Old 03-14-2006, 11:52 PM   #1
WRblueX_Guy
Member#: 53247
Default I have a Rear sway bar, I have a question about the front
I have a Helix Rear Sway bar (adjustable, 22 mm), and I want to buy a Perrin front sway bar, which is adjustable and also 22 mm. I just want to make sure that the front can be as thick as the rear, or if it would be better to get a 21 mm front.
I believe the stock WRX sway bars are 19 mm front an 17 mm rear, so I don't think it should be a problem. I just wanted to double check.
I also have front and rear strut bars, springs, rear end links, and tires.
Thanks,
Brian
WRblueX_Guy is offline   Reply With Quote
Old 03-15-2006, 02:39 AM   #2
Impreza01
Member#: 152
2002 Impreza WRX
20mm/17mm front and rear respectively.
Impreza01 is offline   Reply With Quote
Old 03-15-2006, 04:13 AM   #3
Mark Avery
Member#: 10313
2002 WRX wagon
Stock is 20mm/17mm, so a 21mm in front isn't a big upgrade.
An adj 22mm front with a adj 22mm rear is a great setup for the street.
Mark Avery is offline   Reply With Quote
Old 03-15-2006, 02:41 PM   #4
WRblueX_Guy
Member#: 53247
Okay, cool. Thanks guys.
I'm planning on setting the RSB to the stiffest setting. What would be the best setting on the Perrin in order to obtain the least amount of body roll, and the least amount of understeer?
Thanks
I have a rear sway bar - thinking of getting a front one WRblueX_Guy Brakes, Steering & Suspension 13 07-06-2005 09:27 PM
Does anyone have Helix Rear sway bar and rear endlink setup? aspenwhitewrx Brakes, Steering & Suspension 0 01-18-2005 02:03 PM
Anyone have a rear sway bar mount? Avenger Vancouver Impreza Club Forum -- VIC 0 10-17-2004 02:52 AM
I have a rear sway bar, which endlinks should I go with, should I get front too? Schleppy Brakes, Steering & Suspension 2 08-20-2002 11:52 AM
Getting rear sway bar soon, a few questions.. Hyudra Brakes, Steering & Suspension 20 10-23-2001 04:08 PM
