Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 03-17-2006, 11:46 PM   #1
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
97 Ford Ranger on Bags
Question only one fog light working????
hey guys,
so i bought a set of fog lights from a memeber off of here,
got a pretty good deal, but his car was an 03 and mines an 02... so unfortunetly the plugs didn't match so i went to subaru, they tried to sell me a whole new set of lights (they don't sell just the plug), so i just went to Hobby Shack and picked up a set of Dean's Ultra plugs (i've used them on my RC cars and know they work great) and snipped and re-soldered everything.... my problem is that when i was doing this, being the dumbass that i am, i didn't disconnect the battery, and when i was soldering the right side plug, it sparked real quick and that was it... i thought nothing of it, but now the light won't come on i checked the bulb to make sure it worked, and it does, so i'm guessin i popped the relay, but i'm not sure... the left light works fine.... so i guess my question is, are there separate relays for each fog light??? and if so where are they located???
thanks
02
WRX Sedan
TRinityMtrSprts is offline   Reply With Quote
Old 03-18-2006, 01:45 AM   #2
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
Silver w/ JDM Roof Vent
There is only one relay for the fogs, the relay is located infront of your left knee.... Thats weird. If one is working, why isnt the other. You could try replacing the relay. Make sure its wired correctly as well. Good luck man.
Yesitsdrew5310 is offline   Reply With Quote
Old 03-18-2006, 09:10 PM   #3
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
thanks man... ya i double checked today to see if i perhaps wired it backwards (i've been known to make stupid mistakes like this :P) but it everything checked out... guess i'll try a new relay... i did a search and saw something on the lines of subaru uses a special relay that you can only get from them??? or did i read it wrong???
Old 03-18-2006, 10:44 PM   #4
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
Well if the relay is only available from Subaru then I give you this site: https://www.subarugenuineparts.com/oe_parts_cat.html
Subie_gal on here runs the site. You could probably ask her.
Just go pull the relay take it to autozone or something and see if they have simlar ones.
Good luck man!
Old 03-18-2006, 11:38 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
based on the wiring diagram, if at least one works, then the relay is fine (the two foglights are on the same power lead from the relay, and are connected in parallel) - check the harness - it's probably shorted out somewhere.
I am going to assume that you have already checked that the bulb isn't blown...
DrD is online now   Reply With Quote
Old 03-22-2006, 12:26 AM   #6
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
well, i went over the wiring again today and thought it might be a bad ground (not sure why i didn't think of that first) so i unpluged the Deans plugs and put a wire on the negative side on the male end and half way pluged them back in and ran the other end to a ground on the inside of the passanger side quarter panel and tried it... and what do ya know it worked! ... so i proceeded solder the new negative to the plug and bypass the old one, then i tapped into the ground wire and thought it was all good... nope... freakin thing didn't work again!!! so i came to figure out that the plug was bad, if it was only a 1/4 of the way in it would work??? but all the way in and no deal??? so i unsoldered both plugs and replaced them both with old ones off my R/C car and now the light works with old ground and all.... so i guess these new Deans plugs are made like shyt!!! cuz the male end is pretty much melted from the soldering iron (the stupid thing is that i barely had the iron on the damn thing!!! just enough to liquify the solder and that's it!!!). so in the end, no bad relay, no bad ground, wiring harness was fine it was just the stupid freakin plug!!!
i swear i've had the worst luck with this stinkin car (never buy ebay cars!!!)
thanks again for all the input guys
ERic
anybody has extra one fog light cover for 04 wrx right side. pengmao MWSOC Private Classifieds 1 03-02-2008 04:20 PM
So... Am I the only one still at work? Strider Off-Topic 120 12-22-2006 04:33 PM
Help! I blew out one fog light on the way to the Doo Wops jonnysubby North West Impreza Club Forum -- NWIC 11 03-07-2005 07:58 PM
Only use fog lights? TecnoWRX Electrical & Lighting 2 02-16-2005 08:25 PM
Will my00 fog lights work with a WRX? BeavisNuke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-07-2002 08:21 PM
