Old 06-19-2006, 10:24 AM   #51
InfamousDX
Member#: 25413
Originally Posted by MSR
Drill it out, slow drill speed as the bolts are hard and drill it fast and the drill goes blunt and bolt work hardens, once you drill it enough the head falls off, the threaded part screws out with fingers.
They are tight due to the surface area of the flange.
Will one of those DeWalt cordless drills work or do I need something high powered?
Old 06-19-2006, 05:15 PM   #52
MSR
Member#: 20842
05 Spec C Type RA
I never had any luck with rattle guns, even the bigggest snapon battery gun doesn't even look at it, you need some big bars and allen key arangement.
MSR is offline   Reply With Quote
Old 06-19-2006, 08:10 PM   #53
ejsportcom
Member#: 88905
and when all else fails, a welder....
ejsportcom is offline   Reply With Quote
Old 06-19-2006, 08:14 PM   #54
MSR
Member#: 20842
05 Spec C Type RA
I think drilling the head off is easier, even with welding something to it, it's still tight!
Old 06-19-2006, 08:27 PM   #55
ejsportcom
Member#: 88905
i guess it all depends on your situation, i had it set up like crawford had shown and it would not slip at all, plus i used the turbo bracket to hold the crank in place, then i welded a hammer to it (yes i know its a** backwards), and i put a 3ft pipe on the end of that and it came right off. its funny cause i don't have any good drill bits so when i tryed drilling it i ended up giving up after breaking like four bits. plus welding is more fun
Eric
Old 08-24-2006, 03:43 PM   #56
Member#: 106514
http://www.cobbtuning.com/pr-cam-wrench.html
We do not have a cam gear tool currently for the AVCS gears, but hopefully in the near to distant future. Having the correct tools really help the job go alot faster.
- J.
Jeremy@Cobb is offline   Reply With Quote
Old 08-24-2006, 04:11 PM   #57
txjunglist
Member#: 11926
2011 Outback Limited
Dark Grey
go to your local home depot and get one of these .. they work great for removing the rounded out cam bolts...
http://www.irwin.com/irwin/consumer/...IrwinCat100511
txjunglist is offline   Reply With Quote
Old 01-04-2007, 08:08 PM   #58
P0411
Member#: 130215
Well hell!!! I got them off, but now Im having a hard time getting the intake cams to line up with the cam gears? Any ideas?
P0411 is offline   Reply With Quote
Old 01-21-2007, 10:07 PM   #59
thejean
Member#: 17763
I tried this tonight. Got the two on the drivers side loose but one of the psg side is starting to strip out inside. I stopped before it got too bad (may still be salvageable. I am thinking of trying to source an 11mm allen and hammer it in there and try again. Do you think drilling would be easier/safer/better?
On a side note... I only read after I turned one cam pully about a 1/4 turn that you are not supposed to do this. Does this gurantee me that I will have bent valves?
thejean is offline   Reply With Quote
Old 01-22-2007, 08:06 AM   #60
txjunglist
Member#: 11926
Dark Grey
2 post up .... it works
Old 01-22-2007, 11:04 AM   #61
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
the valves close by default and the spring holding them closed is pretty strong so unless you're putting a lot of force behind turning the cam gears chances are the valves arent opening. if the gears are still on the timing belt and its slippingi then watch out though...
if your allen key is stripping you might want to think about using a bolt out kit or even cutting a notch across the head and trying to use some sort of flat head screwdriver if you can find a way to put a lot of torque on it.
i had no trouble getting these off myself, i cant understand what all this 900 ft. lb. air gun talk is all about. i had a 2 foot breaker bar or so and put a bit of weight onto it and i was finished all 4 in just a few minutes. i got 3 of them to break loose just be leaving the timing belt on, but the last one skipped teeth when i tried so i stopped that quickly and pulled it off a different way.
TROLL is offline   Reply With Quote
Old 01-22-2007, 11:20 AM   #62
thejean
Member#: 17763
Two of my three came off super easy. One started to strip and I haven't tried the fourth yet.
Sounds like I haven't bent any valves though... phew! ***wipes forehead***
Old 04-10-2007, 01:41 PM   #63
57sailplane
Member#: 101953
i tried the timing belt and vise grip around the crank and cam idea. it sliped. then i had an idea why not clamp the belt tight around the cam gear with another vise grip. it worked flawlessly. i think this will work on the tightest cam gears. thats just my opinion. i would post picture but dont no how. sorry
57sailplane is offline   Reply With Quote
Old 04-10-2007, 03:18 PM   #64
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I hate subaru cam gears...I personally have always wrapped the belt and used a big breaker bar as I rarely see an impact get the job done...lack of cfm if you ask me...
anyhow, sometimes they break, sometimes they strip...just luck of the draw
Old 04-10-2007, 03:19 PM   #65
thejean
Member#: 17763
I ended up griding down the cam bolt and pounding a socket over it. That worked but man, I thought I was hooped for a bit there. Easy outs did not work at all, they just snapped like twigs.
