Closed Thread
Old 03-14-2006, 08:35 PM   #1
JJ1077
Member#: 109897
Subaru Banner air intake mass air flow sensor
my car just got a new intake and the mass air flow sensor must stay on there when i punch it the car stalls can anyone help there is no leak the sensor is brand new so is there something i can buy in place of that or bypass something
JJ1077 is offline
Old 03-14-2006, 08:49 PM   #2
sha_zapple
Member#: 41012
1998 Legacy L
It would help to know what year and model car you have, and if you typed proper sentences.
Yes the MAF must be integrated into the new intake. Chances are its not plugged in properly, you damaged it while taking it apart, or one of your vacuum lines is not plugged inproperly or has a leak
sha_zapple is offline
Old 03-14-2006, 09:10 PM   #3
JJ1077
Member#: 109897
isnt the mass air flow there to restrict air or let only a certain amount of air isnt there something else to do
JJ1077 is offline
Old 03-14-2006, 09:14 PM   #4
djviper
Member#: 107276
99 V.R.Special
WRC blue
the maf is called the mass air flow sensor because it mesures the air comeing in so at certain revs the engine knows how much fuel to add to hit its target afr, you can ditch it with certain ecu's and only run the MAP as this is geeraly quicker to respond and can cope with a far greater air flow
djviper is offline
Old 03-14-2006, 09:33 PM   #5
WR^2X
Member#: 37617
Sounds like you're thinking of the throttle body, specifically the butterfly valve of the throttlebody.
WR^2X is offline
Old 03-14-2006, 09:37 PM   #6
djviper
Member#: 107276
99 V.R.Special
WRC blue
"car stalls", are you running any sort of boost controler?
djviper is offline
Old 03-14-2006, 10:03 PM   #7
JJ1077
Member#: 109897
NO I JUST HAVE INTAKE AND PIPE BUT I PUT COLD AIR INTAKE AND THE MASS AIR FLOW SENSOR HAD TO GET PUT IN BETWEEN THE CONE AND THE PIPE KNOW WHEN I PUNCH IT IT FREEZES UP AND I LET OFF THE GAS AND ITS FINE AGAIN
JJ1077 is offline
Old 03-14-2006, 10:08 PM   #8
djviper
Member#: 107276
99 V.R.Special
WRC blue
is the MAF sensor in the same place and orentation as it was before?
and what do you mean by freezes up?
djviper is offline
Old 03-14-2006, 10:10 PM   #9
attitude
Member#: 52043
04 sti
And Why Did You Start Yelling?
attitude is offline
Old 03-14-2006, 10:17 PM   #10
JJ1077
Member#: 109897
YES THE MAF IS IN THE SAME DIRECTION
BUT WHEN I PUNCH THE GAS THE CAR STALLS EVERY TIME I PUSH ALL THE WAY ON THE GAS.
JJ1077 is offline
Old 03-14-2006, 10:20 PM   #11
layzienoy
Member#: 91505
its funny how people consider caps online as yelling lol
well you might want to take a look at the sensor to see if there is any build up or dirt on the sensor, did you bang it against anything when you installed it, also this is just a thought but the filter you are using may contain oils and it may get onto the sensor
layzienoy is offline
Old 03-14-2006, 10:24 PM   #12
djviper
Member#: 107276
99 V.R.Special
WRC blue
do you have your "CEL" light on at all??
djviper is offline
Old 03-14-2006, 10:53 PM   #13
Lachlan
Member#: 19470
1981 Brat GL
Lachlan is offline
Closed Thread
WTT: AEM Cold Air Intake With Dry Flow Filter For??? Or Get It For Free!!!! sum0325 SCIC Private Classifieds 6 02-11-2010 01:57 AM
Air intake size and flow wcbjr Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-25-2003 04:22 PM
AEM Cold Air Intake and Air Bypass Valve jfalcon001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-10-2002 08:45 PM
Air intake ? (Akimoto Air Intake) Snooze Normally Aspirated Powertrain 26 12-19-2001 09:56 AM
Air Intakes & Air Flow Sensor Norris Normally Aspirated Powertrain 6 10-17-2001 04:11 AM
