Old 03-15-2006, 01:02 AM   #1
josh...just josh
Member#: 82273
97 impreza L
now with wrx brake love!!
Default rx7 trans in an impreza
i know that this is kinda crazy, but i heard someone say something about using a rx7 transmission in an impreza the other day and it got me thinking, how possible would it be? i was thinking that you could get a bellhousing adapter made and custom driveshaft+ axles for whatever rear diff you used
the non turbos use the same size clutch (225mm) disc as subarus so i would think that you could use the subaru pressure plate and relase bearing with the 7' disc. the cross member could be sussed out, but what about shifter linkage? the rx7 just has the shifter mounted directly in the top of the trans where as the subaru uses a linkage. i would think that if you mounted the 7's tranny the shifter would be behind the opening on the subaru. i dont really know how to deal with that (besides making the shifter shaft shorter and moving the whole thing forward).
does anyone know if this has beed done or have any ideas on it?
josh...just josh is offline   Reply With Quote
Old 03-15-2006, 01:11 AM   #2
djviper
Member#: 107276
99 V.R.Special
WRC blue
why on earth would you want to!
if you want near industructable RWD form a scoob (well as close as n a buget!) use the 6 speed sti with the spiders out of the mid diff, get the midd diff welded and the run it to a r200 (from a nissan 300zx) youll need custom mounts and shafts
djviper is offline   Reply With Quote
Old 03-15-2006, 02:00 AM   #3
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
I might be putting a W58 Toyota transmission in to my Legacy. If that goes well, I may upgrade to the virtually indesrtuctable Mazda Turbo II trans.
I'd think the shifter will be too far forward, considering the spot at which Subaru motors sit in the engine bay (far forward). If the RX shifter sat too far forward, I'd just move the motor back and modify the mounts - it wouldn't need to be kept forward for axles or anything.
BTW, I already have an R200 differential in my car. It's kinda clunky, but they're tough as hell.
mranlet is offline   Reply With Quote
Old 03-15-2006, 09:27 AM   #4
josh...just josh
Member#: 82273
97 impreza L
does the w58 trans go in easier? that would be cool to, i would just really like to build a purpose built rwd trans
Old 03-15-2006, 02:25 PM   #5
josh...just josh
Member#: 82273
97 impreza L
let me know how it's going in, i really want to know because i'm doing a manual swap and since i'm staying n/a i'd like to have as little drivetrian loss as possible
Old 03-15-2006, 07:06 PM   #6
mranlet
Member#: 66304
98 RWD BG Outback
The distance of bellhousing to shifter on the W is really similar to that of the EJ trans and they're 50 bucks at the junkyard (from Mk III Supra). If I do it, it probably wont be for another month or so, or when my RWD converted trans starts biting it, but rest assured I'll keep everyone updated.
Old 03-16-2006, 01:16 PM   #7
josh...just josh
Member#: 82273
97 impreza L
thats great guy, what are your plans about the bellhousing adapter? and what what clutch are you plaining to run?
Old 03-16-2006, 04:05 PM   #8
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
I was thinking the same thing...I'm planning out a 3.3 into a xt w/ a rx7 or supra trans. Nice lil drift project that you dont see every day
XENONSVX is offline   Reply With Quote
Old 03-16-2006, 10:40 PM   #9
josh...just josh
Member#: 82273
97 impreza L
i really havent seen anyone do anything like this, i'm half tempted to just get a 7 transmission and do it
Old 04-27-2006, 05:25 PM   #10
Mad Ra88it
Member#: 113563
98 Unicorn
Any info on how well these work?
I'm in Sacramento, if anyone has a Bare Block laying around, We can meet up and see how well the T2(mazda turbo II) trans fits.
Because if it fits, I'll be selling my whole FXT RWD trans(welded center Diff)
Mad Ra88it is offline   Reply With Quote
Old 07-09-2006, 01:21 PM   #11
Mad Ra88it
Member#: 113563
98 Unicorn
I have my block outside of the car and if anyone has a trans that they would like to bring over....PM me.
07 FXT trans in an 04 wrx? scoobdude Transmission (AT/MT) & Driveline 1 12-18-2010 01:30 PM
06 WRX trans in an 04 WRX WRBlueRex04 Transmission (AT/MT) & Driveline 4 04-30-2010 11:01 PM
What do i need to instal an 02 trans in an 04 wrx MaxMendez Transmission (AT/MT) & Driveline 4 04-10-2008 09:34 PM
('93-'01) Can you put BMW or Volvo front seats in an Impreza? driver Impreza Forum 8 05-05-2001 01:48 PM
Anybody used Legacy springs in an Impreza? Thug Brakes, Steering & Suspension 0 04-06-2001 08:26 AM
