Old 03-14-2006, 08:47 AM   #1
dug-e-fresh
Member Sales Rating: (4)
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Default Driveshaftshop WRX Driveshaft & GTSpec Subframe Install
Driveshaftshop WRX Driveshaft:
1st thought was this is a big son-ova-beech. Because its aluminum it has to be... its definitely considerably lighter. Fitment was a non-issue EXCEPT for 3 clearance issues due to the diameter of the shaft:
Clearance issue 1 & 2:
Solution to Clearance Issue 1 & 2:
The hammer is always victorious:
Clearance issue 3:
Solution to Clearance Issue 3:
Unbolt and remove clamp:
Re-install clamp and refasten:
Overall, it was a fun install and went pretty smoothly/easily. I had no balance issues or vibrations post install... the car drove virtually the same and I took it to various rpms/mph combinations from idle to 8k, 1 mph to 120 mph. I will climb under and inspect in a few days.
dug-e-fresh is offline   Reply With Quote
Old 03-14-2006, 08:47 AM   #2
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
GTSpec Subframe Install:
They are beauties-
Too bad they are under the car... and yes I need a new swaybar, lol!
Not much to say other than the driver side piece needed two washers on the back bolt for spacing (bolt just above "20" in "2006" in the pic). And the passenger side piece is not compatible with the O2 location of the TXS bellmouth downpipe. Easy fix... just have another bung welded in.
Easy install... excellent fit and finish... one heck of a piece of work... highly recommended.
Both mods get 2 thumbs up Better stronger lighter... how can they be wrong?
Special thanks to Andrewtech and James for getting the shaft to me so quickly and at a good deal... to MTS (Maryland Turbo Solutions, marylandturbo.com) for getting me lift-time on short notice for the install and a deal on the GTSpec subframes, too. Thanks Rob!
def
Old 03-14-2006, 11:07 AM   #3
D-Speed 2.5
Member Sales Rating: (2)
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Do you feel a noticeable difference with those braces? The underside of your car is really blingin!
D-Speed 2.5 is offline   Reply With Quote
Old 03-14-2006, 01:04 PM   #4
Unabomber
👌 Big Ron 👌
Member Sales Rating: (11)
Member#: 18062
on car parts so PM
me b4 j00 buy
Nice review!
P.S. Your front sway bar called.....it wants to be powder coated.
Old 03-14-2006, 01:16 PM   #5
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Originally Posted by Unabomber
Nice review!
It WAS powdercoated!! Damn Whiteline bar...
def
Old 03-14-2006, 01:22 PM   #6
WRblue'02
Member#: 15667
2004 STi
Alpine White
I got severe vibration from my Driveshaft Shop aluminum driveshaft from about 60-65mph. That was on an 04 STI, though.
Have you had any issues with vibration?
WRblue'02 is offline   Reply With Quote
Old 03-14-2006, 02:03 PM   #7
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
As posted....
def
Old 03-15-2006, 02:24 AM   #8
WRXRallyBlue
Member Sales Rating: (10)
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Sweet
WRXRallyBlue is offline   Reply With Quote
Old 03-15-2006, 09:53 AM   #9
Snitt
Member Sales Rating: (1)
Member#: 36361
2016 Golf R
Lapiz Blue
I've often wondered if the lightened driveshaft was worth it, and I'm glad to see someone went out and installed one. Are you saying that the car still feels the same after installing it? :O
Snitt is offline   Reply With Quote
Old 03-15-2006, 12:05 PM   #10
WRblue'02
Member#: 15667
2004 STi
Alpine White
As posted....
def
Oops, sorry I missed that point. I'm glad it is working out for you.
Old 04-27-2006, 12:42 PM   #11
x99percent
Member Sales Rating: (3)
Member#: 27108
2004 STi
2004 A4
Any new impressions from the driveshaft?
x99percent is offline   Reply With Quote
Old 04-27-2006, 02:19 PM   #12
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Well... I am waiting to here back about some things 1st... I'll update soon.
def
Old 04-30-2006, 02:58 AM   #13
DONAUDI
Member#: 71639
2004 STI
The main reason i was considering the one piece driveshaft was to eliminate the drivetrain slop. The carrier bearing is soft and seems to flex quite a bit. Did you gain any more of a solid feeling from this mod?
