Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 03-16-2006, 10:23 AM   #1
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Question EJ20G head question
I need to know which of the 2 ports on the back of the head (turbo side) are for water and oil. The oil drain tube is the same as my old legacy turbo heads, but the other 2 are not.
No, I do not have a pic....one port is at the top of the back of the head the other is down by the oil drain.
thanks for any help
Scoobyslack1 is offline   Reply With Quote
Old 03-16-2006, 04:26 PM   #2
Scoobyslack1
Member#: 2780
junk yards rule!
Lightbulb
no one has an EJ20G that they can look at the feed lines for the turbo?
Old 03-16-2006, 04:28 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I can when I get home tonight. I looked through my pictures, but nothing I have shows what you are looking for. In my mind, it should be straight forward. The coolant should be pipe, just like on the Ej22T, and the oil lines should use bango bolts. But to describe it for sure, I need to take a look at my heads...
Old 03-16-2006, 04:28 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
A-ha. Search for moose's v2 heads for sale thread...
Old 03-16-2006, 04:32 PM   #5
Scoobyslack1
Member#: 2780
junk yards rule!
Unhappy thanks
The oil drain tube looks just like the EJ22T head, but there is no pipe on the back of the EJ20G head like the legacy's for the water feed....just two holes.
Old 03-16-2006, 04:34 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
Nothing like this pipe (this is moose's head)? If the pipe is missing, it's going to be a large hole with a thread tapped off to the side for the mounting bolt. The oil return will just be a threaded hole maybe 5-6mm across
Old 03-17-2006, 01:51 PM   #7
Scoobyslack1
Member#: 2780
junk yards rule!
Lightbulb
ok any one have a pic of the back of an EJ20G head like this that can tell me which hole is which?
This is an EJ22T head, my EJ20G head has the same oil drain tube, but not the other stuff.
Old 03-17-2006, 04:34 PM   #8
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
Old 03-17-2006, 05:23 PM   #9
ProRallyEric
Member#: 2204
99 Rally Impreza
team graphics
You should have 2 holes taped 12X1.25mm one at the level of the intake cam is for oil feed and the other a little ove an inch above the oil return is your water return.
Eric
ProRallyEric is offline   Reply With Quote
Old 03-17-2006, 06:10 PM   #10
Scoobyslack1
Member#: 2780
junk yards rule!
Impreza GC8
thanks Eric, that's what I thought but wanted to check
Jaxx, thanks but with the different turbo and not seeing the back of the head it is not clear from that pic.
EJ20G heads w/ej22t short block CR question legacymaximus Built Motor Discussion 13 12-01-2006 05:23 PM
Q: EJ20G heads vs. MY98 DOHC EJ25 Heads Kostamojen Subaru Conversions 49 01-30-2005 06:54 PM
Who's using EJ20g heads on a 2002 WRX block? Impreza Rider Subaru Conversions 6 11-30-2004 04:25 PM
EJ22 turbo w/EJ20G heads? Scoobyslack1 Normally Aspirated with bolt-on Forced Induction Powertrain 14 06-19-2003 04:21 PM
EJ20g heads nick robinson Normally Aspirated with bolt-on Forced Induction Powertrain 2 05-19-2003 03:07 PM
