Old 03-18-2006, 09:53 PM   #1
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
Default Un-Married AP, Now P0546 Code
P0546- Exhaust Gas Temp. Sensor Circuit High (Bank 1 Sensor 1)
Why am I getting this, EGT sensor is in and hooked up, this car is a handfull of headaches, this is a new problem in my list of 3 already !!!!!
EagleRockWrex is offline   Reply With Quote
Old 03-18-2006, 10:39 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....it got cooked by running yer AP....take it out, put in a bolt, and use the 2.2k ohm resistor and be done with it.
Old 03-19-2006, 03:42 AM   #3
Christian.
Member#: 87604
The AP had absolutely nothing to do with this failure becuase this is a hardware failure, most likely. You can have this diagnosed to find the failure point.
Take care,
Christian.
Christian. is offline   Reply With Quote
Old 03-19-2006, 10:56 AM   #4
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
Car has 10k miles on it ....
Old 03-19-2006, 02:31 PM   #5
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
First, it helps to tell us about your car. From your profile, it says "stage 2" and I am going to guess that you have a gutted up pipe. A hot tune, and no cat can cook the EGT sensor. It is a very common failure. (A search on p0546 would tell you this) The post from Christian was a waste of bandwidth. Software can break hardware. The AP can cook the sensor, but it also usually takes the cat being gone.
As to your "new problem in my list of 3 already..." You better slow down a read some more. This is a basic problem, and not a big risk. Other common mistakes lead to broken ring lands...
bofh is offline   Reply With Quote
Old 03-19-2006, 07:49 PM   #6
JRSCCivic98
Member#: 67080
If you're running an OEM map then the EGT CELs will go off if there is no CAT in the uppipe. This is probably your problem. If you can log (try ecuExplorer from Tari) the EGT sensor and you actually get a changing temp reading while you drive (you can't log it at idle... not enough exhaust gas temp to bring the temp high enough to start the sensor reading) then the ECU is just setting the CEL because there's no CAT in the uppipe. If you put a stock uppipe back in with a cat then it's probably a bad sensor. I've had my OEM EGT sensor in my APS uppipe for 30k+ miles without any problems and it still reads properly.
JRSCCivic98 is offline   Reply With Quote
Old 03-19-2006, 11:50 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
....the EGT probe got cooked....see my above post
Old 03-19-2006, 11:55 PM   #8
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
I love it when people modify their cars, then say it's a headache when stuff goes wrong or breaks
Another vote for EGT probe getting b0rked.
gjhsu is offline   Reply With Quote
Old 03-20-2006, 02:38 PM   #9
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
Brief history- Was stg II, catless TBE and AP, stock UP. I'm not back to stock TBE and unmarried AP and now I have the CEL and some strange whinning and whistling sounds coming from under the hood and less than 9psi at max boost. However, the car no longer smokes at idle when warm anymore....
Old 03-22-2006, 12:47 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
....deeeeeeeeeeewwwwd....sounds like ya blew the EGT probe outa the UP
Old 03-22-2006, 01:16 AM   #11
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
yeah sounds like the sensor is hanging out of your exhaust... and the tip is easy to damage. Take Uncle Scotty's first piece of advice and replace the sensor with a BOLT. The bolt size you need is:
M12x1.25
Screw it in UBER-TIGHT or else it'll fall out too. To fix the CEL, just unplug the entire EGT probe from the connector on the strut tower and shove the two ends of a 2.2kohm resistor from radioshack into the connector and tape it over to seal it.
But above all, we cannot fix this problem for you. You need to actually go out and LOOK at the car and FIND your problem and fix it. It sounds like you've had some ongoing issues and quite frankly, it sounds like you pulled the panic-move of trying to put it back to stock thinking that would cure the problem. Well, that almost never works.
nhluhr is offline   Reply With Quote
Accessport V2 un-married AP-SUB-002 WRX STi Legacy 2.5L timberwolfmedia Engine/Power/Exhaust 18 06-01-2009 09:07 PM
un-marry AP v1 with out AP!? ravenlunatic Newbies & FAQs 23 10-01-2008 08:24 PM
What does Cobb actually do to un-marry AP from Car if you send to them? Carlito2002WGN Newbies & FAQs 24 05-14-2008 05:59 AM
FS::: 04 wrx un married AP with stuff OvrClkdPmp MWSOC Private Classifieds 16 04-24-2007 08:02 AM
Confirmation of un-married AP Weakness AccessPort 4 09-08-2006 08:17 PM
