Old 08-25-2008, 07:22 AM   #101
Optical NZ
Member#: 120463
Originally Posted by CK02WRX View Post
just want to say thanks for sharing this idea, used it today and it worked a charm!
Optical NZ is offline   Reply With Quote
Old 12-01-2008, 09:39 PM   #102
bruegge
Member#: 196246
Default Awesome post!
Hey guys, Just found this post and the vise grip idea worked great! I used another vise grip to lock the belt top and bottom together near the cam sprocket. The locked teeth keep the sprocket from turning and the crank acted as an anchor. Only needed one breaker bar (on the sprocket). Hope this helps!
Ray
bruegge is offline   Reply With Quote
Old 05-12-2009, 12:15 AM   #103
RR-racing
Member#: 41632
2004 Spec C
WRC blue
Originally Posted by Crawford Performance View Post
Wrap your old timing belt around the crank and one side of the cam gears. Use a vice grip to clamp the belts teeth together at the crank....You now have an inexpensive way to remove your cam gears with out damaging the gears or the cams
Quirt Crawford
www.crawfordperformance.com
Bad Idea, I just broke the passenger side exhaust (plastic) cam gear doing this.
No substitute for the right tool (unless you are very lucky).
Rafi
RR-racing is offline   Reply With Quote
Old 05-12-2009, 11:14 AM   #104
zombiedog
Member#: 25138
85 e30
PRIMERZ!
Don't listen to him.
He's a plant from the Subaru Tool Manufacturer.
Everyone keep using their old timing belts.
Nothing to see here.
zombiedog is offline   Reply With Quote
Old 05-12-2009, 11:40 AM   #105
txjunglist
Member#: 11926
2011 Outback Limited
Dark Grey
i put together a portable co2 tank ... crank that reg on it all the way up and hit those botls with a 1/2 impact and they come right off. 200psi
txjunglist is offline   Reply With Quote
Old 05-12-2009, 11:41 AM   #106
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Rafi
How on earth did you break the cam gear?!!! I've never seen that happen. Are you sure you were turning the correct direction?
Old 05-12-2009, 11:42 AM   #107
Homemade WRX
Member#: 33782
96 bastard child
who's impact sockets are you using?
Old 05-12-2009, 01:10 PM   #108
txjunglist
Member#: 11926
Dark Grey
believe it or not I use the cheap ass OEM brand from oreileys
Old 05-12-2009, 05:31 PM   #109
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
If you clamp the belt this way it doesn't try to turn the crank when you put torque on it:
Koken 10mm hardened allen and a 30" breaker bar made short work of them.
Dan Cech is offline   Reply With Quote
Old 05-17-2009, 09:23 PM   #110
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Here's my setup for breaking mine loose. I jst left the belt on with tensioner. Didn't skip any teeth (uh, that would be bad!), but I started to see some belt flex on the driver's side intake (the one with the most valve spring load when the engine is timed). Hope I wasn't taking too big a risk...
Frank
Frank A is offline   Reply With Quote
Old 05-17-2009, 09:32 PM   #111
zombiedog
Member#: 25138
85 e30
PRIMERZ!
That method is bad. Waaay too easy to skip teeth and bend a few valves.
I'm sure you can get away with it a bunch of times but it's that one time that'll cost you.
Old 05-19-2009, 04:46 PM   #112
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
Yeah, you're going to pull the belt anyway, much safer with all the valves closed and pistons at half mast.
Old 06-13-2009, 02:53 AM   #113
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
what do i do with a broken cam? and where can i get the cam gear tool?
slava from goshen is offline   Reply With Quote
Old 07-19-2009, 07:20 PM   #114
swr999
Member#: 171928
2005 STi
Originally Posted by charliew View Post
... If you need a hammer on an aluminium motor you need to get a different occupation.
Originally Posted by 555ideways View Post
Seriously! This isn't a lug nut on a diesel truck! There's a cam back behind that bolt.
Originally Posted by Element Tech View Post
Guys, never hit the sprocket bolts with a hammer. You can easily damage the cylinder head and break the camshafts centering flanges.
Some perspective: The two Subaru techs who mentioned the hammer "shock treatment" have most likely adopted this technique because they do this pretty regularly, and their experience is that it helps.
I don't think they are suggesting to whale on it like a gorilla, but I worked for several years as a tech and I often used this method, when needed. The idea is that the bolt was torqued pretty good and has been sitting for some time. If you just try and gradually apply torque in the "loosen" direction, you often don't get anywhere. If you can put some initial 'shock energy' into the bolt, this will often let you then overcome that initial 'set'. This is why impact tools work.
