Old 03-14-2006, 11:28 AM   #1
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Default 2.5L STI shortblock on JDM heads and ECU?
So it looks like my JDM block is a gonerhttp://forums.nasioc.com/forums/showthread.php?t=960763 and I am going to have to find a replacement. Ideally I would like to not spend a lot of money on it. A used JDM shortblock in good condition would be my first option. With that not being available, I've started to look at 2.5L STI shortblocks... They cost less than a new JDM empty block and supposedly heads will bolt right up to it. Now, the problem is that I am stuck with my stock JDM engine management and its 8000RPM redline. For all practical purposes my ECU is NOT reflasheable and I can not afford any kind of standalone right now.
So, the question is... Would it run safely? Am I going to get detonation from the 8.7-1 compression and the JDM ignition timing? Will the block fly apart at 8000RPMs? Is this a stupid idea?
Thanks!
powerlabs is offline   Reply With Quote
Old 03-14-2006, 12:35 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
(no em) no probbaly not
(det/timing)yup that is probbaly why it died to begin with
(8000k)yup way fast piston speeds
i responded simmilary to your other post too
have you talked to lachutte about flash 99?
Old 03-14-2006, 07:07 PM   #3
powerlabs
Member#: 45790
SUPERCHARGED
Not yet. Lachutte is a good 20+ hour drive for me, and the trip + the cost of the reflash is more than I could afford
Old 03-14-2006, 07:21 PM   #4
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Fast piston speeds? There are a ton of long stroke cars that have much faster piston speeds. Most high rpm trouble is oiling related, not easily fixed but more pressure can help. I say try it, I would like to know if it works
Scoobie Steve is offline   Reply With Quote
2.5L Sti Shortblock with 2.0 L WRX heads - Need STi Dipstick? skimobile Built Motor Discussion 5 06-13-2007 08:53 PM
2.5L crawford shortblock on 2.0L 2004 WRX heads mistaboosta Built Motor Discussion 11 04-05-2006 06:27 PM
USDM 2.5L STi shortblock vs EJ22T Shortblock yellowscooby New England Impreza Club Forum -- NESIC 13 07-25-2005 08:23 AM
New 2.5l STi shortblock with 2.0l WRX heads? neversatisfied Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 65 06-01-2005 12:33 PM
FS MD: 2.5L STi Shortblock, 2.5L Gasket Kit, STi Pinks (565CC) bryan carbon Private 'For Sale' Classifieds 3 01-27-2004 10:37 PM
