Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 03-17-2006, 12:58 AM   #1
gopsu
Member#: 96448
02 WRX VF34
Default Cobb stage 2.5 map - reliability
For those with cobb stage 2.5 kit, how is your car operating with OTS v1.30 map and upgrades in terms of mechanical reliability. I am thinking about either using the rather "conservative" 2.5 map or getting a custom Protune.
My only concern is having a reliable 250-260whp WRX even if it's not optmized in terms of making big power. All I care is having a reliable car with enough power to pull on stock STi
Lastly, my car is also equipped with STi TMIC and a header. Will Cobb stage 2.5 map be suitable or will custom map be necessary? I will be getting pinks and VF34.
gopsu is offline   Reply With Quote
Old 03-17-2006, 01:10 AM   #2
remowgn
Member#: 41149
04 09 FXT
SSM
I've been running the Cobb 2.5 map since july of last year with pinks and a VF39. A couple of months ago, I added a STI TMIC. I also beat the piss out of it every day. It does run rich, but I haven't had a single problem with it. The cool weather here has been really beneficial since we only get 91 octane... with the 93 you should be fine. You should be able to pull on a stock STI once you get it all set up.
I don't know about headers since I don't have em.
remowgn is offline   Reply With Quote
Old 03-17-2006, 01:14 AM   #3
WRXBob
Member#: 12455
02 WRX
My car running great with the OTS 1.3 map, VF30, STI IC. Smooth and with good power (butt dyno) I know it has some power to be made, but it has been reliable (knock on wood). You want to pull a stock STI? it has much better gearing and more torque, and where can you find a stock STI?
WRXBob is offline   Reply With Quote
Old 03-17-2006, 01:16 AM   #4
gopsu
Member#: 96448
02 WRX VF34
Interesting you are running VF30/34 map on a VF39. How many miles do you have on your car since the upgrade?
Old 03-18-2006, 03:43 PM   #5
gopsu
Member#: 96448
02 WRX VF34
Did you guys have to upgrade the plugs to a one step colder one? I do not recall Cobb requiring them as part of Cobb stage 2.5 upgrade...
Old 03-19-2006, 01:58 AM   #6
Payback
Member#: 41328
2003 WRX Sedan
SOLD - 2/07
I've been running the OTS map since Wednesday with no problems. OK, I know that doesn't mean crap, but initial impressions are very good. It does run a little rich though at WOT. New plugs are not required.
The OTS maps are designed to work in a variety of locations under a wide range of weather conditions and meant to be able to account for variations in cars. A ProTune is not required, but will adjust for your specific car.
Payback is offline   Reply With Quote
Old 03-19-2006, 06:20 AM   #7
sjrhee
Member#: 68010
2004 WRX w/ Cobb 2.5
been running mine since I bought my car new, installed it at 10k and now I have 40k on the ots map. I run it hard in the canyons and wide open roads and it's still running great. I changed my plugs for 1 step colder just in case, didn't need a fuel pump either unless you're getting a protune to compensate for the rich mixture.
sjrhee is offline   Reply With Quote
Old 03-20-2006, 01:48 AM   #8
gopsu
Member#: 96448
02 WRX VF34
sjrhee, mind to post PN of one step colder plugs you got? are they readily available from autozone? thanks...
Old 04-09-2006, 08:38 PM   #9
psyber_0ptix
Member#: 60671
1992 Miata
i dynoed at 273whp on ots map, working on gettin gmy graphs back
psyber_0ptix is offline   Reply With Quote
Driving with VF39 on Cobb stage 2.5 map without JDM pinks... gopsu AccessPort 16 08-01-2006 10:50 PM
Anyone with OTS Cobb stage 2.5 map driving with VF34 and header? txl146 AccessPort 2 03-19-2006 11:34 AM
looking for Cobb stage 2.5 map swift2fly Engine Management & Tuning 2 05-11-2005 12:12 PM
anyone have timing maps for cobbs stage 2.5 vf34 map? blackie Engine Management & Tuning 0 03-31-2005 01:26 PM
Cobb stage 2.5 map with VF30 install WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-03-2004 05:02 PM
