Old 03-15-2006, 01:14 PM   #1
shwoop_soobie
Member#: 102323
99 power poles
beware
Default 2.2 compression
i'm a complete amature and just ned some help. have a 2.2 and i cant find compression specs for it anywhere. i'm pretty sure the internal remain stock, but i looks like it has a 2.5 head on it. it has a turbo kit but i dont know what i should try and set boost at. it currently runs 5 psi and runs good, but i know it has more potential. you guys are the best. what do you think is reasonable to be fast and reliable?
shwoop_soobie is offline   Reply With Quote
Old 03-15-2006, 02:26 PM   #2
overlord
Member#: 52186
2005 LGT LTD
Regal Blue
I would take it and get the thing tuned. You can increase boost all you want but you will never know how it is running unless you get some pulls in with a wideband.
overlord is offline   Reply With Quote
Old 03-15-2006, 02:52 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Who'd you get the car from? Do you have any pictures of the engine bay? What's the turbo set up like? Engine management?
Either you have an Ej22T bottom end, which would be a total score. Even if it is an Ej22E open deck bottom end, it will do all right with 12-15 psi because it's a pretty solid block and the compression will still be in the mid 8's.
But to tell you anything definitive, we really need some more info. I am wondering if this is one of the old JC sports built cars from back in the day...
Old 03-15-2006, 04:31 PM   #4
shwoop_soobie
Member#: 102323
99 power poles
beware
i think the kit is a ludespeed kit. it has a t/4 greddy turbo, topmount ic, electromotive tec 2 (old school) . i think it was originally built by a guy at vishnu performance. the kit originally was on a 2.5. for some reason i want to say its a closed deck block. i know i has all the suppor mods for power, but i just dont know about the internals. where could i find the engine code?
Old 03-15-2006, 04:36 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
You won't be able to tell from the outside. Look closely at the casting. If it's closed deck, it will have a bunch of criss cross hash marks on the casting on top.
Old 03-15-2006, 04:39 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
pictures will help
the injectors will also be a big factor on how much you can do
by any chance did you get the map file for the tec .. it can't be downloaded.. w/o it you will have to start over retuning the car from scratch..
Old 03-15-2006, 05:33 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
If the car was white, I might suspect that it was Shiv's personal car...
Old 03-15-2006, 05:53 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
it would have had a tec 3 too if it had been shiv's car
Old 03-15-2006, 06:32 PM   #9
shwoop_soobie
Member#: 102323
99 power poles
beware
no its silver. i dont have the map. it has pretty beefy looking injectors. whatever comes with the kit. so psi in the teens is feasable though.
Old 03-15-2006, 08:59 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i have the base map for the my00 turbo kit but its not even going to be close for the 2.2 i have been strugeling learning to tune for ~2 years
you can at least download the software wintec 2.13 (i beleive is the latest version) from electromotive and genrate some logs
might be kastles car too iirc it was silver. does it have the ver 5 (big)wing?
have you posted in the southwest forum to see if you might find the old owner?
Old 03-17-2006, 12:54 AM   #11
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
We have a wrx motor going into this car now.
Lot less of a hassle then dealing with tec 2
Smoby is offline   Reply With Quote
Old 03-17-2006, 11:31 AM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hey i know some one who might be intersted in the tec if your gonna sell it ? (coughcoughmatt)
Old 03-17-2006, 01:16 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
Then what was the point of this thread?
And while it may be a lot less hassle than tuing the Tec2, it's a major step backwards in the performance department, and will require a major rewiring operation, but shoot yourself...
1998 Impreza L 2.2 - Cylinder 1 no compression dominantset Private Vehicle 'For Sale' Classifieds 11 11-05-2007 10:14 AM
2.2-2.35 Stroker Compression Q's akbigbud907 Built Motor Discussion 2 10-14-2006 12:17 AM
uh-oh... just did compression test on 2.2 legacydreamz Legacy Forum 2 02-15-2006 07:10 PM
2.2 High compression questions cjfike Normally Aspirated Powertrain 13 11-21-2004 10:35 AM
increase compression 2.2 John*G Normally Aspirated Powertrain 4 05-10-2004 09:45 AM
