Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 09-27-2001, 12:03 PM   #1
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
Question What does the purge control solenoid do?
As the topic ask, what is the purpose of this solenoid?. Reason why I am asking is I broke the outlet that one of the tubes attaches to, the one going to the manfold vac line. I am just wondering what effect will it have if I just leave it like that. If anyone knows I appreciate the knowledge.
MadMax
MadMax is offline   Reply With Quote
Old 09-27-2001, 12:55 PM   #2
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
I did the same thing and wound up buying a new one from Sugar for about $100 or so. It purges the charcoal canister I think; I had a vacuum leak until I replaced the solenoid (I couldn't get glue to work) but I'm not sure the overall affect on driveability, as I had other issues at the time. Since it's fuel system related I would err on the side of caution and replace it. Just my 2c.
Ryan
RyanC is offline   Reply With Quote
Old 09-27-2001, 12:59 PM   #3
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
What a pain in the arse. I think I will just take it out and try one more time to properly glue the thing. Anyone else have an idea on its function.
MadMax
Old 09-27-2001, 01:29 PM   #4
RS'ted
Member#: 3234
If you're intent on fixing it, I would rough up the surface a bit and repair with epoxy. I have one type that comes in stick form, you just slice off a piece and knead it to mix in the catalyst. That stuff is incredibly strong, cures in about 5 minutes, and has a thick enough consistency to hold the parts in place while setting up.
Ken M
RS'ted is offline   Reply With Quote
Old 09-27-2001, 02:54 PM   #5
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
What are the steps of taking it off?
MadMax
Old 09-27-2001, 04:50 PM   #6
RS'ted
Member#: 3234
You installed a TEC-II and a intercooled SC and you can't get that little valve off ? IIRC, there is just one bolt holding it on under the firewall side of the intake manifold. Go Fish !
Ken M
Old 09-27-2001, 04:51 PM   #7
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
Ken M
hahaha
I was just checking, lol.
tough crowd today.
MadMax
Old 09-27-2001, 09:26 PM   #8
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
The fuel vapors from the fuel tank collect in the charcoal canister. At cruising speed, with a low load on the motor, the purge valve will open and the motor will suck the vapors from the canister. If you leave the line off long enough the ECU might see a leak in the purge system, and you might get a check engine light on. Make sure you plug the end going to the intake manifold or you'll have a pretty good vaccum leak.
LVSUBARU is offline   Reply With Quote
Getting rid of the Purge Control Solenoid olivertwisto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-17-2011 08:43 PM
What does the ignition controll module do? zakats Electrical & Lighting 2 08-03-2004 09:06 AM
What does the metal brake clips do? twlai Brakes, Steering & Suspension 6 10-22-2002 02:06 AM
