Old 03-16-2006, 11:33 PM   #1
boardCrazy
Member#: 109248
Default wiring diagram?/color of acc wire for radio
in a 2003 impreza TS, what is the color of the accesory wire for the radio. I am installing an fm modulator for an mp3 player and don't have any wiring diagrams.
also, does anyone know how the radio bezel comes off, is it just held on with clips? thanks
boardCrazy is offline   Reply With Quote
Old 03-17-2006, 01:11 AM   #2
iownaspec
Member#: 34154
1/2 jew crew
should be red. red is acc/switched, yellow is constant, and black is ground. i dont think it changes for any car or audio manufacturer
iownaspec is offline   Reply With Quote
Old 03-17-2006, 11:49 AM   #3
InsaneZane1
Member#: 82719
2004 PSM STi
If your bezel is mounted anything like the one on my 04 STi (actually the climate control panel), then yes it is just held on with clips. I just use a common screwdriver and wedge the top part of it out first, then pry the rest of it out by hand from there.
InsaneZane1 is offline   Reply With Quote
Old 03-17-2006, 05:53 PM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
bC, check out the forum sticky for links to OEM connector wiring diagrams.
Old 03-18-2006, 09:26 PM   #5
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Those colors apply only if using an after-market wiring adapter (which I strongly recommend). If tapping directly into the car's harness, the colors vary depending on model and year.
See this pin-out for the Impreza/WRX radio connector, with wire colors
The first link in this sticky thread FAQ and Threads of Note- Read me first! will lead you to the above pin-out (in case you need to find it in the future). It also has information on opening the dash and removing the radio.
SVXdc is offline   Reply With Quote
Old 04-12-2008, 01:32 PM   #6
deanarammalamma
Member#: 177295
2005 "Saabaru" 9-2x
My 2005 Saabaru 9 2x HU will only produce audio in ACC. Any ideas?
(sorry about all the posts, but I'm new and didn't know where to get my 3 replys before I could post a new topic)
deanarammalamma is offline   Reply With Quote
2002 Accessport wires diagram ? (I have lose wires in the cable) peeledback7777 AccessPort 0 10-26-2006 09:48 PM
Looking for JDM V7 wiring diagram and '01 RS wiring diagram moss Subaru Conversions 1 07-06-2006 10:52 PM
Wire function/color of extra plug behind radio? Jard Electrical & Lighting 3 08-16-2004 12:45 PM
Wiring diagrams/colors/locations for alarm install on 99 2/5rs wastgate Car Audio, Video & Security 0 06-22-2003 08:44 PM
Installing FogLights (continued from Elec. Wiring Diagram Request of 7 June) Bob OM,Md Technical Forum Archive 4 06-12-2000 05:13 AM
