Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-13-2006, 08:50 PM   #1
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
Default When UTEC detects knock?
I had a question on how the UTEC detects knock. Does it detect knock all the time but only correct it when the UTEC is running timing? I'm wondering if I'm getting knock when the ECU has control of the timing. Will the UTEC's logs see a knock (take a knock count) under ECU control and do nothing about it? Or when ECU has control ignore knock totally, detection and reaction?
For instance if I knock at 2000rpm in the 0% load column just cruising down the highway with ECU controlling timing/fuel/boost will I see it in my Knock count column of the #1 log?
Thanks
Travis
TravisSTi is offline   Reply With Quote
Old 03-14-2006, 10:35 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Thanks
Travis
travis,
the utec is always "listening" for knock. it will flash the CEL and display the severity of the knock in the logs whenever the knock signal exceeds your programmed thresholds.
however, it will only pull timing if it is in control of timing. ie, you must be above your TPS threshold, AND you must not have ECU in your timing map for the load cell active when the knock was sensed.
hth
ken
Old 03-14-2006, 11:52 AM   #3
Freon
Member#: 88322
2009 BMW 135i
I do believe if you get knock when the UTEC is in control, it will still affect your IAM if that is what you are asking. I don't think the UTEC cuts off the signal to the ECU at any time. While the UTEC won't "tell" the ECU to pull timing, the ECU is always listening and deciding for itself how good your gas and tune are.
The ECU and UTEC handle knock differently. The UTEC has some sort of threshold and does it by count. The ECU does it by voltage level. They can and will disagree about knock events.
If you look at your logs and you get a good 3 count according to your UTEC, you will see the "ECU Ign#1" timing also goes down. It is clearly reacting to the same knock even when the UTEC is in open loop. Again, they sometimes disagree especially on 0 and 1 counts, but they almost always agree on the bigger counts.
Freon is offline   Reply With Quote
Old 03-14-2006, 01:28 PM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
to add to what freon points out, the utec may pick up events that the oem ecu does not. actually, from my experience, it SHOULD if the thresholds are set properly. i actually use that disparity to determine the severity of the knock--if the utec sees it and the oem ecu doesn't, then it was pretty low level.
Detecting knock at 6000rpms. 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 12-03-2007 05:33 PM
Will utec log knock events in log when not in control? MAP 0 NITROS UTEC 1 08-21-2007 10:55 AM
Cel on. Will utec detect knock? dddnuts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-29-2004 07:32 PM
How does the UTEC retard timing when it detects knock? QA Guy Engine Management & Tuning 18 07-03-2003 02:35 PM
UTEC engine knocking when cold WRXOwner7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-29-2002 08:10 PM
