Old 03-18-2006, 01:02 PM   #1
wgknestrick
Member#: 32576
04 STI
Default STI Cam Sprocket/Gear Removal??
I've searched and haven't come up with much on this subject.
1. Gears are brittle, plastic, torqued to 72ft-lbs, and expensive
2. Special Subaru ST tools to remove these are not sold by dealers and sell for $180 and $120 respectively by Kent Tool Co.
3. Many people here have built engines and removed them.
4. STI AVCS cams don't have the uber convienent wrench flat on the cam shaft itself like the non-AVCS cams.
5. Subaru engineers are morons for not designing a simple wrench flat in the cam shafts or at least a better way to remove these. I shouldn't have to buy $300 worth of wrenches to take off $600 worth of parts.
What do we do?
Best idea I have is impact wrench on the nut, while securing the gear with a strap wrench.
The problem with this is clearence between gears and damage to teeth. I don't think I can destroy the timing belt to wrap around a gear (to protect it) AND still get a strap wrench on it. Has anybody made a "strap wrench" out of a timing belt itself to do this?
wgknestrick is offline   Reply With Quote
Old 03-18-2006, 03:33 PM   #2
sjl1614
Member#: 56791
06 OBS
Well there is a flat spot on the cams, i've them many times to remove/install cam gears.
sjl1614 is offline   Reply With Quote
Old 03-18-2006, 04:47 PM   #3
Crawford Performance
Member#: 42075
Wrap your old timing belt around the crank and one side of the cam gears. Use a vice grip to clamp the belts teeth together at the crank....You now have an inexpensive way to remove your cam gears with out damaging the gears or the cams
Quirt Crawford
www.crawfordperformance.com
Crawford Performance is offline   Reply With Quote
Old 03-18-2006, 10:54 PM   #4
wgknestrick
Member#: 32576
04 STI
WRX cams =/ AVCS cams
Anyways,
Thanks Quirt
Old 03-18-2006, 10:57 PM   #5
wgknestrick
Member#: 32576
04 STI
Is an impact wrench still a "good" idea?
Old 03-19-2006, 02:57 AM   #6
InfamousDX
Member#: 25413
It's probably going to have to be a pretty serious impact gun. I think I read someone broke a 3/4" socket. I had great success with like... an 8 foot breaker bar and my heaviest friend hanging on it. Times like that I wish I had the Subaru removal tool.. but Quirt's idea is news to me and I wanna try it next time.
Old 03-19-2006, 08:53 AM   #7
sjl1614
Member#: 56791
06 OBS
The last set of wrx cams had flats on the cams also.....
Old 03-19-2006, 10:07 AM   #8
wgknestrick
Member#: 32576
04 STI
When did we ever start talking about WRX cam gears in this thread?
Old 03-19-2006, 10:39 AM   #9
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
it takes some serious power to remove gears from the cams...they could not be moved from mine. A place where i had my cams taken off ordered a tool to do it, broke the tool, broke my gear and finally got it off and put a new gear in it. they even tried Infamous' way with a bar and people on it...no luck
BuggeyEYED is offline   Reply With Quote
Old 03-19-2006, 01:55 PM   #10
Peeblesmx445
Member#: 92202
1000 ft/lb impact gun, 5 minutes and call it a night
Peeblesmx445 is offline   Reply With Quote
Old 03-19-2006, 08:40 PM   #11
ejsportcom
Member#: 88905
900ft/lb gun didn't work for me, i had a 6ft pole with about a 250lb friend of mine hanging on it to have them come free.... it was a mess
ejsportcom is offline   Reply With Quote
Old 03-19-2006, 09:16 PM   #12
Peeblesmx445
Member#: 92202
worked or me without any problems.
Old 03-19-2006, 09:25 PM   #13
wgknestrick
Member#: 32576
04 STI
Got them off and here is by far the best and most descript way to do it.
Leave all the timing belt guides on the engine.
Dont' remove the timing belt.
Make sure you have the timing belt/engine in proper location as to not damage valves.
Put a breaker bar on the crank bolt to hold the crank/belt cams in place
Use another breaker bar on a HARDENED allen socket (broke a craftsmen in about .2s)
The gear bolts break super easy this way, and you don't ruin your timing belt. We had no problem with it jumping teeth or anything.
Most impact guns can't even touch these bolts, as these bolts just laughed at ours.
Old 03-20-2006, 04:12 PM   #14
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
I tried it that way and it keep jumping teeth. I think I'll try it the way Quirt mentioned, even though I have the tools ordered.
