Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 09-27-2001, 10:42 PM   #1
RedlineRex
Member#: 10291
2002 Impreza WRX
WR blue pearl
Default Pipe sizes
I've seen some piping sizes for the mazda Rx-7 to be around 4 inches and it is a turbo charged engine. The biggest piping i've seen for the wrx is 3 inches. If I plan on adding a much bigger turbo in the future will the 3 inches be adequate enough? how wide is a good up-pipe? Thanx for any help you guys can dish out.
RedlineRex is offline   Reply With Quote
Old 09-28-2001, 06:00 AM   #2
subywan-kenobi
Member#: 4268
2002 WRX Wagon
WR Blue Pearl
Well, 3" isn't the largest, there are plenty of brands that offer 80mm, which actually equates to something around 3.2" That is what Imprezer is running on both his Syms/Cusco system and now his Bozz Speed system. Actually, Bozz now makes a 90 mm pro system if you really want bigger, but the 80 mm should be just fine for most people's needs. Besides, RX-7s may use those 4", but do you really want that 100+ db in your ear all the time?? 80mm is plenty to flow well at 400+ hp.
As for the up-pipe, you want to keep the factory diameter (I believe it is 2 1/4"). A bigger diameter up-pipe will reduce exhaust gas velocity going into the turbo. A sudden change in pipe diameter will also introduce turbulence and additional back-pressure. Shiv's up-pipe is a good option!
Mike S.
subywan-kenobi is offline   Reply With Quote
Stock exhaust piping size on MY00 RS? GooseMan Normally Aspirated Powertrain 9 06-06-2002 08:16 AM
Vishnu Up-pipe Sizing Question... SpooledRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-06-2002 12:19 AM
Factory Pipe sizes? funscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-23-2002 04:08 AM
Pipe sizing for turbo setup??? mikec Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-17-2001 06:13 PM
Stock Exaust piping size PLEASE 25psi General Forum Archive 5 01-10-2001 12:10 AM
