Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-19-2006, 10:59 AM   #1
scoobyless
Member#: 40192
04 STi
Blue/Gold
Default lean idle
Hi, I have an 04 STi with utec/tuner along with fmic, intake, exhaust, etc. Recently after installing the ewg I started having a really lean idle throwing the p0171 cel even though I know the ewg couldn't really be causing this so I'm assuming it's the fmic/intake which I put on a week earlier. My cruising afr's are really solid along with wot pulls, just my idle afr gets up to 17-18 at times and sometimes around 20 after driving and pushing in the clutch. I was wondering if there would be a way to tune in order to get the idling afr down. Thanks!
Randy
scoobyless is offline   Reply With Quote
Old 03-19-2006, 08:30 PM   #2
Davenow
Member#: 23676
check for exh leaks before the o2 sensor. I had the same thing. I was reading 17.5-1 at idle, but if I was on the gas at all, they were normal.
Old 03-19-2006, 10:01 PM   #3
scoobyless
Member#: 40192
04 STi
Blue/Gold
I'm assuming your talking about the first 02 sensor, correct? And that would just be leaks in the header, right?
lean idle @ start up Spec_C UTEC 3 01-08-2007 10:32 AM
Lean Idle - help please, lol crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 04-19-2006 03:53 PM
Link Lean Idle JenisonWRX Engine Management & Tuning 0 10-17-2004 04:06 PM
Lean idle any ideas? MINO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-27-2004 09:57 PM
HELP - Ecutek + PE 650 cc = LEAN idle yellowWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 05-05-2003 12:03 AM
