Old 03-17-2006, 09:10 PM   #1
dlowman
Member#: 22998
2004 WRX STi
GT35R 572 whp 93/meth
Default issue with TPS
I am having an issue with my tps going to 0% in the factory ignition logs of the utec. I am not getting any other check engine codes. I am running this on top of an ecutek and have basically made the factory ecu stupid above 3000 rpm. The issue seems to only happen when I am under boost. The car is an 04 Sti with numerous mods. So far I have swapped out the throttle body and position sensor. And even swapped out the utec thinking it was a bad utec. I am out of ideas. The unusual thing is that the car will stop doing this the more you drive it. After about 10 mins of driving the issue seems to go away. The issue is worse when you first start to drive it.
Thanks,
Dan
dlowman is offline   Reply With Quote
issue with TPS dlowman UTEC 3 03-20-2006 10:22 AM
issue with tps dlowman Normally Aspirated with bolt-on Forced Induction Powertrain 2 03-18-2006 09:30 AM
issue with tps dlowman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 03-17-2006 09:10 PM
RS-T with TPS malfunctioning... WRX 555 STi Normally Aspirated with bolt-on Forced Induction Powertrain 5 11-05-2003 06:35 PM
Problem with TPS voltage/Zex? Supapooh Normally Aspirated Powertrain 12 03-28-2003 12:41 PM
