Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-18-2006, 02:46 PM   #1
01G_WRX_02
Member#: 89746
2002 WRX Stage 4
PSM w/Gold RPF1's on 255s
Default Problem with my maps.
ok i have my map 2 slot set at stage4 and when I turn the igniton on the check engine light flashes fast and the car wont start, So now i have to click my map selector to 1 and the light stops flashing and it starts, but i dont have a map on the #1 map selector, then i runs way to rich cause its the running a stage 4 car on the stock computer. so then while the car is running i have to click the map selector to the #2 spot where my stage4 map is and then it runs fine. its just when i go to start the car it wont start in the # 2 spot, and i get a flashing light. so whats the deal??
is also most like this from the utec manual
4. Security mode is selected by turning the switch to Map 7. This only disables the engine once the ECU and UTEC have been powered down. If activated, the security mode will continuously flash the CEL. To exit the security mode select an alternative Map.
01G_WRX_02 is offline   Reply With Quote
Problem with any map other than stock. SubiSam Commercial ECU Reflashes 0 11-26-2008 11:06 PM
Can I overwrite an ap fuel map with my map? kileryoyo AccessPort 1 11-02-2007 01:27 AM
Problem with switching maps GlenCastleberry AccessPort 3 12-09-2006 08:24 PM
Need some help with a problem with my knee StuBeck Off-Topic 65 01-12-2006 12:24 PM
Diagnose my problem with my 2nd gear FraudulentNeon Transmission (AT/MT) & Driveline 6 05-11-2004 06:29 PM
