Old 03-14-2006, 04:05 PM   #1
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
Default Can I spray brake cleaner without removing the brakes?
Yeah Yeah...I'm not gonna apply it and then try to run a road course.
Our SUV makes a squeaking sound when braking at times, and the pads were replaced and the rotors turned just last summer.
Can I apply brake cleaner to the rotors without removing the wheels, etc and just wipe dry and let it sit for a bit, then drive around the block a time or two to get them fully dry?
I just want to get rid of the stupid squeal because it sounds like the brakes are bad and they aren't.
-=C=- is offline   Reply With Quote
Old 03-14-2006, 04:06 PM   #2
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
absolutely
Stealthbmbr is offline   Reply With Quote
Old 03-14-2006, 04:11 PM   #3
fliz
Member#: 30342
No need to wipe. Brake cleaner evaporates.
Chances of it fixing the squealing are slim to none, however.
fliz is online now   Reply With Quote
Old 03-14-2006, 04:16 PM   #4
-=C=-
Member#: 7719
99 F-150 crew cab
well, any recommendations?
Old 03-14-2006, 04:18 PM   #5
fliz
Member#: 30342
Nope. I just live with squeaks, I can't fix them.
Old 03-14-2006, 04:20 PM   #6
alacrity024
Review Crew
Member#: 49476
yeah get some "Disc Brake Quiet" goop from the local auto parts store and smear it on the backside of the brake pads. that should take care of it..
alacrity024 is offline   Reply With Quote
Old 03-14-2006, 04:20 PM   #7
Absolut
Member#: 21848
Coating my brakes in a combination of WD-40 and Vaseline seems to work best for me.
Todd
Absolut is offline   Reply With Quote
Old 03-14-2006, 04:24 PM   #8
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
Try not to put any on a painted surface or on the rubber of the seals or lines.
Just kidding, spray the **** out of them, then throw a match on there to burn off the excess.
TyrannoSullyRex is offline   Reply With Quote
Old 03-14-2006, 04:26 PM   #9
warpath
Member#: 84622
2015 OB EVO X
1992 MKIII Supra
Oh yeah, In fact they spray it on blind kid's faces and it gives them sight...
warpath is offline   Reply With Quote
Old 03-14-2006, 04:34 PM   #10
-=C=-
Member#: 7719
99 F-150 crew cab
Thanks smartass...
Old 03-14-2006, 04:51 PM   #11
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
Brake clean burns like a futher mucker when sprayed in the eyes.
Old 03-14-2006, 04:57 PM   #12
-=C=-
Member#: 7719
99 F-150 crew cab
Thanks alacrity...much appreciated.
Old 03-14-2006, 05:08 PM   #13
Bonzo
Member#: 2307
2009 530EXCRF1000D
Orange
I use brake and parts cleaner to clean my cd's and dvd's all the time.
Bonzo is online now   Reply With Quote
Old 03-14-2006, 05:20 PM   #14
pjcoregon
Member#: 15384
different pads than what you are using.
pjcoregon is offline   Reply With Quote
Old 03-14-2006, 05:44 PM   #15
tbert
Member#: 43357
2004 Smug 46MPG
2006 Clown Car
Should clear it right up.
tbert is offline   Reply With Quote
Old 03-14-2006, 06:03 PM   #16
CrazyButHappy
Member#: 58545
2003 WRX
Some squeaking is inevitable as most rotors get a little surface rust and will squeak the first time you hit the brakes in the morning. For a consistant squeak it takes a little more effort to get rid of it.
Assuming you have bedded in your pads, it is not just surface rust, this has been going for a little while. (I have taken my GF's brakes apart three times and every once in a while they still squeak, I am sure just to piss me off.)
1. Start by spraying brake cleaner as you originally posted. Pray this works.
2. When it doesn't take your wheels off and spray the calipers again (avoid spraying rubber parts, etc.)
3. When this doesn't work, remove the pads and note shiny places on the backs, the slides, anywhere they touch the caliper.
4. Spray the caliper with brake cleaner.
5. Use the tube of Brake Squeal Stop goop from Autozone to lubricate the back of the pads and the shiny places. Do NOT get the goop on the pad surface or the rotor. Do NOT put so much goop on it could get on the pad surface or rotor.
6. Put everything back together, drive around a bit and listen for which wheel still squeaks.
7. Re-tighten your lug nuts on the wheels that don't squeak (if you have alloy rims).
8. Repeat process for wheels that still squeak.
CrazyButHappy is offline   Reply With Quote
Old 03-15-2006, 10:18 AM   #17
-=C=-
Member#: 7719
99 F-150 crew cab
Thanks CBH...I'll give it a shot this weekend.
can stock turbo inlet come off in one piece without removing the manifold? jcbluescooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 04-09-2009 07:08 AM
Can the tranny crossmember be removed without removing the downpipe? PhastEddie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-23-2007 09:54 AM
How can I get out my uppipe without removing the lower engine mount bolt? vteg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 02-16-2004 08:55 PM
installing suspension without bleeding the brakes? bryanw Brakes, Steering & Suspension 2 03-24-2001 09:36 PM
