Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 03-17-2006, 02:12 PM   #1
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Default EGT probe in stock manifold.
I plan to have my stock manifold (#3 cyl) drilled and tapped for the Defi EGT probe. I have heard that there can be problems with the probe seizing in the cast-iron manifold over time. Is there something (like NeverSeize) that can be applied to the threads that will prevent this, and will hold up to the heat?
bcblues is offline   Reply With Quote
Old 03-17-2006, 02:15 PM   #2
hondaeater69
Member#: 60324
The probe is screwed into a bung, bung is stainless steel, the bung is tapped into the manifold and not removed.
Old 03-17-2006, 05:27 PM   #3
bcblues
Member#: 17256
04 STi
So the Defi EGT probe will come with a stainless steel bung that is threaded to install in a drilled/tapped hole in the cast iron manifold?
Old 03-17-2006, 05:30 PM   #4
bcblues
Member#: 17256
04 STi
The SS bungs that I have seen were all the type that you welded on to a tubular (not cast iron) manifold.
Old 03-19-2006, 02:53 PM   #5
hondaeater69
Member#: 60324
there are both available. . .i don't know about the defi.
Old 03-19-2006, 04:39 PM   #6
bcblues
Member#: 17256
04 STi
hondaeater69: I have been unable to source such a "screw in adapter" for use with cast iron. Do you know of a source?
Old 03-20-2006, 03:50 AM   #7
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Every bung I've ever had that was meant for installing into a tapped port was made of brass and yes, you can use antiseize on the threads to prevent it from seizing.
If your sender didn't come with the bung adapter (what kind of hokey gauge kit doesn't?), get new ones from www.egauges.com
nhluhr is offline   Reply With Quote
Old 03-20-2006, 02:07 PM   #8
bcblues
Member#: 17256
04 STi
Thank you! I expect my Defi will come with what I need!
Old 03-21-2006, 02:56 AM   #9
drez14
Member#: 57318
the defi gauge will come with a threaded bung to screw into the manifold. I drilled and tapped the cast manifold. It works fine with no sign of leaks
drez14 is offline   Reply With Quote
Remove EGT Probe from Iron Manifold when Hot/Cold? whtlegacy Service & Maintenance 4 10-27-2008 01:13 AM
EGT probe in uppipe or manifold? andygold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 08-23-2006 05:06 PM
is there an EGT probe in stock STI uppipe? RossWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-14-2006 07:51 PM
egt probe in up-pipe or manifold?? Jerry Seagreaves Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-24-2003 01:26 AM
Anybody Local with EGT probe in Manifold? jamz New England Impreza Club Forum -- NESIC 3 02-08-2002 12:17 PM
