Old 03-16-2006, 11:12 AM   #1
corey_dyck
Member#: 98427
2006 STI
Default Speedo corrections needed? 6MT into 02 WRX
If I put a stock 2004 STi 6MT and R180 rear diff into my 02 WRX, will the stock 02 speedometer cluster be accurate? As in I just plug in the speedo wire/connector and all is good?
I have a feeling that the tranny sensor outputs the correct signal and no changes are necessary, but I haven't seen that expressly written anywhere. Yes, I searched. If I missed it, could you please provide a link or search terms to use?
Thanks for your help!
corey_dyck is offline   Reply With Quote
Old 03-16-2006, 06:16 PM   #2
o2sys
Member#: 43842
200? WRX STI
well i just plugged mine in and seems to be working correctly....
o2sys is offline   Reply With Quote
Old 03-16-2006, 07:23 PM   #3
sjl1614
Member#: 56791
06 OBS
no corrections needed..i did the same also
sjl1614 is offline   Reply With Quote
Old 03-17-2006, 08:58 AM   #4
corey_dyck
Member#: 98427
2006 STI
Thank you for that info!
P1591 6mt into 02 wagon code dwike Service & Maintenance 0 04-02-2008 09:24 AM
'06 6mt into '02 WRX? sekretskwirl Transmission (AT/MT) & Driveline 6 04-06-2007 09:30 AM
Questions on 6mt swap into 02 wrx shadymilkman129 Transmission (AT/MT) & Driveline 9 08-18-2006 11:46 AM
Going to swap 6mt into '02 wrx help plz LttLDGN Transmission (AT/MT) & Driveline 10 11-16-2005 08:02 AM
JDM 6MT into MY03 WRX...Question Rippa Subaru Conversions 8 08-28-2005 10:00 PM
