Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 03-13-2006, 09:25 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default JDM Container - All Cusco back in stock! STi, Helix, Endless, Zeal, etc.
Cusco!
Cusco Type OS Strut Tower Bar - 02+ WRX / 04+ STi
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. Cusco Type-OS improve chassis rigidity and reduce this flex. Lightweight aluminum and high rigidity oval sectioned pipe used.
$150 shipped for Front
$150 shipped for Rear
$290 shipped for Both
Cusco Type OS-T Triangle Brace - Rear - 02+ WRX / 04+ STi
*Only includes the triangle brace, not the rear strut tower bar.
$125 shipped
$265 shipped w/ Type OS Rear Bar (as pictured below)
Cusco Type OS Strut Tower Bar and Triangle Brace - Front and Rear Combo - 02+ WRX / 04+ STi
$410 shipped
Cusco Pillowball Upper Mounts - 02+ WRX / 04+ STi
-Designed to work with your stock struts.
-The full pillowball design controls unwanted forces under acceleration and braking. Stable steering response in essense and lane changing improved stability over bumps and holds roll in corners. Enables linear handling and keeps you on the record line better. Stability and safety during turn-ins and under braking. Camber adjustable by sliding the plate and pillowball sections.
$219 shipped for Front
$219 shipped for Rear!!!
$419 shipped for F and R!!!
Cusco Sway Bars - 22mm F / R - 04+ STi
-The addition of stiffer swaybars properly distributes cornering forces by reducing lateral sway applying increased cornering force on the outside wheel and will ultimately increase vehicle turning characteristics. The rear sway bar will promote rotation at the rear of the car, while the front sway bar will promote rotation at the front of the car.
$155 shipped for Front!!!
$155 shipped for Rear!!!
$300 shipped for Both!!!
$239 shipped for Rear with Helix STi Rear Endlinks (Full Pillowball) - 04+ STi
$384 shipped for Both with Helix STi Rear Endlinks (Full Pillowball) - 04+ STi
Cusco Sway Bars - 21mm F / 22mm R - 02+ WRX
$239 shipped for Rear with Helix WRX Rear Endlinks (Full Pillowball) - 02+ WRX
$265 shipped for Front with Perrin WRX Front Endlinks (Full Pillowball) - 02+ WRX
$494 shipped for Both with Perrin WRX Front Endlinks and Helix Rear Endlinks - 02+ WRX
Cusco V2 Lower Arm Bar - 02+ WRX / 04+ STi
-The purpose of the Cusco lower arm bar is to reduce alinement flexing and improve body rigidity. The lateral arm improves body and rigidity by connecting at the lower arm points. Thus preventing body flex and therefore dramatically improving steering, throttle response and traction. The Version II Bar mounts by multiple bolts and the lateral and foe aft rigidity is greatly increased over Version I.
$150 shipped!!!
Cusco Rear Suframe Brace and STi Rear Diffuser- 02+ WRX / 04+ STi
-Rear subframe brace is designed specifically for STi rear diffuser.
-Allows easy installation of 06 STi rear diffuser on 02-05 MYs.
-Stiffens chasis resulting in crisper vehicle dynamics and improved handling.
$249 shipped
STi items:
STi Pink Springs - 04+WRX/STi
-Designed by STi to work with your stock Struts
-Doesn't lower your car too much: -.5" all around for STi, -1" all around for WRX.
-Will retain excellent ride quality while lowering car's center of gravity for increased handling prowess.
-Spring rates: Front: 258 lbs/in; Rear: 218 lbs/in
$379 shipped!!!
STi Group-N Strut Top Mounts - 04+ WRX / 04+ STi
-Stronger version of the stock style upper mounts. Hardened material increases suspension response by reducing flexing and camber changes. Good intermediate modification to maintain streetability over full-blown metal pillowball upper mounts. Easy bolt-on installation with no modifications necessary.
*Front Strut Top Mounts will work for all WRX model years.
$110 shipped for front!!!
$185 shipped for rear!!!
$279 shipped for F and R!!!
STi Group-N Strut Top Mounts and STi Pink Spring Combo - 04+ WRX / 04+ STi
$639 shipped!!!
Thanks,
Preston
Phone: (510) 783-5300
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Preston
Price including shipping: $XXXX
Shipping address.
Gruppe-S is offline
Old 03-13-2006, 09:40 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Helix DNA Coilvers - 02+ WRX / 04 STI ONLY - $999 SHIPPED
-One of the best bang for the buck coilovers on the market
- 8/6 kg/mm spring rates.
- Exclusively matched valving
- Independently height adjustable lower bracket
- 16 way dampening adjustable
- Light aluminum Shock Body
- Camber Adjustable, Full Pillowballs in the Front
- Currently 04 STi fitment only
- Excellent balance between street and track coilver
- Fully rebuildable
- Custom spring rates available for additional cost
Endlinks:
Helix Endlinks (Full Pillowball)
Helix Solid Endlinks are CNC machined from high strength aluminum. This makes an excellent replacement for your factory plastic endlinks which tend to twist and bend upon corner-loading. The addition of Helix Solid Endlinks significantly increases cornering response and tightness, regardless of the use of an aftermarket sway bar or not. The use of spherical bearings allows for a much wider range of angular movement and eliminates the squeaking and creaking associated with the deterioration of rubber or urethane bushings. The spherical bearings are teflon coated to prevent dirt and debris from fouling movement.
$99 shipped for WRX Rear!!!
$99 shipped for STi Rear!!!
STi Replica Strut Tower Bars - 02+ WRX / 04+ STi
$75 Shipped for Front
$60 Shipped for Rear
$125 Shipped for Both
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. These STi Replica Strutbars improve chassis rigidity and reduce this flex. By using a monocoque aluminum tube shaft, high strength and rigidity are obtained without unnecessary weight gain.
