Old 03-16-2006, 02:14 PM   #1
greysave
Member#: 62395
2005 STI
Default Streettuner Cams and Higher Revs
I am soon to be sporting a stage 3 block from Axis which is capable of 8000+rpms. I will also have some larger duration cams, probably 272I 264E or 272E I haven't made up my mind. It is my understanding that you don't tune for cams, that you can slap them in and they work. Is that true or not? If you do have to tune for cams will street tuner have the appropriate parameters to tune for cams?
greysave is offline   Reply With Quote
Old 03-17-2006, 12:05 PM   #2
greysave
Member#: 62395
2005 STI
XX tuning has awnsered my question just in case anyone else wants to know.....You do't have to tune for the cams. You do have to keep in mind the shift in powerband though.
Old 03-20-2006, 02:46 AM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Cams will change the VE of your engine in various rpm ranges. This means you MUST also change the timing in those ranges to suit it. Unless you just don't want to have the best/safest tuning.
nhluhr is offline   Reply With Quote
Old 03-20-2006, 08:21 AM   #4
greysave
Member#: 62395
2005 STI
What is VE?
Old 03-21-2006, 06:30 AM   #5
channerman
Member#: 29046
2004 WRX Wagon
channerman is offline   Reply With Quote
Old 03-21-2006, 06:44 AM   #6
TheMadScientist
Member#: 23717
2005 Big red
If you are going to raise the rev limit with street tuner, you will run into the throttle closing at the stock redline.
I posted some maps at iwsti that has that fixxed and has the low speed boost multiplier increased. The maps are untuned, you will need to tune them to your setup.
TMS
TheMadScientist is offline   Reply With Quote
Old 03-21-2006, 07:39 AM   #7
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
you got my hopes up TMS. . . no 2006 maps
Old 03-21-2006, 07:47 AM   #8
TheMadScientist
Member#: 23717
2005 Big red
Ohh yeh sorry 2004 Sti only.
Send an email to a protuner near you. Most likely they will make the TPS change for free. It is only one cell in the TPS map the needs to be changed.
TMS
Old 03-21-2006, 03:22 PM   #9
greysave
Member#: 62395
2005 STI
TMS
Thanks, I was having a similar problem on my previous setup. Is your name the same on IWSTI.
Old 03-21-2006, 03:29 PM   #10
TheMadScientist
Member#: 23717
2005 Big red
EJ25D re-clocked ECU - 10% higher rev limiter. $50 SHIPPED Patrick Olsen Engine/Power/Exhaust 7 05-21-2010 02:42 PM
Higher CR w/ StgII cams and CNC'd heads. PeteDucati Built Motor Discussion 0 11-24-2006 03:29 PM
Burning Oil only at higher revs? Tricky [RCAF] Normally Aspirated Powertrain 8 09-04-2006 04:28 PM
question about TWE cams and raising rev limit on 99 2.5 RS... Assassin4457 Normally Aspirated Powertrain 9 05-17-2006 12:05 AM
For a higher rev limit mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-18-2005 06:03 AM
