Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 03-16-2006, 01:08 PM   #1
chlnOrSlpn?
Member#: 97785
2002 SRP Bugeye
EFI Logics/CTSUBIE
Default Flashing Anti-theft map question
I flashed to stage 2 last night and well i did everything correctly. well I accidently turned the car to the "off" then back to "on" that it says to skip for the 04-05 users....will that cause any issues at all?
I also wanted to know when leaving my car in a sketchy place and I want to flash the Anti-theft realtime map, how do I go about reverting it back to the stage 2 base map when I get back in the car? Do I just simply do the following?
1. with the key in the "on" position connect the AP
2. Select 'Switch Map'
3. choose Stage 2 Map
4. wait to load, hit 'OK'
5. turn to "off" then disconnect
Or I read something about selecting "Reset ECU." is that all that is needed? Does that Reset the ECU back to the Stage 2 base map?
Thanks,
Chris
P.S. OH and when reading live boost, can I disconnect the AP at any moment while the car is running, ideling of course?
chlnOrSlpn? is offline   Reply With Quote
Old 03-16-2006, 02:55 PM   #2
boxered
Member#: 61884
You don't change the "base" map when you load any realtime map. Park car, plug in AP, turn key on, flash RT anti-theft map, do whatever, come back and repeat the same as above except with stage 2 RT map.
You can disconnect the AP at anytime except when it's loading maps.
boxered is offline   Reply With Quote
Old 03-17-2006, 02:04 AM   #3
chlnOrSlpn?
Member#: 97785
2002 SRP Bugeye
EFI Logics/CTSUBIE
Thank you...I'll give it a shot.
anti-theft map sleeperrex AccessPort 3 12-24-2008 12:22 PM
flashed with anti-theft mode, lost accessport ss4ivan AccessPort 4 06-25-2008 10:35 PM
Anti-lag Map question ? SatanasoSTI Engine Management & Tuning 34 09-07-2006 12:12 PM
Cobb Anti-theft map for compression test? 03WREX Engine Management & Tuning 2 08-11-2005 04:46 PM
Anti theft map on UTEC Fusionpnoy Engine Management & Tuning 11 04-29-2005 09:26 AM