Old 04-14-2007, 12:56 PM   #66
wigglesxjr
Member#: 4293
Midnight Black Pearl
Seeing as I just had a timing belt change (less than 2k miles) and would like to try and reuse it, I'm going to admit defeat and break down and buy the cobb tool...
unless it is absolutely necessary to change the timing belt when I do a shortblock swap? It's a 2.0L-->2.5L swap wiht WRX heads.
-JT
wigglesxjr is offline   Reply With Quote
Old 04-14-2007, 12:58 PM   #67
Homemade WRX
Member#: 33782
96 bastard child
you won't need the cam gear tool as you won't be removing your cam gears...unless you are doing cams...
Old 04-14-2007, 01:51 PM   #68
kaos200
Member#: 2692
-JT
The way I read his post was he is swapping blocks so the cams WILL need to come out to remove the head bolts.
But the timing belt should be fine to reuse with 2k on it.
kaos200 is offline   Reply With Quote
Old 04-14-2007, 01:55 PM   #69
wigglesxjr
Member#: 4293
Yeah,I'm going to have to take off the heads, and the way I interpreted the service manual, the cam sprockets need to come off to gain access to the head bolts. bummer .
-JT
Old 04-14-2007, 03:09 PM   #70
Homemade WRX
Member#: 33782
96 bastard child
yup...missed that little bit on the 2.0->2.5
Old 04-16-2007, 09:40 PM   #71
spin'nall4
Member#: 135322
2004 Subaru Sti
Aspen white
i pulled my engine apart last year and i had this problem with the cam bolts. whoever has a motor where the bolts come off easy is lucky. somebody must have fallen asleep at the assembly line then. i got 3 out of 4 off with much effort. the third i had to drill out cause it stripped. i went through like 10 drill bits and half a day later the head of the fourth finally came off. for the first three i used two flywheel bolt installed in the crank with a wrench the was long enough to jam against the back of the block (the material of the block that surrounds the flywheel). i left the timing belt on and took up all the clearance on the timing belt guides. then i used a 3 foot breaker bar (3/4" drive w/ a matco reducer) and a 1/2" drive 10mm socket w/ piece of 10mm allen key cut off short enough to go into the socket and the allen bolt. it worked but i wish i had the real allen driver at the time. i bought 4 new bolts just to be sure and the correct allen driver (matco 10mm allen driver) for reinstall.
spin'nall4 is offline   Reply With Quote
Old 06-06-2007, 07:54 AM   #72
mddrum
Member#: 149606
It is time to replace the timing belt on my 2000 Outback wagon (110Kmi). I've had dealers quote $540 to $1200. Reading the chat, I get it's not easy. Have no knowledge with which to judge the estimates. Recommendations?
mddrum is offline   Reply With Quote
Old 06-06-2007, 08:11 AM   #73
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
agreed, The last time I did my cam gears it wasn't that bad, but I was obviously more experienced the second-third time around.
big breaker bar, make sure to not turn on an angle to avoid stripping, loosen them all before taking the belt completely off.
SBW is offline   Reply With Quote
Old 06-06-2007, 01:22 PM   #74
spin'nall4
Member#: 135322
2004 Subaru Sti
Aspen white
you dont have to take the cam gears off to change the timing belt, only to take apart the motor. the timing belt i imagine wouldnt be that hard while in the car. probably just time consuming because of the extent of things that have to be taken off. i did a new one with the new motor but it was on the bench so probably much easier.
Old 08-09-2007, 10:37 PM   #75
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Originally Posted by CK02WRX View Post
You can't use the 1 1/8 wrench on an STI. I did it this way. I put two of the flywheel bolts in and used a wrench between them that was long enough to touch the engine stand mounts. That way the crank bolt doesn't tighten and you can use both hands to loosen the cam gear bolts. It also makes it a one person job instead of 2+ like others have needed. I also found out that the Snap-on 10mm 1/2" drive hex socket was very strong and would not break like craftsman and several other that I broke. It lists of $20 but its worth it because you break several $10 sockets and never get one bolt loose.
I fully endorse this method but I would suggest leaving the other pulleys/guides in place. With them in place the angle is such that more of the gear teath and timing belt are engaged making it less likey to slip.
LiquidForce is offline   Reply With Quote
04 Sti Cams and gears xilles Engine/Power/Exhaust 6 12-23-2008 08:59 PM
Any other ways to remove the cam sprocket on a sti without a special tool? ride_the_pony69 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-09-2006 05:20 PM
wtb jdm sti cam sprockets wearejoy Private 'Wanted' Classifieds 8 01-22-2006 07:03 PM
WTB: Sti Cam sprocket (cam gears) HD-sw20 Private 'Wanted' Classifieds 0 09-30-2005 10:05 PM
Cam shaft gear removal? HELP! johndingk2 Legacy Forum 2 01-16-2005 10:27 PM
