Old 03-14-2006, 08:15 AM   #1
ljaviation
Member#: 42270
2003 A&P IA
ww.flyingleafaviation.com
Default WRX strut assemblies in a 92 Legacy wagon
Does any one know if '02-'03 WRX strut assemblies will fit an older Legacy wagon. A friend of mine has an older 92 LSi wagon with air ride height and needs struts bad, but doesn't want to spend the $300+ per strut.
Just wondering if anyone has tried this or has any info. I am aware that the air ride height would have to be disconnected.
Thanks,
L J
ljaviation is offline   Reply With Quote
Old 03-14-2006, 08:54 AM   #2
subarurabbit
Member#: 4083
2011 OB 3.6R
why not go with "regular" gr-2 or AGX?
subarurabbit is offline   Reply With Quote
Old 03-14-2006, 10:05 AM   #3
ljaviation
Member#: 42270
2003 A&P IA
More info..
I was wondering if WRX takeoffs,... springs, tophats and all, will physically fit.
Buying the non airride struts is ok, but if I have to buy springs, tophats, ect, to make it work, the cost difference with time involved may not be as cost effective.
Old 03-14-2006, 10:10 AM   #4
snowjob
Member#: 59357
2009 Forester XT
They Work fine, I had 2004 WRX suspension(read: strut hophat and spring) in my 91. The front tophat fits fine but you need to extend the holes in the rear to use the wrx rear tophats, if you do not want to do this just use the tophats from a 92.
You will also need to add a thick washer to the top of the rear tophats so the nut on the top of the strut will be tight, if not it bang bang bang.
Here is a pic of mine, it lowers it a bit, but not bad at all
snowjob is offline   Reply With Quote
Old 03-14-2006, 01:53 PM   #5
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
extend holes- what do you mean. can you explain? i am severly interested in rear tophat fitament from GDB->gc8
h
swapstar is offline   Reply With Quote
Old 03-15-2006, 08:36 PM   #6
snowjob
Member#: 59357
2009 Forester XT
If you go from a bc/bf legacy to a GD tophad the holes are about 5MM wider in each direction and you need to extend the bolt holes in the rear.
Old 03-16-2006, 12:19 AM   #7
ljaviation
Member#: 42270
2003 A&P IA
Thanks for the reply.
L J
FS chicago/skokie: 92 Legacy wagon internetautomart MWSOC Private Classifieds 0 05-31-2007 03:34 PM
will 02wrx struts and springs fit in a 92 legacy? wrxburton Brakes, Steering & Suspension 1 03-10-2007 04:17 PM
FS: 02+ WRX Strut Assemblies w/ Eibach Springs in OC, CA msv Private 'For Sale' Classifieds 4 09-17-2005 08:03 PM
Impressions of a 92 Legacy wagon Turbo Miker General Community 9 04-20-2005 04:31 PM
Impressions of 92 Legacy Wagon Turbo? Miker Legacy Forum 2 04-18-2005 06:31 PM