DONAUDI is offline   Reply With Quote
Old 05-01-2006, 03:41 PM   #14
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
neanderthal blackout
subscribed
MeetMrGlock is offline   Reply With Quote
Old 05-01-2006, 03:44 PM   #15
thahaminator
Member Sales Rating: (20)
Member#: 22738
I have one being made for me right now so Ill post a review in a few weeks.
thahaminator is offline   Reply With Quote
Old 05-01-2006, 04:34 PM   #16
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
I'd say, yes, drivetrain slop is diminished.
Again... I will post more soon.
def
Old 05-03-2006, 12:39 PM   #17
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
How much do one of these things weigh?
breathinez is offline   Reply With Quote
Old 05-03-2006, 12:55 PM   #18
x99percent
Member#: 27108
2004 STi
2004 A4
Old 05-05-2006, 03:12 PM   #19
InfamousDX
Member Sales Rating: (184)
Member#: 25413
Glad to see it's worked out for you Doug, the DS that is. Another friend installed one on his WRX and it vibrated. man I'm torn as to whether or not to get it.
Old 05-05-2006, 03:34 PM   #20
c'dalerider
Member Sales Rating: (29)
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
I do not have vibration but i still have rubbing upon hard right or left turns at low speed. Also, at high speeds, letting off the gas the trany twists and i get rubbing. I NEED new, hardend trany mounts but noone makes auto trany mounts so i have do diy mod.
My friend Andy/Xotic also installed his and had better success. We both noticed overall improvments as formentioned in this post.
c'dalerider is offline   Reply With Quote
Old 05-05-2006, 04:15 PM   #21
gswrx
Member#: 44701
I have no problems with mine but I did cut out a chunk out of the floor area. I do rev up a lot faster.
G
gswrx is offline   Reply With Quote
Old 05-05-2006, 06:06 PM   #22
Poweredbysnail
Member Sales Rating: (14)
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
I heard that a one piece drive shaft will put a load on your rear seal on your tranny and will cause it to leak. Any info on this would be great I want to get one for my car to go with my 6 speed.
Poweredbysnail is offline   Reply With Quote
Old 05-05-2006, 06:25 PM   #23
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Ok... so here's the scoop:
My shaft was PERFECT... not a single grind, vibration or ANYTHING of that matter to complain about.... well, until I hit 130+ mph anyway.
At this point the most awful grinding/vibration came from under the car... near the rear. Now mind you these speeds are what I see when running the quartermile. I keep into just past the traps...
Upon inspection, I found that the driveshaft was hitting the rear diff carrier which ground a 1/4" wide 1/8" deep groove into the shaft.
This area had been modified. A LOT of material had been removed and the clearance there should have been enough that there should not have been an issue.
Anyway... I was told to rotate the shaft 90 degrees to see if this made the problem go away.
I have 2 problems with that... 1) the shaft I have now is damaged, and 2) testing this would require another journey to 130+ mph (with a damaged shaft that MIGHT become more damaged).... not something you just do for the heck of it, especially when you are looking for a problem... any problem let alone a problem with a 12 pound 4 ft long aluminum shaft spinning just below and behind me at REDICULOUS rpm.
So... needless to say, they are sending me a new one. I am swapping in the new shaft soon... installing a new clutch and then heading back to the track. Hopefully I will have no further issues.
That is all.
def
Old 05-06-2006, 05:21 PM   #24
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Hopefully it works out for you. Afterall, if we don't get 10.9 out of that sz49.. Well, if you value your knees, it'll happen. Know what I mean?
Old 05-07-2006, 12:21 PM   #25
c'dalerider
Member#: 92388
04 WRX, 06 STI
omg, you got them to send you a new shaft. nice. mine is def chewed up alittle bit but i feel itwill be ok. But i certainly have the same concerns as you. i hope its not a time bomb and did not make the shaft weaker in any way. I dont think it did and after i put some tranymounts in it should be fine.
Driveshaftshop WRX Driveshaft djerickd Car Part Reviews 37 04-25-2009 10:18 PM
VA: DriveShaftShop, alluminum driveshaft Rexxyou Drivetrain 5 04-06-2009 09:21 PM
Gtspec Subframe richy_21 Brakes, Steering & Suspension 3 10-26-2008 01:50 AM
FS: GTSPEC subframe reinforcement braces, trunk cage, midframe reinformcement subynooby RMIC Private Classifieds 3 04-22-2007 12:53 PM
WRX axleback & Stromung mid: Installed! Siper2 Mid Atlantic Impreza Club -- MAIC 10 03-17-2005 09:13 AM