Brakes:
Porterfield R4-S Brake Pads (carbon kevlar), 04+ STi, F/R
These pads are a good balance between race pads and street pads. The Porterfield R4-S’ are unique because they’ll withstand 20 minutes of track time with no fade (they so not fade at temperatures up to 1,100 degrees F) but at the same time, they will work fine when cold and they’re very rotor friendly (as well as being very slow wearing). The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. The R4-S compound also has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brakes material.
Good for autocrossing, drivers schools, weekend track sessions, solo events, and rallys.
$199 shipped for F, $269 shipped for F and R!!!
Goodridge Stainless Steel Brakelines
$115 shipped!!!
-Improves pedal feel
-Gets rid of unwanted line flex
-More durable than stock
Brembo Sport Replacement Rotors (Drilled or Slotted) - F/R - 04 STi only
~Brembo Sport slotted brake rotors are for drivers who want to improve the
looks and performance of their vehicle's original braking system without
having to change additional brake components.
~Brembo Sport slotted and drilled brake rotors provide excellent stopping
power in everyday traffic, as well as high performance street and track
driving.
~Brembo Sport slotted brake rotors match the vehicle's original equipment
rotor's dimensions and are fully compatible with its hubs, brake calipers
and road wheels.
$394 shipped for F, $375 shipped for R!!!
OK, now for the packages:
04 STi Front:
1) Porterfield R4-S Pads F, Brembo rotors F, Goodridge SS lines F+R: $675 shipped!!!
2) Endless SSS Pads F, Brembo rotors F, Goodridge SS lines F+R: $655 shipped!!!
3) Porterfield R4-S Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1110 shipped!!!
4) Endless SSS Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1180 shipped!!!
Special Brake Packages for the WRX:
Gruppe-S finally carrys Motul Fluid! People have been asking for some cheap effective brake combos for their WRXs for quite some time now. This is the most cost effective way to improve your brakes.
Porterfield R4S Pads + Goodridge SS Lines + Motul RBF600 Fluid
*The Goodridge Stainless Steel Brake Lines will improve your pedal feel and stop unwanted line flex at high temp.
*The Porterfield R4S Carbon Kevlar Brake Pads have a superior coefficient of friction compared to the stock pads and have excellent fade characteristics. They'll take 20 minutes of weekend track time for beginner to intermediate drivers with no ill effects
*2 Pints of Motul RBF600 Brake Fluid are more than enough to flush your entire brake system. This is some of the best brake fluid out there (DOT4) and is track worthy stuff.
All 4 Corners for 02 WRX - $299 Shipped
All 4 Corners for 03+ WRX - $319 Shipped
If there's a package that you'd like and it's not listed, please don't hesitate to ask for pricing.
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
Gruppe-S is offline
Old 03-13-2006, 09:50 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Legacy items in stock and ready to ship!!!
Endless SSS Pads, F+R, Goodridge SS Lines, and 1L Motul Brakefluid - $535 shipped!
These are an ideal pad for the spirited street driver. They'll even work for 20 minutes of track time. They're low dust, quiet, and rotor friendly. The lines will increase pedal by stopping unwanted flex and Motul Brake Fluid is some of the best that you can buy. An awesome package for an agressive street driver or a beginner to intermediate track driver.
STi Pink Springs - 05 Legacy GT, Sedan/Wagon - $379 shipped
These can be used with your stock struts and will lower your car 15mm. Expect better handling as a result of lowered center of gravity and stiffer springs rates.
STi Front Strut Tower Bar - 05 Legacy GT, Sedan/Wagon - $255 shipped
Cusco Type OS Front Strut Tower Bar - 05 Legacy GT, Sedan/Wagon - $150 shipped
Cusco Sway Bars - 05 Legacy GT, Sedan/Wagon -
$190 shipped for Rear
$325 shipped for Both
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
Gruppe-S is offline
Old 03-13-2006, 10:10 PM   #4
BoostinEJ20
Member Sales Rating: (14)
Member#: 73710
ordered cusco rsb 02+ WRX and helix rear endlinks! WOOT!
BoostinEJ20 is offline
Old 03-14-2006, 03:29 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thank you for your order!
Gruppe-S is offline
Old 03-14-2006, 04:37 PM   #6
BoostinEJ20
Member#: 73710
woot for fast shipping, thanks guys!
Old 03-20-2006, 10:52 AM   #7
BoostMonster
Member#: 78224
2004 STI
Question
How hard is it to get the helix dna's rebulit? Do they have to be sent overseas or are they done here in the states?
BoostMonster is offline
Old 03-20-2006, 03:15 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
The complete set can be rebuilt in the states for about $400 (for normal wear and tear).
Thanks,
Geoff
Gruppe-S is offline
Closed Thread
JDM Rain Visors are back in stock! Edo Performance SCIC Vendor Classifieds 16 11-24-2009 02:47 PM
Engines Back In Stock! VF34-Helix DP-Gruppe-S Manifold-Turbo Back Combos-Free Dampers Gruppe-S Engine/Power/Exhaust 35 10-08-2007 09:34 PM
Exterior Replica items back in stock, STi, Chargespeed too! Gruppe-S Exterior/Styling 41 06-03-2006 06:51 PM
Cusco back in stock. STi, Endless, Porterfield, Brembo items. Legacy Parts too! Gruppe-S Suspension/Brakes/Handling 10 01-28-2006 07:06 PM
All Cusco back in stock! Sway bars and Strut bars! GNV Motorsports Suspension/Brakes/Handling 27 06-21-2005 01:10 PM
