Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-14-2006, 05:46 PM   #1
wowthatisrandom
Member#: 70510
2004 WRX
Default help me pass emissions!!
so i went today to see if just maybe i could pass emissions but NOPE i failed miserably at that. so what do i do now...
I ONLY HAVE TILL SAT!! im going back to Wisconsin for School!
Im from Missouri we dont use the sniffer only OBDII
i got the following failures
catalyst : Not Ready
Evaporative System : Not Ready
Oxygen Sensor : Not Ready
Oxygen Sensor Heater : Not Ready
Readiness : Not Ready
and i have the following mods
Utec
VF22
650cc inj.
helix up
helix Catted Down
helix cat back
bov
walbro 255lph
thanks
jason
wowthatisrandom is offline   Reply With Quote
Old 03-14-2006, 06:00 PM   #2
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
There is a post on the EM&T forum saying what you have to do to get some codes to clear. I think doing those would help getting the ready codes apparently you have to drive a while to get them.
http://forums.nasioc.com/forums/showthread.php?t=955920
TravisSTi is offline   Reply With Quote
Old 03-14-2006, 06:09 PM   #3
fizzak
Member#: 84968
2005 WRX
Uhh, what do you mean we don't have a sniffer? What do you think that probe is they stick in the tail pipe at the emissions station?
fizzak is offline   Reply With Quote
Old 03-14-2006, 06:26 PM   #4
wowthatisrandom
Member#: 70510
2004 WRX
they dont do that in missouri they hook up a sensor to ur gas cap...
then they plug in a OBII scanner and thats it.
they no longer pu that on the tail pipe
Old 03-14-2006, 06:29 PM   #5
fizzak
Member#: 84968
2005 WRX
Your right, my bad. Just confirmed this with a buddy, the probe is for pre-1996 models.
Old 03-14-2006, 06:33 PM   #6
wowthatisrandom
Member#: 70510
2004 WRX
thanks lol since i was there 30 min ago
Old 03-14-2006, 06:35 PM   #7
subeforlife2002
Member#: 100667
2002 WRX stage 4
Do you have a check engine light going off? Or is it not through the full drive cycle for the light to pop up yet.
subeforlife2002 is offline   Reply With Quote
Old 03-14-2006, 06:36 PM   #8
wowthatisrandom
Member#: 70510
2004 WRX
i got no CEL so i would assume it hasnt gone thru the full cycle yet
Old 03-14-2006, 11:36 PM   #9
subeforlife2002
Member#: 100667
2002 WRX stage 4
Any luck so far wowthatisrandom?
Old 03-14-2006, 11:46 PM   #10
wowthatisrandom
Member#: 70510
2004 WRX
so far ive gotten 2 suggestions
1. register my car in Wisconsin since i go to school there.
or
2. go back to stock
neither which i am happy about
Old 03-14-2006, 11:53 PM   #11
subeforlife2002
Member#: 100667
2002 WRX stage 4
I was also going to say register it under wisconsin. How many miles have you put on the car since you cleared the codes? When I was having check engine and I cleared it the first time I put 500 miles on the car ( most highway ) until the light came on. The other night after we put my clutch and flywheel on it only took 6 miles till the light came on. I just pulled my codes tonight and I have misfire in cylinder 1-4 and a P0420 code with is catyltic converter effiency, but I don't have a cat in any of my exhaust or header. So I'm figuring its my 02 sensors. I am running a very similar setup as you also ( not saying its your 02's just saying I'm in the same boat)
Old 03-15-2006, 12:36 AM   #12
wowthatisrandom
Member#: 70510
2004 WRX
ya before i had the stage 4 i got the p0420 all the time and afterwards i get the misfire codes occasionally so sounds simliar, i reset my ecu b4 i left wisconsin last friday so its been close to 500 miles b4 i tested it
Old 03-15-2006, 12:47 AM   #13
subeforlife2002
Member#: 100667
2002 WRX stage 4
Sorry I can't help you out at all. Did you do anything to fix the P0429 code or you just keep clearing it?
Old 03-15-2006, 12:48 AM   #14
wowthatisrandom
Member#: 70510
2004 WRX
i have a scan gauge so i just cleared it but the utec can disable the light so u can use that its in parameters/user constants
Old 03-15-2006, 01:12 AM   #15
dvang
Member#: 84188
05 legacy
caravan full of kids now
u keep getting the "not ready" because you keep resetting the ECU.
u want to pass the OBD2 test?
you need to drive a bit b4 the ecu gets into ready mode, some say 50-100 miles start and restart car. just because you dont see a CEL because the utec disables it doesnt mean its not there.
easiast way to pass in your situation accessport or go back to stock a bit .
remove utec
reinstall stock injectors
try doing the mech CEL fix for the 02 sensors if its still going off
hopefully your upipe has the egt probe plugged in.
remove BOV
dvang is offline   Reply With Quote
Old 03-15-2006, 07:01 PM   #16
subeforlife2002
Member#: 100667
2002 WRX stage 4
Just talked to Jorge from P&L motorsports in franklin park. Seems to be that our Utec systems don't work well with big injectors. If I understand correctly it seems that our utec's can't fully control larger injectors like the AP can. Which will throw a misfire code like I have on all four cylinders!! Maybe switching from you Utec to AP isn't a bad idea. I am thinking about it.
Need help to pass emissions HF|[S]Devil Normally Aspirated Powertrain 5 06-25-2009 02:18 PM
Help me pass CA smog revcor632 Service & Maintenance 9 01-16-2009 04:30 PM
help me pass smog! WReXd Southern California Impreza Club Forum -- SCIC 15 06-12-2007 12:14 AM
Out to sea, help me pass the boredem... WRX_scott Mid Atlantic Impreza Club -- MAIC 5 08-21-2006 10:29 AM
does the utec help in passing emissions? tEkkGOD Engine Management & Tuning 5 09-30-2003 12:05 PM
