Old 03-20-2006, 05:54 PM   #1
Ceyvme
Member#: 88211
06 Evo IX
Wicked White
Default Car seems slower after tune sinks in....
Im currently Cobb stage 2 with perrin uppipe, invidia downpipe, and turbo XS axleback.
When I first put the tune on the car seems perky and fast. Also after a battery reset. When the tune is about 50 miles in, the car seems to slow down quite a bit and seems sluggish to get in boost.
Now before you yell at me, I only reset the computer once to actually confirm it was doing this. Now that I know it is, what are some things to check? I dont have a mechanical boost guage as it broke a few miles back so what else can I check to ensure that my car isn't dieing?
Ceyvme is offline   Reply With Quote
Old 03-20-2006, 06:22 PM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
You can use your AP cable as an interface to your laptop computer and then use one of the logging programs (DeltaDash, StreetTuner, Tari, etc) to log some of the vitals. Good things to look at are:
-Knock Correction (during a pull)
-A/F Learning
-Boost (or Relative Pressure)
etc
nhluhr is offline   Reply With Quote
Old 03-20-2006, 06:25 PM   #3
jays05
Member#: 78165
05 STI 35r + e85
It sounds like you got too aggressive of a tune, and after a while the ECU is pulling timing. I had the same issue with my own self-tune for a while- the only way I could keep it knock-free was to run a 95+ octane mix. Otherwise it would feel great for a day or two, then start slowing down when the ECU pulled timing.
I guess you could try running a higher octane fuel mix to see if the problem is fuel/knock/tune related.
jays05 is offline   Reply With Quote
Old 03-20-2006, 06:49 PM   #4
Ceyvme
Member#: 88211
06 Evo IX
Wicked White
Alright, after my oregon trip I guess I am going to start filling up with 94 octane again. Thanks for the information guys.
Also nhluhr, where can I find more info on those programs if they are free utilities?
Old 03-21-2006, 06:21 PM   #5
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Old 03-21-2006, 06:25 PM   #6
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
Your car is probably pulling timing like the others have said.
You can datalog for free by using ecuexplorer which you can get from www.tari.co.za
Just download that onto a laptop and you cand datalog with your accessport cable.
Check your IAM, a telltale sign about how much knock you are getting, 16=good--less than 12=bad basically. When you reset your ecu with the AP it should go to 12, see where it goes after about 30 miles of driving, don't do the "vishnu reset" since this will automatically bump it up to 16.
Also check what kind of ignition timing and KC values you are getting. Negative KC=bad.
good luck
boundy3 is offline   Reply With Quote
Old 03-22-2006, 12:54 AM   #7
xFactor
Member#: 65470
02 Hong Norr Wrx
rock chip red
There are other factors that are in play. Streetuner has a table titled "leared knock correction". Over time the ecu learns and applies a more general timing advance, or more likely retard, in this load vs. rpm map. For instance, right now with my car, I have an IAM of 16, yet my ecu has learned to pull 3 degrees of timing in the 5k -6k rpm and 1.7 -2.0 load (out of a current 2.14 max scaled load). I'm still seeing full advance on my sm-3, but the because learned kc map is one of the final corrections applied to the final timing number, my timing is still relatively low at 13 degrees when my base + advance adds up to 16. Yeah the car really feels flat compared to a fresh ecu reset. (I'm going to throw a little extra fuel at it, hoping to re-teach it; afr's in those sites are 11.4ish right now)
But I don't know if Tari reads the learned kc map; and there are probably even more maps still hidden away that impact timing that we don't know about...
later, x
xFactor is offline   Reply With Quote
Old 03-22-2006, 01:34 AM   #8
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
later, x
There are.
For instance, as soon as the Intake Air Temperature crests 122 degrees, the ECU starts pulling roughly a half degree of timing per degree of temperature rise over 122... so at 158 degrees intake temp, the ECU is pulling about 18 degrees of timing (note, it doesn't pull any more than 18...anything hotter than 158 and it just pulls the same amount).
Completely un-enclosed short-ram intakes = the devil
Car Runs slower after installed my HKS SQV BOV????? starBug Engine Management & Tuning 16 11-24-2011 10:41 AM
Put sti TMIC on 02 WRX, car seems slower bl00sc00b Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 01-28-2009 12:02 PM
Car feel slower after ECU reset???????? starBug Engine Management & Tuning 6 06-23-2004 04:03 PM
My car seems slower these days... Night Kid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-15-2002 06:47 AM
Does your car seem slower? SpeedyBoy Transmission (AT/MT) & Driveline 9 04-15-2002 05:53 PM
