Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 03-14-2006, 07:04 PM   #1
Member#: 14715
09 Rigdeline RTL,
07 Burgman 650 Modified
Default rearend swap ??'s
i have a 97L wagon and i also have the complete rearend and rear disc conversion from a 2000 rs so my question is will the rs rearend effect my gearing and should i also swap over the driveshaft too. any pro's and con's to this besides rear disc brakes. and what else in the rear can i tranfer from the rs over to my 97L wagon.
boostinwrx is offline   Reply With Quote
Old 03-14-2006, 10:42 PM   #2
Member#: 75078
2000 Legacy GT
Black Granite Pearl
im pretty sure that the rear end from an RS will not work in a 97L. the gearing of the rear differential must match that of the center diff, (which is on the back of the tranny). the 97L has a 3.9 final drive ratio in the rear and the RS has a 4.11.
the rear disc brake conversion will work if you have the wheel hubs, but as for using the RS rear diff, thats a no go unless you swap transmissions.
DerrickRH is offline   Reply With Quote
Pros & Cons swapping in 6 speed without rearend swap. swift2fly Subaru Conversions 28 12-07-2006 06:49 AM
RS to WRX motor swap?'s bluimpreza00 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-21-2003 12:59 PM
Turbo crossmember swap ?'s serious Legacy Forum 4 01-08-2003 01:10 AM
engine swap ?'s SlowRS Normally Aspirated with bolt-on Forced Induction Powertrain 14 10-19-2002 12:08 PM
