Old 09-08-2000, 10:17 PM   #1
Peter Hadfield
Member#: 1890
1990 Legacy L Sedan
Champagne Rally Car #212
Angry Overheating
I am currently fighting overheating problems with my 90 Legacy L model. I have already had the thermostat replaced. I cannot think of any other reason why this problem continues to occur. The radiator was replaced just before I bought the car. No coolant is leaking, with the exception of when I shut the car down when the temp goes too high, and coolant is pushed out of the reserve coolant tank. Any thoughts or suggestions would be appreciated. Thanks!
Peter Hadfield is offline   Reply With Quote
Old 09-09-2000, 12:57 AM   #2
Ben
Member#: 423
2002 WRX wagon
Post
Any sounds come out around the front?
I would think about the water pump.
Have you change the water pump when you replace the timing belt?? If you didn't , then it maybe the problem since you said you already change the thermost and coolant in the tank!!!
Ben is offline   Reply With Quote
Old 09-09-2000, 04:44 AM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Arrow
Did you change the radiator cap? Maybe it's no longer holding the proper pressure. One thing you may want to do is this. When the car is cold remove the radiator cap and have someone start the car. Watch the level of coolant. If it's forced out very fast when it's first started up, you may have a block or headgasket leak. The combustion gas gets forced into the coolant and pushes it out. I've seen this happen but not on a Subaru.
I'm thinking water pump too. Those are just some other thoughts.
[This message has been edited by Peaty (edited September 09, 2000).]
Peaty is offline   Reply With Quote
Old 09-09-2000, 02:34 PM   #4
smartservice
Member#: 842
1969 Subaru 360
Post
Here's a step by step on checking your cooling system.
1.Check the vehicle coolant level stone cold in AM in radiator and resevoir. If it is low at all top it up (you may have to remove the air purge plug on the other end of the radiator to make sure it's fully purged of air pockets.
2. With a cooling system pressure tester pressurize the system to 17 psi. Inspect all hoses,clamps, water pump, radiator seams for any sign of coolant leakage.(You can bypass this step if you don't have a pressure tester but sometimes it's necessary to weed out those slow leaks.)
3. With cap on start vehicle and let idle.(all accesories off) Feel the upper radiator hose. It should be cool to the touch. Keep feeling it while monitoring the temp gauge. When the thermostat opens the hose will start getting hot rather quickly. At the point you feel it is getting hot check where the temp gauge is sitting. It should be at 1/3-1/2 way up. Continue to monitor the gauge to see when the electric fans kick in. The gauge should read no higher than 1/2-5/8. After the fan cycles on and off once turn the AC on to make sure that both fans come on.
4. If all checks out fine but your problems persist then the next step will require an exhaust gas anaylizer.(most repair shops have one) With the car cooled down again and the radiator cap off, hold the probe of an exhaust gas anaylizer above the throat of the radiator and also above the coolant recovery tank. Be carful not to suck up any coolant as it will ruin the equipment. If you have a failed head gasket or crack in the block or head (very unlikely) you will detect Hydrocarbons (HC's) coming out of the radiator and in the recovery bottle. Anything above 8 or 10ppm HC's is the sign that exhaust is getting in the cooling system.
Hope this helps solve your problem
Mike Corbin
smartservice is offline   Reply With Quote
My STI is overheating when the AC is on and the AC fan doesnt work, why overheating? nicksamba_18 Service & Maintenance 1 03-09-2015 09:55 PM
overheating sti 6mt? cowboy_Rob Motorsports 32 06-08-2010 08:33 AM
My STI is overheating when the AC is on and the AC fan doesnt work, why overheating? nicksamba_18 Off-Topic 9 08-21-2009 07:37 PM
('93-'01) Overheating Problem.... Help! (kinda long) but important SubaTubaru Impreza Forum 15 05-27-2001 03:34 AM
#$@! car overheated on me tonight! Patrick Olsen New England Impreza Club Forum -- NESIC 19 03-02-2001 09:51 PM
