Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 03-15-2006, 04:36 PM   #1
mtxfrk2k1
Member#: 103401
2005 WRX
Default Misfiring after Reflash! Help!
im using Engenuity editor and ecuExplorer/EcuFlash to load and flash the stock ecu.
i loaded a slightly tuned map to my car last night and it ran pretty decent except for a little bit of rough idling.
today i drove it for about 10 miles and was running about 10psi when it just started to die on me.
i pulled over and now when i try to start it. it just misfires from the beginning and it shuts itself down.
any idea on what to start or anything?
could i have fouled the plugs?
could the ECU try to learn over itself?
mtxfrk2k1 is offline   Reply With Quote
Old 03-15-2006, 05:15 PM   #2
JRSCCivic98
Member#: 67080
This is what happens when you try and run someone else's map on your car. Did you do any logs on the car as you drove it first and did you even put a wideband on it to make sure the A/F ratio was ok for your perticular application? You can do what you're doing if you don't use the right tools for the job. I know this doesn't solve your problem, but this is how people blow up their cars. I hope you haven't done that.
JRSCCivic98 is offline   Reply With Quote
Old 03-15-2006, 09:18 PM   #3
mtxfrk2k1
Member#: 103401
2005 WRX
it will idle and rev to 4500 just fine with the MAF unplugged.
as soon as i plug the MAF in, the car idles like **** and will sometimes stall out.
it also sounds like the intake is sucking in alot of air just while sitting there idling.
what all could it be?
Old 03-15-2006, 09:23 PM   #4
mtxfrk2k1
Member#: 103401
2005 WRX
http://www.zippyvideos.com/1866425994312726/100_0653/
thats a video of when it was doing good.
it idled and ran great...
now it doesnt...
Old 03-15-2006, 09:57 PM   #5
JRSCCivic98
Member#: 67080
Flash back to stock. If it still drives and sounds like crap, then you've probably killed something.
Old 03-15-2006, 10:36 PM   #6
mtxfrk2k1
Member#: 103401
2005 WRX
it still does it with stock map.
we have it narrowed down where it cant be spark plugs because when we unhook the maf they all kick in and run normal, which means there is atleast some compression for all 4 pistons which means a valve isnt bent.
im thinking boost/vac leak or something of that nature.. gotta take everything out and try again i guess.
Old 03-16-2006, 10:05 AM   #7
JRSCCivic98
Member#: 67080
There may be a leak somewhere with that APS FMIC setup you have... or it could be a botched engine from a crappy map you thought would work for your car. It's hard to say without being there. What else changed when you did the reflash?
Old 03-16-2006, 11:13 AM   #8
mtxfrk2k1
Member#: 103401
2005 WRX
we installed new turbo, fuel pump, injectors.
the fuel pump kicks on strong and everything.
we thought the turbo seized up but its still spinning great and everything.
the injectors are stock modded ones scaled to 740.
Old 03-16-2006, 11:35 AM   #9
happasaiyan
Member#: 37731
its a boost leak post MAF. if you had a wideband, you would most likely see <8:1AFR. with a leak that big, it should be pretty easy to pinpoint.
happasaiyan is offline   Reply With Quote
Old 03-16-2006, 12:49 PM   #10
mtxfrk2k1
Member#: 103401
2005 WRX
my friend is coming to pick me up. we are going to go check it out . we are going to remove all the IC piping check for holes in the hoses or piping.
could it be a bad MAF? any way to check?
Old 03-16-2006, 06:22 PM   #11
happasaiyan
Member#: 37731
check where the couplers are. i bet it will be easily visible. mine always popped off on the coupler pre-intercooler...on both ends of the coupler.
Old 03-16-2006, 10:57 PM   #12
mtxfrk2k1
Member#: 103401
2005 WRX
lol coupler actually split. i just looked where it was connected.. so it is fixed now.
to think 19psi could do such a thing...
on a completely self road tuned first try
Old 03-17-2006, 07:04 PM   #13
happasaiyan
Member#: 37731
i feel your pain, my friend.
i did injectors/fuel pump/turbo/fmic all by myself all in one shot...i was tuning it myself with my utec...and once i worked up the boost safely to 19psi, the hose blew off, and the car died...and i was on the side of the highway underneath my car trying to get the hose on enough to get the car to run long enough for me to get home so i could re-tighten it. got home, retightened it....then went for another run (this time with the tools in hand ) and when i hit 19psi again, the other end blew off. i think this happened a couple more times before i just ended up using the clamps that came with the APS kit. (the t-bolt clamps were actually too slippery to hold the boost- ymmv). no problems running 23psi now.
Old 03-18-2006, 09:41 PM   #14
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
glad you got it working... it sure seemed like a hose must have popped off somewhere...
Colby
colby is offline   Reply With Quote
Help! Engine misfire after boost gauge install... wrxsomeday Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-16-2009 06:25 PM
first cylinder 1 misfire, after plugs, 1,3,4 misfire! DieselClown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 08-26-2008 02:59 PM
Misfire on cylinders 2 and 3 after reflash Farns801 AccessPort 2 04-21-2008 09:09 PM
help 05 sti misfiring after head gasket change takumi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-13-2007 09:29 PM
Need Help! Car Misfiring after install!!! Bad! boozy04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 12-18-2006 11:08 PM
