Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 03-14-2006, 08:45 PM   #1
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
Default Itbs?
Yeah, I'm almost done. Pictures are with only a single butterfly in place:
Synchronization will be handled by two of the same throttle wheel connected at a neutral point by an adjustable rose-jointed rod.
Idle control will be modulated by valves that are tapped into the walls of the throttle body below the throttle plates.
I will be running MAF with an intake plennium to see what sort of changes there are from the ITBs alone, and then be converting to MAP so that I may run exposed intake horns on track days.
The only big hurdle for this conversion on my car (98 Outback) is to adapt the Phase II style intake manifold bolt pattern to secure the bodies to my Phase I heads. I've thought about cutting just the flange off of a Phase II intake manifold and adding some tabs for the Ph I head pattern. This way, it would assemble by bolting my cut and welded flange on to my head and bolting the ITBs down via long studs that are permenently fastened to the adapter section. The Phase II intake ports are small, so any port matching that is needed (and there is a lot) can be done by shaving rather than adding material.
Any thoughts?
mranlet is offline   Reply With Quote
Old 03-14-2006, 08:53 PM   #2
redwagon
Member#: 2181
2008 SpecB
You make those out of WRX tumble valves?
redwagon is offline   Reply With Quote
Old 03-14-2006, 08:56 PM   #3
mranlet
Member#: 66304
98 RWD BG Outback
Yep. I've replaced the 3/4 butterfly with a full one that I cut down from a piece of flat stock galvanized. There is significant portwork to get the full throttle plate to pass by the low-tolerance passage wall.
Old 03-14-2006, 09:06 PM   #4
Handsdown
Member#: 29355
sick. super super sick.
Handsdown is offline   Reply With Quote
Old 03-14-2006, 09:13 PM   #5
djviper
Member#: 107276
99 V.R.Special
WRC blue
this might sound dumb but i dont know the back ground, what are you trying to achieve?
djviper is offline   Reply With Quote
Old 03-14-2006, 09:17 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
better throttle response.
Old 03-14-2006, 09:25 PM   #7
mranlet
Member#: 66304
98 RWD BG Outback
Individual throttles for each cylinder are the epitome of instantaneous response.
Just imagine a Subaru version of something like this:
http://video.google.com/videoplay?do...3082170&q=itbs
Or better yet, this:
http://www.youtube.com/watch?v=Ba8sT2BQ4uc&search=itbs
If you've ever driven an E30 M3 or Mercedes 190E Evolution, you will know that the connection between driver and engine is unsurpased with individual induction.
Old 03-14-2006, 09:38 PM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Oh snap!!! ITB's!!!
As for adapting them to the heads... Why not just run WRX heads? If you are going this far for ITB's, I presume you are doing something to bypass all the sensors and gizmos in the intake manifold region...
Old 03-14-2006, 09:43 PM   #9
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
Ahhh Yeah! subscribe!
Rally_wgn is offline   Reply With Quote
Old 03-14-2006, 09:44 PM   #10
djviper
Member#: 107276
99 V.R.Special
WRC blue
got ya!
Old 03-14-2006, 09:46 PM   #11
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
I've always wondering why you had ITBs in your profile but only mentioned the aspect of the RWD BG.
-paK +1
Pakin is offline   Reply With Quote
Old 03-14-2006, 10:42 PM   #12
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
wow
DoctorNick is offline   Reply With Quote
Old 03-14-2006, 11:03 PM   #13
mranlet
Member#: 66304
98 RWD BG Outback
Originally Posted by Kostamojen
Oh snap!!! ITB's!!!
I'm trying to make them adaptable to the more popular NA platforms, and I'm partial to the DOHC Phase I heads because of their flow and tunability.
I'm going one step at a time; I've got to finish my setup before reproducing it for other people, but I think that eventually a set of these things will find their way on to a WRX
Old 03-15-2006, 02:16 AM   #14
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
I've been trying to figure out how to do this same thing, I had the same idea too , good job so far. I'm thinking the main problem is going to be the air after the throttle plates. For like the brake booster, vaccum lines, etc. How are you coping with these problems?
THAWA is offline   Reply With Quote
Old 03-15-2006, 02:49 AM   #15
redwagon
Member#: 2181
2008 SpecB
I think back to my old Alfa with two twin-choke Dellortos, that had small ports referencing below the venturis all connected with a small plenum box and then the brake vacuum hose etc. tapped to that. Just drill some counterbored holes under your throttle plates and tap some short bits of brass pipe to use for hose spigots.
Old 03-15-2006, 02:49 AM   #16
Storm
Member#: 5218
96L Most Over-
Developed Beater
You can use a common pipe with small fittings in each throat to serve as a vacuum source for all of the necessary components.
I'm using a simple 4 port airchuck plenum fitted with the appropriate nipples and one large trunk line to the manifold. Although I'm not using ITBs, the single trunk line to a central vacuum distribution block seems to work just fine for me.
Jay Storm
Old 03-15-2006, 04:13 AM   #17
JDMviola
Member#: 80680
05 Impreza 2.5 RS
CGM
That is awesome, can't wait for the finished product
JDMviola is offline   Reply With Quote
Old 03-15-2006, 05:28 AM   #18
moss
Member#: 10197
*subscribes*
moss is offline   Reply With Quote
Old 03-15-2006, 09:16 AM   #19
poruki
Member#: 68792
I'll agree, ITB's make for GREAT throttle responce.
www.projectaerosol.com/porubi/
poruki is offline   Reply With Quote
Old 03-15-2006, 09:25 AM   #20
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Instead of changing the flanges, just finish it up and send them to me. I will put them on my car and just run open horns all the time with just some JDM filters (screen) over them.
Nice work, I've been thinking about this for a while, just wish nothing else was wrong with my car so that I could focus on that.
Old 03-15-2006, 05:05 PM   #21
mranlet
Member#: 66304
98 RWD BG Outback
This looks awesome. I can see that you adapted the throttles using plates of aluminum, but how did you do the throttle linkages?
Old 03-15-2006, 09:01 PM   #22
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Kreeger is offline   Reply With Quote
Old 03-15-2006, 09:23 PM   #23
poruki
Member#: 68792
The carbs are Weber 48 IDA's as used by the VW guys and that is where the linkage came from.
The intake manifolds are CNC machined from billet aluminum.
Stock 2001 EJ251 + Webers = 126.3 HP at the wheels.
Old 03-15-2006, 10:09 PM   #24
Gator GT
Member#: 37190
07 specB - 6spds,
4 tips, 3 LSDs, stg 2!!!
very very impressive. I can not wait to see (and hear) this final product!!!
GGT
Gator GT is offline   Reply With Quote
Old 03-15-2006, 10:16 PM   #25
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
this is awesome!
great idea and awesome job implementing it! looks sick, cant wait to see it in action.
keep this updated with pics
Ben
Olsen Twins.......ITB......Pretty sure it's worksafe Nightwing Off-Topic 56 12-29-2003 11:03 PM
ITB on RS engine possible? SlowMotion Normally Aspirated Powertrain 24 11-13-2003 02:51 AM
Itb Scubaru Normally Aspirated Powertrain 94 02-25-2003 11:36 PM
Is everything in place for drive-by-wire ITBs? aspera Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-15-2003 02:12 AM
ITBs for 2.5 ? MichiganRS Normally Aspirated Powertrain 0 03-02-2001 09:02 PM
