Old 03-18-2006, 04:04 PM   #1
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
Exclamation WRX running gear and motor in my 85 GL coupe.
We have started the full process of converting a 85 Subaru Gl 3-DR Hatch to street/track spec converting the powertrain and suspension to 2004 subaru WRX specs. The WRX doner car has been fully striped of all components we are using.
As you read this the GL has the engine and transmission removed and is sitting on a custom table we welded up on casters so the car can be moved around the shop with out the suspension in it. We are in the first parts of this project and have no real timeline in mind as we are taking it a day at a time.
This is a F'n huge project and not for the weak at heart. This is no joke either. Pictures will be posted soon!
The car will be utilizing:
SDS management.
Fuel Cell (for multiple reasons) as the suspension goes through where the stock tank is.
Stock WRX engine
Stock WRX transmission
Large Front Mount Intercooler
750cc Injectors
Turbonetics T3-T4 Hybrid turbo
40mm Deltagate Wastegate
Undecided on BOV
Stage 3 street clutch with light flywheel
Stock WRX suspension
Stock WRX brakes
Stock 04 WRX wheels
Full 7 point roll cage
Aftermarket gauges
I will update this in about a week with some pictures and more details of the process as it goes.
CB!
B&B AUTOMOTIVE GROUP LLC
SPOKANE, WA
USA
neighbor667 is offline   Reply With Quote
Old 03-18-2006, 04:15 PM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
You are my hero. I've been waiting to do a project like this myself but I don't have the time. Make sure you do all the fuel lines... the new pump will run way too much pressure for the old carbureted lines.
Old 03-18-2006, 04:51 PM   #3
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
EVERYTHING is getting replaced, no worries. The GL body is just being used as a shell basicaly. Even the steering components are being converted. CB!
Old 03-19-2006, 01:32 AM   #4
suberdave
Member#: 101865
88 GL-10 STi
i did this to my 88 GL wagon with Ver 2 STI stuff. it is an awesome project. took me a little over 100 hours to do mine. here are some pics
More Pic's
http://www.suberdave.com/subaru/glwrxt/
any questions on what i did send me a PM
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 03-20-2006, 03:08 PM   #5
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
Similar, but the 85 GL needs much more structural modifications etc. to fit the motor, trans and suspension. Also shortened drive lines are needed. Front suspension is not too bad, just top plates and some slight magic but the rear suspension is slightly nightmare-ish. Also frame rails are too narrow on the 85 GL and while the cross member is a help it needs major mods to fit into the whole working eqation.
I like what you did there it is a noteable transplant. People should be envious of what you got there. We are doing more the pro race mock-up approach. Will probobly be doing a 2.2 stroker set up if we can get COBB as a sponsor. We will see how that all goes. Local sponsorship has been a breeze but the national companies are tricky, even though Christian hacked on our 04 wagon last year on the COBB dyno for almost 10 hours...CB!
Old 03-20-2006, 11:16 PM   #6
Kincaid Racing
Member#: 82249
MY99 Impreza V-6
Java Black Pearl
I like the originality of you car! Now can you squeeze a STi motor in a justy?
Kincaid Racing is offline   Reply With Quote
Old 03-22-2006, 02:24 PM   #7
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
Sure, we hauled an STI motor from Yakima to here last Summer but had to put the rear seats down...CB!
Old 04-02-2006, 07:46 PM   #8
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
Posting pics this week. Not decided though if I will be utilizing a STI block or not. This is the most major considration so far... CB!
Old 04-06-2006, 04:35 PM   #9
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
Old 04-07-2006, 04:36 PM   #10
JWX
Member#: 28990
oh sweet a gen 2, do keep us updated.
BTW its called a hatch, when you said 85 GL coupe, I thought you were talking about a "gen 3" EA82 coupe/3dr
JWX is offline   Reply With Quote
Old 04-08-2006, 04:25 PM   #11
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
Would have done a GEN-1 but there are even more space issues involved...CB!
Old 04-09-2006, 10:17 AM   #12
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Holy shiit! Latching on for this brilliant project!
Kreeger is offline   Reply With Quote
Old 04-09-2006, 04:45 PM   #13
Keshav
Member#: 1654
1998 GC8 Unicorn
MV Agusta Brutale S
sweet! I can't wait to see more pics.
Keshav is offline   Reply With Quote
Old 04-09-2006, 06:16 PM   #14
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
um, so here goes.
pre '85 is considered gen I with only minor changes between the older EA71 and EA81 models between '78 thru '84. (headlights, grills, ect.) old school '85+ is considered Gen II, with the exception of the hatch (seen here) also sometimes called the threedoor, which would get parts suppliers confused with the three door RX. but, case in point, this is an EA81 pushrod OHV powered Gen I built after '84. (the only subaru past model year '84 to keep the EA81 in the USA.)
let's not forget that there are variations of turbo heads for the EA82 motor, so when someone says Gen II or Gen II turbo head and are talking about the EA82, that's a different story.
