeye stg6
07 Kawasaki ZX6R
just take the stage 4 vf34 map and take off a few degrees of timing and your good to go. then just get a tune in the future
wrx13oy is offline   Reply With Quote
Old 03-14-2006, 09:06 AM   #4
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
Why would you pull timing?
BadTrip is offline   Reply With Quote
Old 03-14-2006, 10:05 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
timing is not a knob for power.
when you put on a more efficient turbo, or run higher boost, the charge in the chamber becomes more dense.
a denser charge literally lights off faster than a more rarified one. in other words, you need less advance to ensure that the max chamber pressure occurs at 15* atdc.
if you DON'T change the advance, then you may find yourself running into knock for the very same reasons: the motor is both tolerating and requiring less advance to achive minimum best timing.
hth
ken
Old 03-15-2006, 11:50 AM   #6
mtxfrk2k1
Member#: 103401
2005 WRX
where can i get this vf34 or vf22 map. i need a vf22
mtxfrk2k1 is offline   Reply With Quote
Old 03-24-2006, 03:09 PM   #7
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
hth
ken
I have much to learn Master Ride5000. Thank you for the info/education.
Old 03-24-2006, 03:09 PM   #8
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
Bump for a 22 map
Old 03-30-2006, 10:48 AM   #9
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
double bump
Old 03-30-2006, 02:11 PM   #10
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
There is no need to bump, just use the 34/30 map and customize from there. Those turbos are VERY similar (I've had both).
TypeC is offline   Reply With Quote
VF 22 question? stealthydrew Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-20-2006 11:19 AM
VF 22 question gizmodude311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 04-01-2006 02:04 PM
VF-22 question IRON_REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-20-2005 04:47 PM
VF-22 Question carguy19 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-01-2004 10:31 AM
vf-22 map for utec jbogli Engine Management & Tuning 2 07-27-2003 09:11 AM
