Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 03-16-2006, 09:13 PM   #1
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
Default Will a '95 L 5MT swap into my '98 L 4EAT??
I know the answer is anything is possible. But will it be plug and play?
A friend has totaled his 1995 Impreza L Coupe (EJ18 with 5MT). It just got a new clutch and everything. He's offered me the whole car for $300, making it very tempting for me to not buy the pistol I've been wanting and just buy this car as a doner car.
My question is, would the 5MT swap into my 1998 Legacy L if I got a EJ22 5MT ECU? I'm wanting this to be plug and play so I could possibly turn the conversion in a 5 day period. However, if anyone has the wiring diagrams I'd need to make it work correctly, I would probably still do it.
Perdue is offline   Reply With Quote
Old 03-17-2006, 11:47 AM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yeah.. it can be done you don't need the ecu ... i would want a tranny that was newer ..
the biggest pain is changing the peddle box .. you then move the nuteral postion switch to the clutch peddle switch ...
look around in the transmission fourm
Old 03-20-2006, 11:39 PM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
its been done, like he said, peddle box is a PITA!!!! if you can, remove steering column, it will help tons. $300 for all those goodies is nice....but i would do some searching to see if the impreza EJ18 5MT gear ratios are different from the legacy trannys....i dont think they are but they might be. legacy afterall has/had the EJ22 with more power. but it will bolt right up. as far as wiring goes, you will need to locate the wire that tells the ECU that it is a MT ECU or AT ECU. its only 1 wire, you basically cut it and it thinks its a manual ECU now. then you can get rid of the TCU wiring if you want to. do some searching and you'll find your answers. also, look for "5MT and AWD swap" by legacy777, his website has all the info you need to know.
~Josh~
Will this motor swap into my 96 L? emsmap Normally Aspirated Powertrain 4 02-22-2010 02:19 PM
2003 EJ20 Swap into 96 Legacy GT 4EAT turboL Subaru Conversions 1 02-27-2009 12:19 AM
Legacy GT 5 speed Sportshift Auto swap into 02 WRX w/4EAT??? WRX_02_227 Transmission (AT/MT) & Driveline 1 03-05-2006 06:42 PM
02 WRX wagon 5MT going into my 04 WRX Auto Lowjack Subaru Conversions 0 08-07-2003 02:07 PM
will '99 style headlamp housing fit into a '98? stylth007 Technical Forum Archive 5 10-03-2000 12:44 AM