FWIW, my '88 I had to order parts from an '84 because parts stores would get me EA82 parts. if you were to see an '81 and an '89 they would be identical, minus the carb in the '89 would have an ECU, solenoids, an O2 sensor and TONS of vacuum lines.
JonofScio is offline   Reply With Quote
Old 04-09-2006, 06:21 PM   #15
Caboobaroo
Member#: 72335
89's RX/XT6
Blacksssssss
Originally Posted by JonofScio
um, so here goes.
pre '85 is considered gen I old school. '85+ is considered Gen II. with the exception of the hatch (seen here) also sometimes called the threedoor, which would get parts suppliers confused with the three door RX. but, case in point, this is an EA81 pushrod OHV powered Gen I built after '84. (the only subaru past model year '84 to keep the EA81 in the USA.)
Umm acutally Jon, a gen 1 car is pre '80 unless its a Brat then it was pre '82 for them. Gen 2 are the EA81 bodystyled cars like the hatchback you had. Then gen 3, is the EA82 bodystyle, like my RX.
Caboobaroo is offline   Reply With Quote
Old 04-09-2006, 07:40 PM   #16
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
Thanks for jackin the thread on that note for a second... CB!
Old 04-10-2006, 01:15 PM   #17
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Whats that car weigh?
Any idea? Should be a neat project to watch.
jetfan8178 is offline   Reply With Quote
Old 04-10-2006, 02:38 PM   #18
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
The 4x4 was around 2200 IIRC. The modern components will probably bring the weight up a little but even a stock EJ20 in this thing will be a ROCKET!!
Old 04-10-2006, 03:46 PM   #19
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
Yup, that was the thought. Unfortunatley the engine will not be stock and the car may be slightly faster than its original powerplant. He he...all kidding aside there are two main reasons were doing this and many smaller reasons really.
Reason # 1. To make a street legal rocket ship that will be utilized at the track.
Reason # 2. A big F.U. to all those who said it couldn't be done...Hey we really do love our Subies and thats whats its all about.
CB!
Old 05-05-2006, 01:43 AM   #20
neighbor667
Member#: 52060
2004 Sooby WRX 2.5
New pics on Saturday...
Motor is in for first Mock up.
Suspension is in in the front prior to coil overs.
Figuing out the clutch hydraulic issue as we speak.
Loooks damn sexy as it is.
Thanks again to dave at STM!
CB!
Old 05-06-2006, 04:55 PM   #21
970subaru
Member#: 45703
oh hell yeah.
I have been looking to do this same conversion for a while now, but using the entire powertrain out of my legacy.
what struts?
what knuckles?
what control arms?
what axles?
I was thinking that it would work to ream the ea81 control arms for legacy ball joints and try to keep the suspension geometry similar to a 5 lug car. axles would probably have to be custom. I will build some coilovers with parts from stockcar products to be easy to use ea81 strut towers. hoping that the inserts are the same.
what are you doing for the rear suspension? I am planning to get rid of the torsion bars and run circle track coilover parts in the stock shock position.
please get back to me on this if you dont mind, I am really looking forward to building a 2100lb awd subaru.
I dont realy have the ea81 car yet so sorry if my questions are kinda stupid.
right now I am searching for a hatchback to do this on, any one know of one near me holla. the only prospect I have right now is a EA71 brat which will be a lot harder to fit an EJ so I am pretty sure that I am going to have to keep looking for a hatch.
970subaru is offline   Reply With Quote
Old 05-09-2006, 10:47 PM   #22
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
Is that late 70's Rabbit a 16v swap? Did it come from NH?
JeremyRS is offline   Reply With Quote
Old 08-01-2006, 02:13 PM   #23
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Bumpity... any updates?
Old 12-10-2007, 04:12 AM   #24
newyorkreload
Member#: 63955
1885 Broom Stick
Wood
...and then?
newyorkreload is offline   Reply With Quote
Old 12-12-2007, 04:57 PM   #25
CPTsWRX
Member#: 75782
2004 FXT
Cayenne Red
Yes please more!!
CPTsWRX is offline   Reply With Quote
STi Brembos in my '87 GL Caboobaroo Subaru Conversions 62 02-07-2008 10:06 PM
wrx 1/st and 2nd in my 98 tranny IllNastyImpreza Transmission (AT/MT) & Driveline 3 02-07-2007 07:25 PM
wrx motor in an 89 gl wagon rusty89wagon Subaru Conversions 5 11-12-2006 04:26 PM
Swapping a 04 sti motor in my 02 wrx.......got some questions mcu81 Subaru Conversions 3 07-13-2006 12:35 AM
I just put my new 2.5 motor in my 97 L- finally got everything all set to go and turn Murray Normally Aspirated Powertrain 12 12-30-2002 08:24 PM