CK02WRX is offline   Reply With Quote
Old 03-20-2006, 07:55 PM   #15
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
I've never removed cam gears from a Suby, but I have taken them off of other motors. I remove one cam cap at a time and slip some folded paper under the cap and re-torque the cam cap. This way the cam is held in place and then you can un-bolt the cam sprocket with an impact gun.
eastcoastbumps is offline   Reply With Quote
Old 03-20-2006, 09:10 PM   #16
wgknestrick
Member#: 32576
04 STI
If you keep the belt guides on the engine, it should keep the belt on the gears. You want a slow, gradual force on the breaker to prevent teeth jumping. We have a pretty serious timing belt on our cars that should hold everything in place.
Once we figured this out, it took us about 1min to break all 4
Old 04-05-2006, 05:38 AM   #17
jdmej20
Member#: 33186
2002 wrx impreza
I LOVE GOOOOLD!!
I used a 1 1/8 wrench to hold the Cam as tight as i can and my buddy used a breaker bar with the Allen socket and we got them off pretty easy. This was on a JDM ver.8 motor too.
jdmej20 is offline   Reply With Quote
Old 04-06-2006, 08:23 AM   #18
BensonRST
Member#: 106895
1999 RS-T
Custom Charcoal
the thing about using the crank bolt to keep the cams from spinning, is that it tightens the **** out of the crank bolt. then you have even more trouble if you need to remove that. if you need to take a cam gear off, just buy a new car. hahaha. what make them so tight, 6000rpm clutch dumps...? haha
BensonRST is offline   Reply With Quote
Old 04-06-2006, 12:35 PM   #19
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
You can't use the 1 1/8 wrench on an STI. I did it this way. I put two of the flywheel bolts in and used a wrench between them that was long enough to touch the engine stand mounts. That way the crank bolt doesn't tighten and you can use both hands to loosen the cam gear bolts. It also makes it a one person job instead of 2+ like others have needed. I also found out that the Snap-on 10mm 1/2" drive hex socket was very strong and would not break like craftsman and several other that I broke. It lists of $20 but its worth it because you break several $10 sockets and never get one bolt loose.
Old 04-06-2006, 01:34 PM   #20
02Toyowrx
Member#: 56520
Using a timing belt works about half the time. I ended up buying the cam tools from a source I found .. they were about half the price as the SPT tools and I hear they are better quality (havent seen the SPT tools in person)
02Toyowrx is offline   Reply With Quote
Old 04-06-2006, 08:01 PM   #21
BensonRST
Member#: 106895
1999 RS-T
Custom Charcoal
not to sound like a newb or anything, but i've never seen avcs heads with the cover off. is that stuff on intake cam the avcs? does it work off an actualy cam degree change instead of a lobe profile change like vtec does?
Old 05-03-2006, 01:48 PM   #22
rbahr
Member#: 40671
2006 STI, Outback XT
Grey, Blue
Hi 02Toyowrx,
Can you post the source/part number for these tools?
TIA
Ray
rbahr is offline   Reply With Quote
Old 05-03-2006, 04:15 PM   #23
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
Originally Posted by rbahr
Hi 02Toyowrx,
TIA
Ray
I too would like to know the source/part number. Can you please PM this information.
Rick
ami2fst4u is offline   Reply With Quote
Old 05-03-2006, 04:33 PM   #24
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
After removing and installing the cam gears using the old timing belt, vise grips, and a good 10mm hex socket I'm glad I didn't waste any money on the tools. However, if you want them you can get them from http://subaru.spx.com/index.asp WRX CAMSHAFT SPROCKET WRENCH ST 499207100 and ST 499207400, Sti CAMSHAFT SPROCKET WRENCH ST 499207400 and ST 499977500. Most of the engine builders don't use the tools. I was set on using them until I talked to a few professional engine builders. I have heard they are around $200 and to me that is a waste since there are so many ways to remove the cam gears without them.
Old 05-29-2006, 12:21 PM   #25
Sadisticracer1
Member#: 96724
i am currently in the same dillemma my gears dont want to come off. obviously i am going to try some of the ideas mentioned for the removal in here. my question is whos making the aftermarket replacements for the 05 sti and how i can get my hands on them. i have looked almost everywhere and i cant seem to find the actual gears, its always shafts, no gears.
Sadisticracer1 is offline   Reply With Quote
04 Sti Cams and gears xilles Engine/Power/Exhaust 6 12-23-2008 08:59 PM
Any other ways to remove the cam sprocket on a sti without a special tool? ride_the_pony69 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-09-2006 05:20 PM
wtb jdm sti cam sprockets wearejoy Private 'Wanted' Classifieds 8 01-22-2006 07:03 PM
WTB: Sti Cam sprocket (cam gears) HD-sw20 Private 'Wanted' Classifieds 0 09-30-2005 10:05 PM
Cam shaft gear removal? HELP! johndingk2 Legacy Forum 2 01-16-2005 10:27 PM
