Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 03-18-2006, 03:51 PM   #1
Timmay
Member#: 5844
02 WRX
Blaze Yellow
Default 02 WRX Failed Emissions - What Now?
I need some advice/recommendations on passing emissions. My 2002 WRX has failed the carbon monoxide test for emissions twice. The readings were 25.3764/25.1095 and the limit is 20 (Colorado). All the other tests passed. Here’s what I have on the car. The engine was hot for both tests.
Test 1
- COBB AccessPort ECU Stage 2, 91 Octane as the base map
- MRT Turbo Back Exhaust with a high-flow cat in the DP
- JDP STi up-pipe
- Walbro 255 fuel pump
- The intake is more or less stock, but the snorkel and the scoop were removed
- The car had more or less a full tank of gas
- Name brand gass, full tank, 91 octane
- Recent oil change
Change for Test 2
- COBB AccessPort ECU Economy 91
- 4 gallons E-85
I have the stock turbo back exhaust that I could install if needed, but I think the car should’ve passed as is. Any ideas what might be causing this? Has anybody else run into these problems? There are plenty of folks who are passing emissions around here with 1 cat.
Thanks – Tim (TIMMAY!)
Timmay is offline   Reply With Quote
Old 03-18-2006, 03:57 PM   #2
wacerx
Member#: 96075
07 Schwinn
Candy green
may be a bit too much extra work, but i would say throw on the stock DP pass with flying colors and then switch back.
wacerx is offline   Reply With Quote
Old 03-18-2006, 04:14 PM   #3
z&cobb
Member#: 12344
2002 2JC
blue
Test 1
- JDP STi up-pipe
- Recent oil change
Change for Test 2
- 4 gallons E-85
The only easy things I can think of are a new air filter, and a good Italian tune up run with a high detergent gas, like Shell V-Power, since you still failed with a boat load of alcohol in the tank.
How do they conduct that test? They don't take sniffer readings in Maryland on an 02 WRX. Is it on an awd dynamometer, or a just a probe up the tail pipe.
z&cobb is offline   Reply With Quote
Old 03-18-2006, 04:26 PM   #4
Timmay
Member#: 5844
02 WRX
Blaze Yellow
I'm in the process of putting on the old exhaust and new plugs now. Lame... Hella lame...
Old 03-19-2006, 10:48 AM   #5
WickedRydaX
Member#: 31900
Don't feel bad I have to do an engine swap to pass, it's just part of the game you got to pay if you want to play.
MCL
WickedRydaX is offline   Reply With Quote
Old 03-19-2006, 01:42 PM   #6
Timmay
Member#: 5844
02 WRX
Blaze Yellow
Damn, dude. You win... What has to happen to require an engine swap to pass?
Old 03-19-2006, 09:18 PM   #7
azn2nr
Member#: 35276
the real question is are you failing the 2 speed idle test at idle or at 2500?
azn2nr is offline   Reply With Quote
Old 03-19-2006, 11:23 PM   #8
SVTHorsnake
Member#: 88794
'01 Turbo SVT Cobra
'07 997 911 TT
they're still using sniffers out there? if you're engine light's off, you should try finding a place that hooks into obdII port.
SVTHorsnake is offline   Reply With Quote
Old 03-19-2006, 11:31 PM   #9
WickedRydaX
Member#: 31900
It is easier to do a full swap then a part by part "restocking" of the car. Big turbo, big injectors, custom fuel lines, TGV deletes, just a lot of thing that cause CEL's. I got done with it today, only two codes after the swap so far. P0103 Mass or Volume Air Flow Circuit High Input. P0113 Intake Air Temperature Circuit High Input. Cleared them and haven't come back yet, not too bad if I say so myself.
MCL
Old 03-20-2006, 02:19 AM   #10
FireScoob
Member#: 86642
FireScoob is offline   Reply With Quote
Old 03-20-2006, 06:06 AM   #11
Timmay
Member#: 5844
02 WRX
Blaze Yellow
That's interesting. I got the same error codes when I disconnected the battery and pulled the MAF. I cleared them and they haven't come back.
Old 03-20-2006, 06:13 AM   #12
Timmay
Member#: 5844
02 WRX
Blaze Yellow
Also, I'm not exactly sure what's testing what, but they plug into the ODBII port and they put something over the exhaust. I suppose they could just be venting the echaust?
Old 03-20-2006, 07:24 AM   #13
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
Its an OBDII scan and a sniffer. However, it is rumored that the sniffer will no longer be required very, very soon in Colorado. I hope the rumor is true 'cause I will have to emission my '04 in '09.
D fresh is offline   Reply With Quote
02 WRX rotor removal: What is the size of the huge nut that holds the rotor on? phasedlife Brakes, Steering & Suspension 34 02-01-2011 03:56 PM
02 WRX hit a ditch, now stuck in 3rd Max419 Transmission (AT/MT) & Driveline 7 07-26-2009 09:26 AM
02 took a dump...what now? UpSideDownDesi Transmission (AT/MT) & Driveline 26 05-10-2007 10:53 AM
My 02 WRX Tell me what you think cfwrxtasy Member's Car Gallery 27 04-21-2005 02:32 PM
02 WRX factory alternator, what is amp rating? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-29-2004 10:52 AM
