Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 03-15-2006, 01:11 AM   #1
azn2nr
Member#: 35276
2006 2.5i clone
438/420 whp
Default How do you depressurize the AC system and drain powersteering.
ok i just started my swap and have a few questions (swap consists of a legacy turbo motor into a 95 impreza)
the power steering needs to be removed to get the motor out. is there a dain for this so taht the system can be disconected and where is it? also do i use the car's powersteering system or the motor thats beeing swapped in's powersteering system.
also on the ac system, whats the best way to get the system depressurised without having it tow'd to a shop and does the system need to be drained in order to be removed or if its just depressurized will it be safe to remove. and how toxic is the freeon charge.
i think thats all for now. tia.
azn2nr is offline   Reply With Quote
Old 03-15-2006, 01:41 AM   #2
TheKryptKeeper
Member#: 80818
1994 Impreza L wagon
As far as the AC goes, there is good news and bad news.
The Good:
Freon (R12 refrigerent) is not so much toxic as it is dangerous. The freon binds to plain O3 AKA ozone. It destroys our atmosphere. Because of this, the government has a fund in place to pay people for used and contained freon. That means that there are people who are more than willing to come to your house and replace your R12 with the enviromentally safe R134a refrigerant for free.
The Bad:
You don't have freon, you have R134a. They stopped putting freon in cars since 92-93 I believe.
The Ugly:
There isn't anyone who will want to 1. come to your house and 2. do it for free. If you vent it into the air it is a $25,000 dollar fine if caught and it isn't too good for the pollution (It binds to nitrogen and makes it sink ergo it gets real stinky).
As far as the power steering, make sure that the steering wheel is strait and take off one of the lower lines, however, it is built into the crossmember so it might be easier to keep it together and just detach the PS pump and let it dangle.
Good luck, Now go and spred your new found eviromentally consience information to the many plethora of women you are trying to get to know.
TheKryptKeeper is offline   Reply With Quote
Old 03-15-2006, 01:45 AM   #3
TheKryptKeeper
Member#: 80818
Unless of course you were talking about the 92 legacy AC lines. In which case, you might have freon, I doubt it though. Check with Subaru.
Old 03-15-2006, 02:08 AM   #4
azn2nr
Member#: 35276
2006 2.5i clone
438/420 whp
ok but since im taking out the crossmember doesnt that mean ill have to drain the system anyways adn use the legacy powersteering system.???
Old 03-15-2006, 11:44 AM   #5
azn2nr
Member#: 35276
2006 2.5i clone
438/420 whp
lumps.
Old 03-15-2006, 12:07 PM   #6
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
my 93 had freon
i wouln't drain the ac system unle you had to .. espically if it works..
power steering .. i just made a mess ... i reused the 1.8 pump (possible w/ ej20g) left it connected untill i had the subframe seperated from the car
for the love of all that is holy, how do you remove the AC vent rings? Capt Crunch Interior & Exterior Modification 4 01-02-2007 12:28 AM
How do you remove side AC vents on sti? SpeedMasterLee Interior & Exterior Modification 1 05-31-2006 04:24 AM
How do you bleed the power steering system? Red Rocket Brakes, Steering & Suspension 3 01-11-2004 12:18 PM
How do you flush the a/c system for MY00 2.5RS latinskllz Service & Maintenance 3 07-28-2002 03:46 PM
('93-'01) How do you flush the cooling system? 2yLiTe Impreza Forum 6 06-04-2001 05:48 AM
