Old 09-28-2001, 09:06 AM   #1
Haven
Member#: 95
2006 Wrx
Crystal Gray
Question throttle body spacer
has anybody thought that a throttle body spacer would do any good? i was reading about it on "poweraid" web page they don't have an application for our cars, but i would think if enough people e-mailed them they might make one for us.
Haven is offline   Reply With Quote
Old 09-28-2001, 09:16 AM   #2
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Care to elaborate or provide links to this "spacer" What advantages does this claim?
I've heard of it for old carberated cars, but never newer ones... Please, do tell.
omahasubaru is offline   Reply With Quote
Old 09-28-2001, 09:25 AM   #3
Haven
Member#: 95
2006 Wrx
Crystal Gray
go to poweraid.com they explain it alot better than i can i can't even create a link to it.
Old 09-28-2001, 10:29 AM   #4
synapse79
Guest
Member#:
why would you want to move the throttle body further away from the intake ports on the head, if anything, it should be moved closer.. if possible..
Old 09-28-2001, 11:52 AM   #5
Rubasu
Member#: 1418
MY00 2.5RS
The spacer creates a venturi effect. It swirls the air going into the intake and into the combustion chamber making it easier to atomize. I have seen these on alot of carb. applications but have never seen one on a TB app. that could be interesting to see the results...
Rubasu
Rubasu is offline   Reply With Quote
Old 09-28-2001, 03:39 PM   #6
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
For GM's, some companies make TB spacers and air foils for the dual TB setups.
adeck is offline   Reply With Quote
Old 09-30-2001, 01:45 AM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default well
I think there are rellegedly a couple of benefits to a throttle body spacer. Larger plenum volume and cooler intake air temp for starters. I actually made one of these for my own car. I have not installed it yet as I am trying to figure a way to inexpensively duplicate it from the master I made. I am considering IMP or phenolic resin but I havent had time to find a someone with the equipment for these processes. It was a bit of a PITA to make even tho I have drill press etc. The tb bolts are in a rectangular pattern even tho by eye it initially appeared square. It is for my 2.2L and I dont know if the tb bore is the same on the 2.5L(I doubt it.)
subysouth is offline   Reply With Quote
Throttle body spacer PARANOID56 Normally Aspirated Powertrain 13 12-14-2005 08:51 PM
Throttle body spacer for 2.2??? Jaredm82 Normally Aspirated Powertrain 8 07-09-2004 12:58 PM
Nitrous Throttle Body Spacer Joncas Normally Aspirated Powertrain 5 07-15-2001 04:06 PM