I might also suggest that instead of tapping on the hex bit straight into the socket of the bolt, instead get a flat-end round punch, and tap the bolt at an angle at a few different positions around the bolt. Using this method I often found that stubborn bolts came loose without too much effort.
swr999 is offline   Reply With Quote
Old 07-19-2009, 09:27 PM   #115
555ideways
Member#: 36652
"Subaru tech" does not equal sensible mechanic. I've spent my fair share of time behind the scenes at dealerships and have seen the good and the bad. I'd give a flat rate tech credit for finding the fastest way around a job- but not the most sensible.
555ideways is offline   Reply With Quote
Old 07-19-2009, 10:24 PM   #116
swr999
Member#: 171928
2005 STi
^^^ Agreed. I guess I was just trying to point out that what might sound like a brutal approach can, in the right hands, solve an otherwise difficult problem. The mechanic still has to be using understanding and experience.
Old 07-20-2009, 02:01 AM   #117
madmax718
Member#: 172501
could just buy the tool.
madmax718 is offline   Reply With Quote
Old 07-21-2009, 11:30 AM   #118
Big C
Member#: 3586
2000 RSTI Rally Car
2012 STI SWP Hatch
I found this thread after I had fought with this for quite awhile..my upper gear bolts came out fine, but the lower ones were stuck....some decent ideas here, but I'm *really* not a fan of the vise grip/death torque approach. This puts too much stress on components never designed to take that much torque.
After trying the impact gun (IR TIMax - no joke gun), the "medium" death torque approach, and some heating/etc I was able to drill the bolts out in about 10 min (each) with a 7/16" Dewalt Titanium coated drill bit. So for $16 (new drill bit $12, bolts $2/each) I had the bolts out in 20 min with no damage to the motor at all. I highly suggest taking this route and using lots of oil/cutting fluid to keep the bit from dying. The part number for the lower cam sprocket bolt is 13199AA010 in case you want to get it online...
Big C is offline   Reply With Quote
Old 07-21-2009, 12:25 PM   #119
madmax718
Member#: 172501
the double wrap approach I think is ok. You'd be surprised at the amount of torque going through those cams. I wouldnt do it without first moving the pistons to neutral and letting the cams come to rest. You have to let them come to rest anyways. Unless your straight on the cams gear you still apply that kinda stress.. not that much difference.
Old 07-21-2009, 05:37 PM   #120
n2oiroc
Member#: 141952
15 legacy 16 wrx
good man!
n2oiroc is offline   Reply With Quote
Old 08-20-2009, 04:02 PM   #121
rjw5164
Member#: 220239
2002 ej257 WRX
A lot of good ideas here. Had to use more than one method to get all the cam bolts out of an MY02 EJ20.
Thanks guys.
rjw5164 is offline   Reply With Quote
Old 08-20-2009, 04:35 PM   #122
scprs
Member#: 172359
2005 STi
the belt thing didnt work at all for me. Used the tool (aka ST tools from subaru) and a 1000lb impact took five minutes taking all the gears off.
scprs is offline   Reply With Quote
Old 08-20-2009, 04:59 PM   #123
zombiedog
Member#: 25138
85 e30
PRIMERZ!
Good job...
This is the thread for people without the "tool and 1000lb impact".
But thanks for the update.
Old 08-20-2009, 11:05 PM   #124
nx2kta
Member#: 133247
06 Sti
wrb
you can also drill half inch in with a 5/16 drill bits and it will come off real easy
nx2kta is offline   Reply With Quote
Old 08-21-2009, 10:43 AM   #125
scprs
Member#: 172359
2005 STi
Good job...
Really? was that necessary i dont think so. Sorry for not specifying what tool meant. I fixed it for you.
04 Sti Cams and gears xilles Engine/Power/Exhaust 6 12-23-2008 09:59 PM
Any other ways to remove the cam sprocket on a sti without a special tool? ride_the_pony69 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-09-2006 06:20 PM
wtb jdm sti cam sprockets wearejoy Private 'Wanted' Classifieds 8 01-22-2006 08:03 PM
WTB: Sti Cam sprocket (cam gears) HD-sw20 Private 'Wanted' Classifieds 0 09-30-2005 11:05 PM
Cam shaft gear removal? HELP! johndingk2 Legacy Forum 2 01-16-2005 11:27 PM
