Old 03-18-2006, 03:06 PM   #1
Jowrx04
Member#: 106619
2004 Impreza WRX Wag
Default Stock exhaust heat shield bolts
If I replace all the stock front exhaust heat shield bolts with stainless steel bolts will they not rust as bad as the stock one's? These things are a pain to get off, even after soaking them for hours with penetrating oil. If I need to get back in there in the future (replace gasket,etc...) and I will, I would like it to be a little easier. Most of my time spent replacing the uppipe lower gasket was spent on the heat shield bolts.
Any suggestions?
Jowrx04 is offline   Reply With Quote
Old 03-18-2006, 04:00 PM   #2
WR^2X
Member#: 37617
That should be fine.
WR^2X is offline   Reply With Quote
Old 03-20-2006, 09:29 AM   #3
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
Yes you can replce them w/ stainless. Dont torque the stainless too much. and be sure to use good antisieze on them all. coat them liberally. Sometimes the stainless and carbon steel of the capture nut will corrode together w/ the heat and salt.
permatex rated to 1500F will work good.
LyveWRX is offline   Reply With Quote
Old 03-20-2006, 12:28 PM   #4
Legba
Member#: 88589
2005 STI
the best one
LyveWRX nailed it. There are torque specs online you can find that will give torque specs for whatever stainless fasteners you use. High temp antisieze is a good idea too.
Legba is offline   Reply With Quote
Old 03-20-2006, 12:30 PM   #5
ChgoJay
Member#: 71722
Its not just a good idea, it is a must!!!!!!!!!!!!!!!!!
ChgoJay is offline   Reply With Quote
Old 03-20-2006, 12:38 PM   #6
-Kevlar-
Member#: 82378
the only one i have left around the downpipe is the upper one and its only got 3. i just left the rest off.
-Kevlar- is offline   Reply With Quote
Lot of part vf39 injector cf exhaust heat shield cusco heat shield Ect ppericfe Tri-State Area Private Classifieds 14 02-28-2009 08:08 AM
(NYC)Lot of part vf39 injector cf exhaust heat shield cusco heat shield Ect ppericfe Engine/Power/Exhaust 13 01-07-2009 11:27 PM
FS: stock turbo heat shield and 02 Axle back stock exhaust bigturbosti Engine/Power/Exhaust 1 05-12-2008 11:12 PM
FS SoCal: Blitz SUS intake, stock exhaust, heat shield, cats, uppipe Lazyxturb0 Engine/Power/Exhaust 8 12-14-2006 09:34 PM
exhaust manifold heat shield bolt chewbakarox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-15-2005 05:04 PM
